Question about Passport 8500 Radar Detector
What's the fix?
8500 going off laser every 2 minutes.
  • Anonymous Sep 26, 2008
    I have the exact problem.... but mine just started doing this, cant find a solution yet. Ive reset the unit but that didnt work.
  • Anonymous Oct 09, 2008
    same problem
OK.....this is strange. I have the same problem with constant false alarms switching between POP and KA for five to ten minutes constantly. I tried the Q tip recommendations from this site and no luck. Here's the weird part, when pluged into my 2006 Lexus GS the problem continued. When I plug it into my new used car a 2006 Mercedes CLK it works perfect! So, my conclusion is it must be a combination between the dector and the Lexus that causes the problem. I'm confused because it took over a year and a half for the problem to start in the Lexus. I plan on calling Escort tech dept. to see what the heck would cause this.I'll post the results from the call afterwards.
Posted on Oct 19, 2008
Getting false laser readings, any adjustments?
This is fixable as described in other threads here. This is annoying and seems to be random, though it also does it sometimes when the wipers are turned on or I use the windshield sprayer. 2 minutes with a smal Philips screw driver and a Q-tip will fix it. I just did mine and it works great now.
Unscrew the three screws, pop the three components apart (it really is a no-brainer since they only fit back together ONE WAY, so don't be nervous. There is not anything that is going to fall apart or spring into a hundred pieces in there.
I used canned air to blow everything out and just used the Q-tip on the front window and the parts that looked like the detector window internally... I didn't bother swabbing all of the board.
IT WORKS! GREAT FIX!!!!! DO IT!! NO MORE FALSE LASER ALARM WHILE ACCELERATING and randomly.
Apr 27, 2010 | Passport 8500 Radar Detector
Passport 8500 escort
Hello!!
Hold all three buttons down and reset it.hope it fixes the problem!!
Regards
Smilemaker
Jul 19, 2008 | Passport 8500 Radar Detector
Vertical laser error
If the error code means "vertical laser error" you could check for the flat connector of the vertical laser module. Here I send to you an image to explain it. 0b500ff.jpgIF all is ok. you could try with another vertical laser board and replace it
Apr 20, 2010 | Datalogic Magellan 8500 Wired Barcode...
Hae brother MFC-8500 and just replaced
This is an easy one. With the power on, open the front door, where you installed the drum. Press the CLEAR button. The display will ask something like, "Change Drum? Press 1 for yes. Press 2 for no."
Press 1.
Close the front door.
Feb 10, 2010 | Brother MFC 8500 All-In-One Laser Printer
I also have a 8500 passport that flashes laser and will go off
Does this happen in the city or does it happen when you are out in the middle of nowhere? I have seen laser detectors that are falsely triggered by various lighting devices that contain wavelengths of light similar to those used in police laser.
If this is annoying and you dont want to hear it, you can locate the receiver element that detects the laser signal and cover it up with a piece of black electrical tape. That should stop whatever is causing your problem unless there is something actually broken inside the unit.
Thanks,
r
Aug 21, 2009 | Passport 8500 Radar Detector
Canon Laser Class 8500
Problem is caused by worn paper feed tire, and seperation tire. The worn tires causes vibration on the seperation plate. Replace both tires.
Dec 12, 2008 | Canon LaserClass LC 8500 Plain Paper Fax
Laser warning going off all the time
Hi All,
I fixed my Radar, No Manufacturer help, no cost to me at all. I got advice from a forum member on a satellite forum I belong to. So what I did was I took apart the radar. Watch carefully how it comes apart so you can reassemble again after. Get a Dry Q-tip (ear swab) leave it dry so you do not end up leaving and residue on the diodes etc. Start by cleaning the horn, wipe the electronic board all over gently with the Qtip , blow ou the diffusion screen (leave the spit in your mouth). After all that I did not see a spec of dirt on the Q tip I used..there was no sign of dirt, residue but whatever I did do fixed the problem. I have been using it for three months and not one false alarm from the laser mode.
Good luck all......
May 30, 2008 | Passport 8500 Radar Detector
Help
rest teh machine by shut off the machine and pull out the pluug. wait 2 minutes and plug in the power and turn on the machine.
May 29, 2008 | Brother MFC 8500 All-In-One Laser Printer
HP 8500 Color Laser Printer- problem priting reds
the basic causes for this problem is either the foil is bad or weak. secondly the element in the fuser unit doesnt heat properly so try replacing it with a working one n see what happends.
May 28, 2008 | HP LaserJet 8500 Color Printer
Cannon Laser Class 8500- Memory Upgrade problems
How can i get information from the memory beginning in 2005
Jan 22, 2008 | Canon Laser Class 8500 Printer
Passport 8500 Radar Detector Logo
377 people viewed this question
Top Escort Vehicle Parts & Accessories Experts
Jason
Steve
Are you an Escort Vehicle Part and Accessory Expert? Answer questions, earn points and help others
