Question about LG WM1812C Front Load Washer
LG wm1814cw washer
OE error and I know that is drain error. drained washer hose and cleaned out little stuff. rewashed clothes in washer. still OE error. do I have to turn washer upside down to get to the pump?
  • 489 Answers
No, there is no access to the drain pump other than by removing the front panel to get to it.  It is a job that can be done but you will need to spend some time to disassemble the machine to get to it.
Posted on Sep 29, 2008
Wm1814cw le error cade
Make sure your drain hose is not bent - the code looks like a drain issue. It could be your drain pump. I had to take mine off and it was full of "gunk" and that can keep it from draining, causing that code. I have no affiliation with Home Depot, but they have a great web site showing how to get to the drain pump and how to take it off and clean it or probably just to replace it. Go in to the area to order the part and there should be an option to view a video on how to install it - not too hard, just follow directions. www.homedepot.com/ApplianceRepair 48de78f6-d540-4f0d-8488-f3f5c589abed.jpg 1bc73971-d1f5-473d-8b8f-f05840bc9002.jpg
Jul 16, 2014 | LG WM1814CW Front Load Washer
I have a lg front load washer wm1814cw that will not drain or spin out and come up with a OE error. i love the washer and the dryer. i cleaned out the dairn in the front of the washer were the door at...
take the filter back out and turn it on,( drain spin setting) look inside of the hole and see if the little impeller is turning, if it is not turning you will need to replace your pump,, if it is you have a clog in the drain hose the one from the tub to the pump
Jan 23, 2011 | Washing Machines
Washing machine flashing oe
OE = Drain Error • Not fully drained within 10 minutes.
Check and clean the pump filter. The access panel is located on the front, bottom left of the machine. Place a towel under the front of the pump filter access panel opening before opening to catch any water that may flow out.
Check drain hose on the back of the machine for any kinks or blockage.
Dec 18, 2010 | LG WM1814CW Front Load Washer
I am getting the oe code and i already tried to unplug the washer and drain it. What do i do know?
OE is a drain error, here's some stuff LG recommends.
Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge
If you try the above, and still no success, your looking to replace the drain motor on the unit.
Mar 31, 2010 | LG WM-2277HW Front Load Washer
I have an OE code on my WM1814CW LG Washer
OE code - Check for clogged drain filter on end of hose, bent or clogged dain hose. Make sure hose doesn't go too far down drain pipe.
Hope this helps
Bob
Jul 06, 2009 | LG WM1814CW Front Load Washer
Error Message/OE
sounds like too much water is coming into machine.check water valve,and water sensor.it is bringing in too much water or not enough.
Mar 06, 2009 | LG WM1814CW Front Load Washer
I have an error message on my LG WM1814CW washer The message
This means the machine did not drain within a 10 minute time period. check the pump trap for debris and clean out. Check the drian hose. Check for drain pump operation diring drain period
Washer won't drain
You either have a foreign debris trapped inside the drain pump or the drain pump is broken.  You will need a qualified LG technician to repair this problem.
Jul 01, 2008 | LG WM1814CW Front Load Washer
LG WM1812C Front Load Washer Logo
307 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
