Question about Craftsman 4 Cycle Blower/Vac
Leave blower and vac
Will not start. Has spark but will not fire. You can spray starting fluid in
spark plug hole or in the intake of of the cab. Still no fire.
  • Gary R Waniolek Sep 25, 2008
    I have a craftsmen 205 hp leaf blower that will not start. Please help
    Scholar:
  • 62 Answers
I don't mean to over simplify this, but are you using fresh gas? Gas blowers and string trimmers are extremely ticky when it comes to gas. They like it SUPER fresh. Not just fresh from the can, but fresh from the pump! And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with string trimmers and blowers, and it fixes the problem 75% of the time. Also make sure your spark plug is clean. If you are not sure, a new plug couldn't hurt.
Hope this helps!!
chad
Posted on Oct 08, 2008
  • Alby Thorp Apr 10, 2012
    Also, try to use high octane 100% gas. Ethanol will eat up rubber O-rings, etc. . . over a period of time. You should see an immediate difference in how it runs. Try to drain the gas out of the tank if not used for more than a week, as it will tend to gum up the carb from sitting, especially if left in the heat.
96 ciera 2.2 ran fine. parkedat night next morn wont start.its getting fuel and fire but sounds like its not even trying to start
Check for spark.. pull one spark plug out set it on bare metal(away from cyl hole fuel could light from spark) turn vehicle over and look for spark should be a nice lightning bolt looking spark... blue spark is weak spark.. and see if it's getting spark...,, if not,,."try new plugs.,wires,distributor cap&rotor " also first.spray a little starting fluid down the injection system turn it over and see if it fires.if it does then it's a fuel issue prob not electrical... try that.hope it helps
Dec 31, 2016 | Cars & Trucks
My poulan-pro leaf blower
Does it start if you spray starting fluid into the air cleaner? Try it and let me know.
Oct 30, 2008 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Will not start even withew gas
Try a spray of starting fluid into the carb. If it fires you know you have good spark. If it did not fire replace your spark plug. If it still won't fire point and condensor need to be replaced. If it did fire spray the starting fluid in the carb a few more times to pull the old fuel through the fuel line til the new gas gets through the carb and then it should run. Some machines have a fuel shut off valve make sure it is open.
Dec 13, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
Toro snowthrower model # HSK 635 won't restart, stated first time, ran about ten minutes, then died, put brand new spark plug in, getting good spark, just won't fire up, even when I tried a li
check and make sure its getting fuel. when trying to start, spray some engine starting fluid in spark plug hole. just a little bit. replace the plug then try to start it. if it starts then quits then its a fuel problem. fuel not reaching engine. good-day !
Jan 30, 2012 | Garden
I've put a new sparkplug and new filter -but the blower won't start . Doesn't even feel like it wants to start
Put a spoon full of gasoline straight down the plug hole. Reinstall the plug, if it starts then you obviously have a fuel problem. You may need a new kit installed in the carburetor. Easy fix.
Nov 17, 2010 | Craftsman 4 Cycle Blower/Vac
CRAFTMAN LEAF BLOWER WONT START
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 19, 2009 | Craftsman 4 Cycle Blower/Vac
The leaf blower won't start and I did change the spark plug and last time it run for like 30 sec. before it shut down again.
Main cause of small gasoline engine failure is carburetor clogged. Try spraying carburetor cleaner into carburetor and intake. Check if unit has air cleaner. If engine starts briefly with cleaner then carburetor needs manual cleaning. Carburetor removal and overhaul.
Jul 10, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Wont start
try some starting fluid in the intake, clean the spark plug. is it an old blower?
Mar 20, 2009 | Craftsman 4 Cycle Blower/Vac
I have a craftman yard vac with a tecmseh 4.5. She has failed to
Hi gr2954;
Lots of the starting problems with 2 cycle engines (weed eaters, blowers, chain saws, etc) are caused by leaving them stored for long periods of time with the oil/gas mixture left in them. what happens is that a residue forms on parts in the carb.
Try the following: empty the fresh gas out of the blower. add a gas stabilizer to the existing gas you plan to put in the blower. You can get this stabilizer at any auto parts store. While you are there get a can of spray start fluid. Put the fresh, modified gas in the blower. Take the spark out and spray some starter fluid in the plug hole.Replace the spark plug and try to start the engine.It will probably take a few cycles of doing this to get the blower to stay running.
when you put the blower up for a long period, empty the remaining gas out then start the engine and run it till it stops. this gets the remaining gas out of the carb.
Nov 30, 2008 | Garden
Craftsman 4 Cycle Blower/Vac Logo
389 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
