Re: I for got my password to get pass the initial screen....
If the problem is with your windows password, i suggest you try using this unlocker. I've used it dozens of times without problems, the website is : www.password-reset.com
Ensure the device is powered off.
Press and hold the Volume Down button then press and hold the Power button.
When the System recovery screen is displayed, release both buttons.
From the System recovery screen, select Factory data reset.
Note Utilize the Volume buttons to highlight and the Power button to select.
Select Yes to confirm.
Note Allow several minutes for the reboot process to complete.
Note To set up the device after completing the factory data reset, refer to Initial Activation and Setup.
There isn't one! If you need to reset it do the following. Turn off your Epson WF-3640 using the power button.
After it's off Press and hold the " # " button on the number pad of the printer and then while holding down the "#" button press and hold the "Power" button at the same time. This will turn on the printer and you'll see a list of items on the LCD screen. Use the number "3" or "6" to move and highlight the "Password Initialization" option. Once highlighted hit the "Color" start button on the pad (below the Stop button). to initialize password reset. Once that is done a confirmation message will show up on the screen to confirm you want a password reset. select the "Stop" button on the panel to confirm it as "Yes". This will then give you a confirmation message that the password has been reinitialized. Once you get the confirmation message just turn off the printer using the power button. This will remove any password set on the printer and will give you access to all ADmin options within the printer.
Hope it helps you!
If you have forgotten your pass code them you need to go to the Xbox 360 Dashboard, go to the system area, then to family settings, then console control and enter an INCORRECT pass code. You will be informed that your password is incorrect and there should be an option to reset your pass code. Press that and you will then have to answer your passcode question. If you answer this correctly then you will be able to set another pass code.
If you have forgotten the answer to your question then you will have to contact Xbox Customer Support im afraid. Hope this helps!
To change the password on the router you'll need to login into it using the userid/password you initially setup, if you don't remember what those are you can always reset the router back to the factory settings via the reset button on the back of the router.
Best you can do, is remove it and logon and reset a password, this time back-it-up!
Download this program and burn to a CD & boot off it, then follow simple instructions, you remove password, & reboot & logon without one..
You can get a Password Reset disc download and burn to CD. Copy/paste the address below, into your address bar of your browser. http://pogostick.net/~pnh/ntpasswd/cd080802.zip Download this file and burn it to CD. Put into drive and turn on PC, and boot from the CD. Follow instructions, choose the correct USER. & BLANK the password. make sure you say OK to write the data, and reboot. The logon password will now be reset blank.
Hello. The phone password (unless you changed it at one point) is most often just the last 4 numbers of your phone number or SSN. Please try that. Once you have passed that screen you may reset to a different code again.
If that is not it, you should be able to take it to your mobile phone store and have them reset for you, but any contacts may be lost, etc. Phones are set this way to prevent an easy reset and use on lost phones, so there is no other "easy" way to do this without accidentally disabling or wiping the phone setup/activation.
Boot your pc into safe mode, usually F10 as the pc power on, Go into the Control Panel, then users and you should be able to delete your account's password from the user's manauel.
In the setup menu goto Clock/System goto the bottom till you see factory reset then select that. The DVD player will restart in the initial setup mode.
If you forgot your password you can do the following:
Press and hold the [|<<] and the [||] buttons one the unit the also press and hold the eject button until initialized disappears from the screen. Turn the unit off and on again, all your settings will be reset to the original.
