Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Starter won't engage
I have 13 volts. I can hear the relays click, but the starter won't engage.
  • fatboy9457 Dec 04, 2008
    clicking and clacking noise when trying to start. solenoid or starter/maybe both? 94 fatboy
Better yet...............even if you have the minimun 12.5 volts on the battery, the amps may not be suffiicent to turn the starter and you will hear a clacking noice. the battery probably needs to be replaced.
Posted on Sep 12, 2008
  • rubenhood Sep 28, 2010
    07 road king is on the right track... but if you hear the relay clicking... replace the relay and your problem is solved... the relay is a very common problem they go out all the time... about 14 bucks plus tax... good luck...
    ruben 92 fatboy
    Genius:
  • 2,028 Answers
Pull the starter, and see if it's engaging off the scoot. Make sure you have it secure, they can get away from you real quick. If it engages off the bike, then I'm going to say that your armature and brushes are worn, and the starter needs rebuilt or replaced. If it still doesn't engage, then it's most likely a bad ground, and you'll to have start tracing wires.
Posted on Sep 04, 2008
You may have a sticking solenoid. While holding the starter button, tap the starter solenoid with a hammer handle or something similar. Solenoid should engage and start engine.
Posted on Sep 16, 2008
    07 roadking is on the right track... but if the ralay is clicking try replacing the started relay, is most likely your problem... it is a very common part that goes bad... its about 14 bucks plus tax.. replace it and you should be riding again... good luck...
    ruben 02 fatboy
2014 Honda Forza will not turn over
Hi, Anonymous before testing any electrical component in the Starting System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand, clutch, neutral safety switch.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter motor or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. Faulty ignition relay.
14. The electric starter is working but starter clutch has failed.
15. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Scooter Troubleshooting Scooter won start All about Scooters
Scooter won start
Honda NSS250 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda NSS250 Owner Manual
Jan 30, 2014 | Honda Forza Motorcycles
1995 Isuzu Rodeo won't start all of a sudden.
Check connection battery,could be starter.
Jun 05, 2013 | Cars & Trucks
Starter wont engage
Hi, Harry before testing any electrical component in the Starter Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries.
8. Faulty kickstand or clutch pull in switch/sensor.
10. Starter relay, solenoid or starter circuit wiring faulty.
13. The electric starter is working but starter clutch has failed.
14. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Re Won crank Road Star Forum Yamaha Road Star
Faulty Starter Relay symptoms and fix part no Road Star Warrior Forum...
Yamaha XV16AL Service Manual
OEM parts for Yamaha
YAMAHA XV1600A Owner Manual
May 07, 2012 | Yamaha Road Star Silverado Motorcycles
Why won't it crank over?
Sounds like the starter. The faint click would be the starter solenoid, trying to operate starter. Have it tested.
May 05, 2012 | Cars & Trucks
Need to remove and replace starter on 2003 yamaha roadstar silverado 1600
Hi, Anonymous before testing any electrical component in the Starter Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries.
Roadstar starter problems
What to do When Your Motorcycle Won Start
Yamaha Road Star XV16ARC Owner Manual
Apr 05, 2012 | Yamaha Road Star Silverado Motorcycles
Bike won't start, new Harley battery, and starter bike 2006 FLHX Street Glide, all I get is a clicking noise from solenoid under seat
I'm not too familiar with the later model bikes but if I were getting a clicking noise under the seat and the bike was not starting, I'd investigate the source of the noise. It's possible that it is a starter relay that engages the solenoid that is an integral part of the starter. Look at the starter from the right hand side of your bike. You'll see a single small wire that connects to the end of the starter just above the end plate of the solenoid. Disconnect this wire and connect a test light or volt meter to the wire. Turn on your ignition switch and press the start button. You should hear the click under the seat and see voltage at the end of that wire. If not, replace the relay, a plastic cube about an inch in dimension.
Good Luck
Steve
Jul 02, 2011 | Harley Davidson Storm 50 Motorcycles
Yamaha v star 1100 every time i push starter buttom i hear click in the small box with 2 30 amp fuses but starter do not engaging
first check battery for full charge 12.5 to 14 volts. second corroded battery cables can cause this symptom.third check connections to battery and starter and ground are clean and tight. fourth, click in small box maybe a malfunctioning starter relay- you can ask dealer if your bike has one. last possible starter failure.
Jun 13, 2010 | 2007 Yamaha V Star Custom
Gentlemen, I have a 1979 580c backhoe, proud owner for 3 weeks now. But it won?t start. Here's what I've done so far. 1.checked the starting circuit, the neutral switch is good. 2.I have continuity...
It sounds like you have a bad starter. You can try bringing 12v direct to
the starter just to be sure(be sure it's in neutral) or use a volt meter at
the starter while somone turns the key. You have checked the wire's
and all appears to be ok, the only thing left that would draw the meter
into the red is the starter itself. I hope this helps.
May 23, 2010 | Garden
No start or turn over. Battery registers 13 volts. Stopped for
Its a bad earth between battery and chassis or starter and chassis
Sep 11, 2009 | 1996 Honda VF 750 C Magna
Freelander unable to start at turn of key,
Does the starting solenoid engages? This is would sound like a deep clunk on your starter. When the solenoid engages it close the contact that energize the starter motor, but a worn contact on the solenoid would result in it engaging but not having enough current to turn the engine resulting in a clunking noise when you try to start.
The starter solenoid gets its 12 volt from a relay. This is referred to as the starter relay. If you try to crank, and you hear only a click but the starter do not turn, then the contacts on the relay maybe worn.
To sum it up, if you hear a loud clunk when it dont crank, its the starter solenoid. If you hear just a click but no crank, it could be the starter relay.
Aug 06, 2009 | 2002 Land Rover Freelander
Lands Phones Logo
703 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
