Question about Uniden 5.8GHz Dual Cordless Phone
Uniden Power Max 5.8
When a call comes in the caller shows on caller ID. Problem is that it does not stay. Example, I am out and I come in, check CID and it shows no calls.
I had a friend check today, she called, she showed on caller id, but it did not hold the call.
My extension phone is working fine. Any Suggestions on how to correct the base phone. Thank you
  • chanran Feb 16, 2009
    I too have the same problem. When a call comes in the caller shows on caller ID. But itdoes not stay. It always shows 'caller id Total "0"
    The problem is only with one unit, the other one works perfect and caller ids are displayed on that.
    Any Suggestions on how to correct this. There is no re-set button. Tried de-registering the unit and then registered the same...no results.
    Can any one help?
    Thank you
  • 1,800 Answers
Try to give ur phone a soft reset.
to perform that try menu/settings
or any soft reset button in the phone bottom or back
best regrads
if not help tell me.
plz do rate this poste
Posted on Sep 04, 2008
Try deleting a few entries on your phonebook. One possible reason is that your phone book memory on this perticular unit is full and the same memory is used for CID display. Hope this will work!
Posted on Feb 17, 2009
The Base says new cid:34. How do I get it back where it was. I tried to get a number that rang and it changed the settings
Julie,
Sounds like 34 is the # of calls that came in on the caller ID (CID) lis
To open the Caller ID list, press the little phone handset symbol (it looks like a big "C" then ID next to it) on the right side of the 4-way button (it toggles 4 ways, so press to the right side to get the Caller ID list).
The phone will show the number of new calls (or Caller ID records) and the total number of stored CID records. Use the "up" arrow and "down" arrow to scroll through the list.
It looks like you have the Uniden DECT 6.0 6035, so I attached the manual in case it helps.
You can set up the answering machine if the voicemail was deactivated by Lifeline (page 38 in manual shows how to set up answering machine). If 4 rings is not enough, you can change the # of rings (page 40) and to use the answering machine/voicemail, see page 42 in manual.
Uniden 6035 1 Owner Manual
Nov 03, 2015 | Uniden DECT 6.0 Cordless Phone ID
Uniden cordless phone caller id quit working
Using the Caller ID and Redial Lists
Caller ID (CID) is a service available from your telephone provider that shows the phone number (and sometimes the caller's name) of incoming calls. Contact your telephone provider for more information.
Caller ID list
Redial list
When a call comes in, the phone displays the number and name (if available) of the caller.
The phone saves the information for the last 30 received calls to the
CID list.
When it's in standby, the handset shows how many calls came in since the last time you checked the CID list.
Each handset remembers the last 5 numbers you dialed on it. The redial list is separate for each handset.
Dec 02, 2012 | Uniden Cordless Phone
No caller ID. TP company says I have service.
  • Did you fully charge your phone? - Make sure you fully charge for 16-24 hours .
  • Is the battery old? - Replace the battery.
  • Is the electrical outlet switch turned on? - If you are using AC (electrical) power, make sure that the unit is connected to a non-switched electrical outlet.
  • Are the connecting wires tight - Unplug the AC power converter from the unit and plug it back in.
  • Do you have Caller ID service with your telephone company - In order to receive Caller ID records, you must subscribe to the standard name and number Caller ID service available through your local telephone company. If the Caller ID works for normal calls but not on Call waiting calls, then you must contact your phone company to get the combined CID/CW service.
  • Caller ID shows up after second ring - Be sure to wait until the second ring before answering. Caller ID signals comes through after the first ring, if caller pick ups phone too soon Caller ID signal will not be transmitted to the handset.
  • Confirm that caller ID is still working on that particular line by checking another phone on the same line - If Caller ID is not coming through contact your phone company provider.
If this does not fix your problem, contact your authorized Service Center.*
Oct 16, 2010 | Uniden DECT 6.0 Cordless Phone ID
Caller ID not functioning
i know caller id has to be paid for from the provider! it did anyway. keep experimenting
Jun 01, 2009 | Uniden TRU9460 Phone
Caller ID does not display
CID needs 3 things, a subscription from your phone line provider, a phone to display it, and someone sending it.
If your generic phone is of the single line set variety and it has CID, then check with your provider. If it's a system phone, it may not have the proper equipment installed or not even be available in the phone system. Usually, even if the call is blocked by the sender, you will get a date and time and "unknown caller" or "out of area"
indication when a call comes in.
Carl
May 17, 2009 | Uniden Cordless Phone
On my model 8885 uniden phone, when I try to store a # the screen say's memory full. I only have two numbers stored. help
These phones use a "Shared" memory, the CID information and the Phone book information share the same memory chip. If you clean out the caller ID data you should be able to load more numbers in the phone book. Since you have an 8885 I am assuming you have TCX800 or TCX905 handset(s), to clear the CID memory, Follow these steps:
Deleting Information from the Caller ID List
1) When the phone is in standby mode, view the Caller ID
information to be deleted (see "Viewing the Caller ID
List" on page 50).
2) Press the DELETE soft key. De let e C all er ID appears.
3) Press volume up/down to choose Yes.
4) Press the OK soft key. You will hear a confirmation tone.
To delete all the CID information follow these steps:
Deleting all Caller ID names/numbers
1) When the phone is in standby mode, press cid.
Press the DELETE soft key. De let e A ll? appears.
2) Press volume up/down to choose Y es.
3) Press the OK soft key. You will hear a confirmation tone
Mar 27, 2009 | Uniden 5.8GHz Dual Cordless Phone
Handset#1wont show caller id when the caller id button is pushed
Hardware issue, contact the maker of the phone if it's still under warranty to have them replace or repair it otherwise you might end up paying money for fixing the problem. Sounds like a metal contact is missing, something you can't fix on your own in most cases, even if it's worked in the past. Sorry to hear about your trouble, hope I helped out!
Mar 19, 2009 | Uniden 5.8GHz Cordless Phone
Uniden CXA15198 not showing caller id
Hi! There is a small device available in the market which is a converter. By connecting this between landline and phone, caller ID start display simply.
It cost to me Rs.450/- made by Fintel. Try to get it cheaper at your place.
Try this and the problem is solved.
Nrupesh
Apr 08, 2008 | Uniden CXA15198 Twin Corded/Cordless Phone
Caller ID does not work
I FIXED IT!!!  YIPEEE!!
What I did was UNPLUG the base's power unit from the wall... waiting about one minute, and plugged it back in.  That caused it to "reboot" the entire system, and the CID now shows itself.
Mar 06, 2008 | Vtech ia5864 Cordless Phone
Uniden 5.8GHz Dual Cordless Phone Logo
639 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
