Question about Sony VAIO PCG-F520 Notebook
Video problem i need upgrade existing vga driver vers. 4.0 for standard pci graphics adapter
    Scholar:
  • 81 Answers
You have to go to you computer's manufacturer site and search for the correct drivers for your particular laptop. You should find them on your computer manufatcurer's site. If you do not wish to do that, do the search through Windows Update.
Posted on Sep 04, 2008
My graphics card is not being recognized. Im using a ECS 945P-A Ver: 3.0 motherboard which has no on board video output. im using a Zotac Technology GEforce 7300 GT graphics card too. Do I need a powe
I don't believe that graphic cards of that level need PCI-EX power directly from the power supply (using a power supply cable with a PCI-EX connector). This is a good thing, but that's because this is a low-level card--one that likely needs nVidia legacy drivers: It's likely that active driver support has ended. (The same is true for legacy AMD/ATi cards--and other more ancient cards, as well. ((PCI or AGP) Sabre, 3DFX, etc.)
If you're using the VGA port--perhaps the card's DVI port is needed for initial install, instead--or vice-versa. (You'd need an adapter or different cord to run to a VGA monitor or TV's VGA port .)
Rarely, two VGA ports might exist on a card, instead. In any case, the port needed likely isn't the one connected (with a ribbon cable) to the PCB on the video card. (Once you get a workable video card driver installed, then you should be able to use either port.) Try all usable ports before finding another possible solution....
Apr 05, 2014 | ECS 945p-a Intel 945p Socket 775 Atx Mb...
IBM intellistation Harware Malfunction Call Your Hardware Vendor
Try opening the case and removing any installed PCI cards one by one and testing whether the problem is still present after each card is removed.
If you have a built-in VGA adapter on the motherboard and a separate graphics card, then connect your monitor to the built-in adapter when removing the graphics card.
If the problem remains after all expansion cards are removed, then the fault most likely lays with the motherboard and you may need to buy and install a new one.
Depending on the age of the current motherboard, you may be able to re-use the existing processor and memory if you can get a replacement which takes the same types (processor socket type and memory standard (DDR, DDR2, DDR3 etc)).
If you go for an upgrade motherboard and processor, then you may also need to upgrade the power supply - check the minimum power requirements of the new motherboard against the power outlet capacity of your existing supply.
Dec 23, 2011 | Computers & Internet
I have a 2000 dell computer with win98 oper sys. The current graphic driver that is in their is standard PCI Graphic adapter vga. I need graphic up grade driver for win98 can you help me? Thanks Phil
Access the manufacturer's web-site: http://support.dell.com
Enter the model-number of your Dell computer, and do the search.
See if the device-drivers for "video" for "Windows 98" are still available.
By the way, is it an add-in PCI video-card? If so, what manufacturer? What model?
Device-drivers are _very_ specific to the video hardware.
Jul 14, 2011 | Dell Computers & Internet
No network driver after reformatting the system.....window 7 ultimate....no PCI Simple Communication Controller....no Standard VGA Graphic Adapter.....
If this is the original operating system you can download the drivers at the hp support website.
Just type in your model number (can be found on a white sticker on the bottom of your laptop).
The pci simple communications controller is the phone modem.
And the vga graphic adapter is your video or video card.
http://www8.hp.com/us/en/support-drivers.html
Jun 16, 2011 | HP Computers & Internet
I WANT TO UPGRADE THE GRAPHIC CARD ALSO THE RAM CAN YOU PLEASE TELL WHICH GRAPHIC CARD AND RAM WILL WORK ON MY MOTHERBOARD? Model Name : 8LD533 M/B Rev : 1.X BIOS Ver : 6.00 PG Serial No. :...
  1. Memory Type:DDR266( PC2100) 184 pin (2.5v)
  2. 2 x DIMM
  3. Max capacity: Up to 2 GB
Expansion Slots
  1. 3 x PCI (PCI 2.2 compliant)
  2. You can only used PCI graphic card not PCIE Graphic card
  3. PCI graphic card is hard to find now but you can try to find at any computer surplus shop
May 22, 2011 | Intel Motherboard
I want to install a graphics card since I updated to windows 7 (which won't allow me to use some programs because it requires a video card). Right now it has a standard VGA graphics adapter but I wanted to...
that's easy, but you never said what "some programs" are
(infinite possibles and high end games worse)
or CAD/CAM or other 3D engineering and rendering progs.?
or top flight, Video Editing? omg.
but if you open said PC and see that mother board
you will see slots, the largest slot is the one
called PCI-e (express)
this PC came with ONBOARD
  • integrated
  • Graphics Processor Intel Extreme Graphics shared video memory (UMA)
the PC is a very old and low performance model.
this old PC has no express slots.
most cards sold now do not use PCI now, only PCI-E
express x16
your computer so old , it does not have AGP slot.
so is a relic.
but there are a few remaining companies that still make them.
even used PCI only VGA cards are hard to find, '
those slots are very slow as is all things there.
and will not ever run fast like a modern MOBO would do !
here is one, but I cant promise your unstated Prog will like it.
https://www.newegg.com/Product/Product.aspx?Item=9SIACUE5MM1048
No AGP , NO PCI-Express slots at all. just old PCI (x 3)
It runs 32 times slower that slot than any modern PC (express)
1220-q3ynongdx4nnghasmode251e-1-0.jpg do not expect something this old to run modern bloated apps well.
it wont. nor will it ever.
Nov 03, 2017 | HP Compaq Presario SR1220NX (PJ517AAR) PC...
What dual video card is compatible with the M52?
The 256MB ATI Radeon HD 2400 XT Dual-VGA or Dual-DVI, TV-Out Graphics Card (43R1962)
The 128MB ATI RADEON X300 VGA, VGA PCI-e Dual Head Graphics Adapter (40Y8405)
The 64MB NVIDIA GeForce 6200 VGA PCI-e Dual Head ThinkCentre Graphics Adapter (73P2517)
The 256MB ATI Radeon X1300 Dual-VGA or Dual-DVI, TV-out PCI-Express Graphics Adapter (41U5028)
The 128MB ATI RADEON X300SE Dual-VGA or Dual-DVI Dual Head ThinkCentre and Lenovo PCI-e graphics adapter (41U4813)
The 128MB ATI RADEON X700 VGA, DVI-I, TV-Out PCI-e Dual Head ThinkCentre Graphics Adapter (73P2518)
All above are compatible with the ThinkCentre M52. Hope this helps, Best Regards, - md
Nov 10, 2009 | IBM ThinkCentre M52 8113 - P4 551 3.4 GHz...
Problem with Standard VGA Graphics Adapter
You need to install the drivers for the graphics card that you have. Search for the drivers on toshibas website.
Jun 24, 2009 | Toshiba VGA Board Graphic Card
Upgrade the existing graphics card. GEForce 4 MX440
Yes you can upgrade the card. For information regarding video card refer to website belwo
You can purchase teh AGP video card for the computer with higher memory.
Currently your video card is with 64Mb, try for 512MB or higher version. Do not go for PCI Express or PCI video card. The computer will support only AGP.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=318&SRCCODE=LINKSHARE&cm_mmc_o=-ddCjC1bELltzywCjC-d2CjCdwwp&AffiliateID=X3Th4gZi_iQ-O1wyxfEWrT9eDYy9TsHWNA
Apr 14, 2009 | Computers & Internet
Open Questions:
Official Toshiba Support ' Toshiba Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Virus like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Apr 19, 2018 | Toshiba Computers & Internet
See all Sony VAIO PCG-F520 Notebook Questions
Sony VAIO PCG-F520 Notebook Logo
69 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
