TEN blinks - Check for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, "D" board.
High voltage in TV got problem and that's why TV gives 10 time blink error code.
Qualified TV tech will fix it as its bit complicated fix.
Parts are available but problem of High Voltage Protection (10 times blink) requires high expertise and experience of TV repair.
You must know how to test transistors, resistors using the multimeter if you are going to DIY.
If you don't have necessary tools and test instrument and can't
troubleshoot the unit yourself, I would advice you to seek for an
assistance of a qualified TV Technician to isolate the above faulty
parts.
Parts are available in http://www.partstore.com/CustomContent/PSTOR_ECO/CustomError.htm#PartsearchSKUList
Hope I helped you.
Thanks for using Fixya.
