SOURCE: error screen trouble shooting
If you have the USB cable and a dvd/cd that contains the software/maps, then it needs to be loaded. Install the software on your computer. With the unit off, plug it into USB, then turn on unit. run program installed from dvd/cd. you can also try resetting the unit by holding down the Menu and Nav key, hopefully a small box appears and you can use the stiff stick to change the numbers. if this does appear, change the numbers to read 32 then press the stiff stick in (pressing enter). _Daniel
SOURCE: mapsupdates
On Garmin gps there is several ways to update your maps you can buy the sd update card, the cd, or upload it from the garmin website using a usb cord sold seperatly. the updates can range from $70 dollars to $120. I work at best buy and we carry all the updates for garmin
SOURCE: how to download map updates for shinco gps
I need a brazilian map to my GS shinco model e202. Someone knows?
SOURCE: How do you update Curtis GPS GPD359
plug the cable in , then google the driver setup for you type of gps and then , you can update it
