Question about Kirby Ultimate G Bagged Upright Vacuum
Burning smell, vacuum wont turn on now
Kids were using Kirby Ultimate g and noticed a burning smell, so they turned vacuum off and told me (dad), now it wont turn back on. Belt is ok.
  • yespao Sep 18, 2008
    I am having the same situation. I have tried adjusting the brush and cheking that the belt is on correctly. I do not know what else to try.
  • 120 Answers
The front of the machine ( the peice that holds the brush roller ) and the bag unit are part of a safety system that will only let it turn on if both are locked firmly in place, after checking that examine the cord, look for any burn marks especially at the plug and where the cord clips into the retainer on the handle and if you can where it plugs into the machine but you will probably need a set of torx screwdrivers for that. if there was any funny noises before it shut off the kids could have damaged the motor, and just because the belt isnt broken it can still get burnt and make a bad smell change them ever six months to a year
Posted on Sep 25, 2008
Kirby Sentria 2 burning smell (not belt)
Actually it can. If the machine has a defect but the good news is that is has a 3 year warranty. Take it to a Kirby authorized repair shop not a vac and sew and they will fix it right up....I am a factory authorized service tech for the Kirby co.
Dec 16, 2013 | Kirby Generation 3 Bagged Upright Vacuum
I have the G series Kirby silver vacuum, I was vacuuming and started to smell some burning. Looked down and my green light was off also. What could it be? PLS HELP
Your belt is burning and will eventually wear down and break. The green light comes from copper brushes on your roller creating an electrical current that lights the little green light. As long as the roller is turning, the light will stay on. There may be something jamming the roller (hair, string, paper, etc). Clean the roller off and replace your belt. If you don't replace the belt it will break soon enough. Once you start smelling the "rubber burning" smell it's and indication that your belt has deteriorated at some point and has a weak spot in it. Clean the roller and replace the belt and it should be fine.
Apr 20, 2013 | Kirby Ultimate G Bagged Upright Vacuum
Making a burning smell...not working as it should
remove the brush roll clean the brush end bushings and replace with a new belt
Sep 29, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby wont come back on checked outlet its ok
If you are refitting the shampoo tank, you havent turned it far enough. There is a safety switch that must lock
Mar 07, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Smells (burnt rubber) like it's overheating when I vacuum
I would check the brush roller and make sure it turns good and replace the belt on it . When you smell burning rubber most of the time it is the belt .
Feb 23, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Burning rubber smell when the vacuum is on.
it sounds like the belt may be burning like the roller bar is stuck maybe or the belt is stretched and is burning itself off
Jan 11, 2009 | Kirby Ultimate G Bagged Upright Vacuum
G4 model is burning
May be the carbon brushes. DO NOT run the vacuum until you check them. If they are worn out, they can damage your armature and that is expensive to replace. Try my troubleshooting guide. It helps with do-it-yourself Kirby repairs. You'll also find links to directions and free repair guides!
Aug 22, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Belts Burning
Yes, replace the brush roll, the ends or end is probably bad and causing the belt to slip and burn up.
May 11, 2008 | Kirby Ultimate G Bagged Upright Vacuum
The vacuum turns on but wont run smells like burning rubber I took the bottom off and the belts dont appear to be broken but the one connected to beater bar seems like it may be loose
Generic problem for all Vacuums
Posted by mmetcalf on Apr 24, 2008
the vacuum turns on but wont run smells like burning rubber I took the bottom off and the belts don’t appear to be broken but the one connected to beater bar seems like it may be loose
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
In answer to your question, the reason it smells like burning rubber is because the belt is too loose and it is burning the inside of the belt because it is to loose, the average belt change for a Kirby vacuum is every 4 to 6 months, the tighter the belt the better the cleaning and always use the genuine Kirby belts because they are designed to work with the Kirby, there are replacement belts that will work and are less but they are made to the correct size but Kirby vacuums always s work better with genuine parts. If you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday 1-800-657-1874 If you cannot find a local dealer near you they can ship you the parts UPS.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 24, 2008 | Vacuums
Kirby Ultimate G Bagged Upright Vacuum Logo
163 people viewed this question
Top Kirby Vacuums Experts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
