Question about Pantech Duo Smartphone
How do I add mp3 as my ringtones?
I have the songs i want in my Pantech Duo already but i want to use them as my ringtones. Infact i added them under "Ringtones" in My Stuff section. Some say that the song has to be no more than 30 seconds and has to be under 300kb. The song i want as a ringtone is 1min. and 3sec. I'm willing to shorten it but how do i split it. I tried using the Windows Movie Maker, it does split the song but it will only play for Windows Movie Maker. I am not able to paste it anywhere else. PLEASE HELP =.=
Don't use Audacity. It sucks. there's another free audio editing program just called "Free Audio Editor." Here's the link for the download
http://www.free-audio-editor.com/
If you load the song into this you can edit it much better than you can with Audacity. It's a freeware version and the only output you can save the files to is .wav which is ok for the Duo.
Posted on Jan 16, 2009
Download a software to your computer called Audacity. It will let you cut songs and then you can save them to your phone and use them as ringtones.
Posted on Sep 05, 2008
Ringtones
The phone will only play ringtones applied to its memory. You need to move the tone from the SD card to the phone. First check your user manual for ringtone specifications. It should tell you how big a file you can use.You may have to edit the song to fit.
Aug 17, 2009 | Cell Phones
you need to load tones into the ringtone file in my documents, then go to settings>sounds>ringtones and select the one you want. If you have tones in the ringtone folder and its still not working check the size and format of the tones, windows mobile 6 was only designed to accept tones under 320k and in .mp3 or .wav formats.
Sep 21, 2008 | Pantech Duo Smartphone
Can i put a song from my SD card as an ringtone on my pantech duo?
You can but the file needs to be labeled My Ringtones. If you have tones in the ringtone folder and its still not working check the size and format of the tones, windows mobile 6 was only designed to accept tones under 320k and in .mp3 or .wav formats.
Sep 07, 2008 | Pantech Duo Smartphone
Using a ringtone for text alert
Always think carefully about altering your phone's window registry for any reason. If you follow the instructions all should be fine. If you are a complete novice, I wouldn't recommend it, you could seriously mess up your phone. Use at your own discretion.
*WARNING I DO NOT know the extent at which this works ( "How many tones that can be added""How long the ringtones can be"FOLLOW THE INSTRUCTIONS!! I AM NOT/WILL NOT BE RESPONSIBLE FOR ANY DAMAGE CASUED TO YOUR PANTECH DUO BY PERFORMING THIS PROCESS!! Doing this involves tinkering with the phones defaults if you change something that you are not supposed to the phone may not work causing the phones warranty to be void (Solution:If your not sure what your doing DONT DO IT). Before you start make sure all ringtones you desire to be used as alerts for text messages, voicemail, etc. are in the "\My Documents\My Ringtones\" folder. This is very important as you will see. Also make sure all ringtones are short enough (15 seconds MAX) that they will be recognized as useable tones*
1. Download the Mobile Registry Editor (Don't worry it's Free) http://www.breaksoft.com/Blog/Utilities/2005/1/Mobile_Registry_Editor.aspx
2. Connect your Pantech Duo to your Desktop/Laptop and run the registry editor
3. Once your device and has been connected to the Editor open "HKEY_CURRENT_USER" (should be the second file folder down)
4. Open "Control Panel" (this should also be the second file folder down)
5. Click (and only click) "Sounds" (Should be the 15th file folder down *make sure its just "Sounds" and not "SoundCatergories"*)
6. Double Click "All Sounds"
7. In the pop up menu box scroll down to the end of the list of assorted factory tones
8. Put your cursor at the end of the last line and press enter to creat a new line to type in
9. Type in " \My Documents\My Ringtones\ " immediately by the exact name of the file you wish to enter ( EXAMPLE: \My Documents\My Ringtones\342.wow.mp3) MAKE SURE YOU ADD THE FILE TYPE (.wma,.mp3, etc.)
10. Click "OK" when you are finsihed adding your ringtones
11. On your Pantech Duo from the home menu Click Start>Settings>Sounds>Text Message then scroll through the tone options to reveal that tones you added are options and and can be play automatically!!
Reply and tell me if it worked, if it didn't, or if the directions are unclear P.S. have someone text you to double check if it works
Aug 23, 2008 | Pantech Duo Smartphone
Pantech duo ringtones
I get free music ringtones from myxertones.com
Just register and then start downloading the instructions are there once you pick a song and you can listen to it before you download it
Jul 19, 2008 | Pantech Duo Smartphone
How do i get my ringtones from my sd card set as my ringtones?
I got ringtones from my microSD card on my Pantech Duo to set as ringtones by using another phone. I put my microSD card in another phone and bluetoothed them to my pantech duo. When i had bluetoothed all the ringtones i wanted onto my pantech duo, i removed my microSD card from the other phone and put it back in my pantech duo. Then i went to "Settings" on my pantech duo and then "sounds". The first option is "ringtones" so i used the circle button to select the ringtone i wanted and hit "done".
Jun 30, 2008 | Computers & Internet
Ringtones
hit edit contact and there should be a link under sounds and alerts saying ring tone.. it might be at the very bottom. just hit this and choose the ringtone
Jun 16, 2008 | Pantech Duo Smartphone
Not able to set my fav song as ring tone
If you convert the song to mp3 format, you can set it as a ringtone.
Mar 29, 2008 | Pantech Duo Smartphone
Pantech Duo
you need to cut a somg below 30 sec and make it under 300kb.put it under thenpantech duo icon in hte active synch and into sound files.
Nov 27, 2007 | Pantech C120 Cellular Phone
Pantech Duo Smartphone Logo
264 people viewed this question
Top Pantech Computers & Internet Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Are you a Pantech Computer and Internet Expert? Answer questions, earn points and help others
