Question about Konica Minolta DiMAGE A1 Digital Camera
Can I use the battery charger BC-400 overseas?
    Master:
  • 425 Answers
No, you cannot. This is due, not only to the shape of the plug, but also to the fact that the AC cable for BC-400 do not comply with overseas regulations. Though the label on BC-400 indicates the voltage rating (100-240V), the durability of the power cord for each type of BC-400 differs respectively. Minolta has no responsibility for any damage or loss incurred by use of AC adapter or BC-400 not warranted in the region. The mentioned electric cords may not be inseted to the power receptacle. In this case please obtain the transform adaptor at the local dealers. (Please be noted that especially in China there are 5 or 6 types of plug .) Warning: Please be careful when pulling in/out the cord from the power receptacle for the electric shock prevention.
Posted on Sep 15, 2005
I would like a new charger Ryobi bc-1807t charger and 2 batteries. or a repair to my charger
home depot -lowes -most hardware stores--go online to buy the replacement for repair do a search for tool repair store in your area but might be cheaper to do replacement
Sep 09, 2016 | Ryobi Drills
Battery charging
Depends on how much the battery is in use, and how much battery life is left.
If it's relatively new (3 years old) and fully empty, it could be full by 2 hours - 2 h 30 min. If it gets really hot before that time, it's full by then.
Mar 06, 2014 | Konica Minolta Dynax 5D / Maxxum 5D...
Bosch charger not charging
Its sounds simple but always worth a try, clean all the contacts on the charger, one will read the condition of the battery, If this is dirty, it may not be giving a strong enough signal to the charger and as such it will interpret the battery as faulty.
Dec 06, 2013 | Drills
Can the BC-NH01 battery charger also charge AAA
In reality, yes. The AAA batteries are to short for the charger, so some fiddling is required. I'd recommend you buy a suitable multicharger instead.
Apr 13, 2010 | Fuji FinePix E550 Digital Camera
Cannot find my instruction manual. can you charge the battery on the computer using the usb cable?
No, the battery cannot be charged using the USB cable. You need the supplied battery charger. If you've lost it, you'll have to buy a BC-CSK or BC-CSKA charger from Sony.
Jan 13, 2010 | Sony Cyber-shot DSC-W180 Digital Camera
Using battery charger overseas
it's alway suggested that you simply use plug adaptors to change shape of plugs for overseas-do not reduce voltage since most all chargers including yours support 220 or 110
Jun 07, 2008 | Cameras
What is BP-400?
BP-400 is a exclusive external power battery pack for DiMAGE A1 and A2. It can be attached to the body and has portability and movability. It is very convenient for the customers who want to use AA size battery or take a long time picture. One or two exclusive lithium-ion battery NP-400 can be attached. 6 AA batteries; Ni-MH and Alkaline battery can be used. (Nickel dry battery and lithium battery cannot be used. Recording: Approx. 560 frames,continuous playback: Approx. 480 min.(2 pcs. NP-400 batteries) Recording: Approx. 290 frames,continuous playback: Approx. 270 min.(6pcs. 2100mAh Ni-MH batteries) Recording: Approx. 80 frames, continuous playback: Approx. 80 min. (6pcs. Alkaline-manganese batteries) Standard Accessory: Holding Strap HS-2 Optional Accessories: Dedicated lithium-ion battery (NP-400), battery charger (BC-400) INPUT: AC100-240V/50-60Hz, OUTPUT: DC8.4V 700mA
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
Charging battaries oversea.
The battery chargers that are included with JVC camcorders sold in the U.S. are designed to operate on power from 110 to 240 Volts at 50 or 60 Cycles AC. All that is needed to use the battery charger overseas is a plug adapter to connect into a foreign electrical outlet. These are generally available from a store which carries electrical supplies.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Overseas Use
The operating voltage of the AC Adapter Kit/Compact Power Adapter/Battery Charger is 100V - 240V and conforms with international standards. Voltage may be unstable in some countries/regions. Please take care when using the device. The shape of the plug varies depending on the country/region. Make sure the conversion plug adapter is the right shape for your location.
Sep 04, 2005 | Canon GL2 Mini DV Digital Camcorder
Overseas Use
Yes. The power supplies and battery chargers supplied with all Powershot Digital Cameras are designed to work on input voltages from 100-240 volts (50/60 Hz). The only item that you may need is a plug adapter that allows you to plug the U.S. type power supply or battery charger into the foreign type wall outlet. Plug adapters should be easily available at a local electronics store.
Aug 31, 2005 | Canon PowerShot S10 Digital Camera
Konica Minolta DiMAGE A1 Digital Camera Logo
144 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Damen Wong
Damen Wong
 Larry
Larry
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
