Question about Konica Minolta DiMAGE A1 Digital Camera
What is external battery pack "EBP-100"? - Konica Minolta DiMAGE A1 Digital Camera
    Master:
  • 425 Answers
This is the external battery pack for DiMAGE 7, 7i,7Hi, 5, S414, S404 and S304. This is the type of external battery pack to connect the camera and the battery part with cord. Taking a picture while keeping the battery part only warm in a cold place. As there is a belt loop at the part of battery, it does not bother to capture images. Battery:Two lithium batteries NP-100 Battery performance: Approx. 580 frames(recording), Approx. 580 min(playback) Accessories: Battery Charger BC-100, Lithium ion battery NP-100(2pcs), Battery holder BH-100 Optional: Battery Charger BC100 is sold separately. BC-100 specifications: INPUT: AC100-240V/50-60Hz, OUTPUT: DC8.4V1.1A
Posted on Sep 15, 2005
2 Suggested Answers
SOURCE:
toto
  • 425 Answers
SOURCE: What is the external battery pack "EBP-100"?
This is the external battery pack used for the DiMAGE A1, 7, 7i,7Hi, 5, S414, S404, S304, Z1, Z2 and A2. This is the type of external battery pack that connects the camera and the battery part with a cord. Taking a picture while keeping the battery part only warm in a cold place. As there is a belt loop at the part of battery, it does not bother to capture images. Two lithium batteries NP-100 Approx. 480 frames(recording), Approx.450 min(playback) Battery Charger BC-100, Lithium ion battery NP-100(2pcs), Battery holder BH-100 Battery Charger BC100 is sold separately. INPUT: AC100-240V/50-60Hz, OUTPUT: DC8.4V1.1A
Poloroid spectra 2........Does it have a battery, and how do you get into it???
The battery is included in the film pack. All original film packs now have flat batteries, especially if cold stored. Refrigerated packs with flat batteries can be used if you convert the camera to accept an external 4.5v dc stabilised power supply such as an external battery pack.
New film packs are available from The Impossible Project, but they are not the same material as the original Polaroid ones. The website tells you about the differences in results and product behaviour.
Jun 13, 2011 | Polaroid Spectra 1200si Instant Camera
I have a pavilion dv 7 that shutdow the otherday.The battery was hot and if i turned the pc back on it would run for a couple minutes then shutdown.The charger was also hot. I purchased a new battery and...
There are isues with HP external power supplies - if it is a dv7-3xxx series you require AC Smart adapter (120 watt) - 100-240VAC input, 50-60Hz, 2.5A - 18.5VDC output, 6.5A, Pt No 463953-001
for earlier models require AC Smart power adapter (90 watt) - 100-240VAC input, 47-63Hz - 19.0VDC output, 4.74A, 90 watts, with power factor correction (PFC) 463955-001
If you are within the warranty period utilize that warranty if not contact HP and see what price a replacement external power pack is.
Jun 15, 2010 | HP Computers & Internet
Starter motor horn brake lights not working
Hmmm, don't like to state the obvious .. but it sounds like you have a flat battery? Have you tried bump starting the bike, or use an external booster pack (or jump leads) to get it going?
Sep 26, 2009 | 2004 Skyteam ST 100-2
Battery is dying
Nope - that battery is completely rechargeable. There is a small possibility that the battery could have experienced some small corrosion, but this is a slim possibility. The documentation suggests that this model has an external battery pack, and comes with the following instructions:
Slide the external battery pack cover to open it.
Insert four AA batteries, be careful to observe the correct polarity. Slide the
cover back into place.
Inserting external battery pack
Twist the external battery pack to UNLOCK direction. Insert the H300 to the
system slot of the external battery pack.
May 31, 2008 | iRiver H340 MP3 Player
Focus problems
go to the Konica Minolta customer technical support[now part of Sony] However I doubt an item of this age is repairable due to lack of parts.
Jul 17, 2007 | Konica Minolta DiMAGE 7i Digital Camera
External power battery pack
No. The EBP-100 is not usable, and we cannot guarantee compatibility with any other manufacturer's external battery packs.
Sep 19, 2005 | Konica Minolta DiMAGE E201 Digital Camera
Konica Minolta Lithium-Ion Battery Recommendation (warning against the use of non-genuine or counterfeit batteries)
We have received a number of inquiries regarding the usage of Konica Minolta digital cameras with non-genuine or counterfeit Konica Minolta lithium-ion batteries. Please be advised that genuine Konica Minolta lithium-ion batteries are equipped with security system to prevent the camera from damages. It has been reported that some counterfeit batteries are NOT equipped with a security system. The use of such batteries will cause damage to your Konica Minolta digital camera and may cause fire. Further, every Konica Minolta digital camera has been designed to fulfill its nominal value in performance with a corresponding genuine Konica Minolta lithium-ion battery. For safety and optimum performance, we recommend that you only use genuine Konica Minolta lithium-ion batteries with Konica Minolta digital cameras. Genuine Konica Minolta lithium-ion batteries will include the Konica Minolta model # (NP-200, NP-400, etc) and are only available through authorized Konica Minolta dealers and the Konica Minolta on-line store. Please note that Konica Minolta is not responsible for damages or troubles caused by the use of lithium batteries which are not specified in the instruction manuals or not produced/distributed by Konica Minolta Camera Inc. (Updated 01/29/04) Genuine Konica Minolta lithium-ion batteries are listed below: Konica Lithium-ion Battery DR-LB4 for Konica Digital Revio KD-510Z/410Z/500Z/400Z/310Z Minolta Lithium-ion Battery NP-200 for Minolta DiMAGE Xt/Xi/X Minolta Lithium-ion Battery NP-400 for Minolta DiMAGE A1 Minolta Lithium-ion Battery NP-600 for Minolta DiMAGE G400 Minolta Lithium-ion Battery NP-500 for Minolta DiMAGE G500 Minolta External High-Power Battery EBP-100* is available for the following models: Minolta DiMAGE A1/Z1/7Hi/7i/7/5/S414/S404/S304 * EBP-100 is consisted of 2pcs. Lithium-ion Battery NP-100, 1pc. Battery Holder BH-100, and 1pc. Lithium-ion Battery Charger BC-100
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
We have received a number of inquiries regarding the usage of Konica Minolta digital cameras with non-genuine or counterfeit Konica Minolta lithium-ion batteries. Please be advised that genuine Konica Minolta lithium-ion batteries are equipped with security system to prevent the camera from damages. It has been reported that some counterfeit batteries are NOT equipped with a security system. The use of such batteries will cause damage to your Konica Minolta digital camera and may cause fire. Further, every Konica Minolta digital camera has been designed to fulfill its nominal value in performance with a corresponding genuine Konica Minolta lithium-ion battery. For safety and optimum performance, we recommend that you only use genuine Konica Minolta lithium-ion batteries with Konica Minolta digital cameras. Genuine Konica Minolta lithium-ion batteries will include the Konica Minolta model # (NP-200, NP-400, etc) and are only available through authorized Konica Minolta dealers and the Konica Minolta on-line store. Please note that Konica Minolta is not responsible for damages or troubles caused by the use of lithium batteries which are not specified in the instruction manuals or not produced/distributed by Konica Minolta Camera Inc. (Updated 01/29/04) Genuine Konica Minolta lithium-ion batteries are listed below: Konica Lithium-ion Battery DR-LB4 for Konica Digital Revio KD-510Z/410Z/500Z/400Z/310Z Minolta Lithium-ion Battery NP-200 for Minolta DiMAGE Xt/Xi/X Minolta Lithium-ion Battery NP-400 for Minolta DiMAGE A1 Minolta Lithium-ion Battery NP-600 for Minolta DiMAGE G400 Minolta Lithium-ion Battery NP-500 for Minolta DiMAGE G500 Minolta External High-Power Battery EBP-100* is available for the following models: Minolta DiMAGE A1/Z1/7Hi/7i/7/5/S414/S404/S304 * EBP-100 is consisted of 2pcs. Lithium-ion Battery NP-100, 1pc. Battery Holder BH-100, and 1pc. Lithium-ion Battery Charger BC-100 For further assistance concerning Konica Minolta products, please contact Konica Minolta technical support by phone or Interactive Q&A or visit our website at http://www.konicaminolta.us Thank you for your understanding and cooperation in this matter. We look forward to your continued support for Konica Minolta products.
Sep 15, 2005 | Konica Minolta DiMAGE 5 Digital Camera
Konica Minolta DiMAGE A1 Digital Camera Logo
574 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Damen Wong
Damen Wong
 Larry
Larry
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
