Question about GE WSXH208A Front Load Washer
Ge top loading washer
Washer does spin and removes water from clothes but does not agitate at all. seems the front comes off to access parts but don't know how to remove front. Thanks Danny
There are two spring tabs between the front cover and top lid of the machine.. i used a small screwdriver and stiff puddy knife. you have to push in the tab and then lift up..pins will stay in the lid... slide out of the front panel
Posted on Nov 11, 2008
Kenmore Series 70 Washing Machine - won't drain water
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope this may help;
DON'T FORGET TO RATE:
Aug 10, 2008 | Washing Machines
Hi, The water comes into the load, but then their
the agitator shaft could be stripped out. does it sound like the motor is working during the wash cycle or is it just idle? This is a common problem with ge washers the agitator strips out on the transmision and needs to be replaced.
Jan 02, 2010 | GE WJSR2070B Top Load Washer
Ge top load washer will not agitate
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Good Luck!!
Sep 12, 2009 | GE WBSR3140DW Top Load Washer
Washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Mar 29, 2009 | GE Profile WPRE6100G Top Load Washer
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
Ge washer
Pull up sharply on the agitator to remove it from the shaft. Check the agitator mounting cup underneath it is probably stripped out. It is a replaceable part.
If the agitator is difficult to pull up,use a old strong leather belt under the agitator and pull it off using the belt.
Jan 11, 2009 | General Electric WHDSR316G Top Load Washer
Wprb8050d0ww does not drain, clothes very wet
eric it seams that its draining ok?thats important.must happen in a certin time frame to get clothes dry.also this thought comes to me check between the tubs with your hand thru the top.if clothing got there it couldnt spin well.but as a repairman i have replaced more ge motors than boards.god bless i hope that helps
Jan 03, 2009 | GE WPRB8050D Top Load Washer
GE TOP LOAD WASHER DOES NOT AGITATE OR SPIN
ck lid switch can be acessed by pressing clips at front edge of front anel and pulling panel off
Nov 20, 2008 | GE WWSE5200B Top Load Washer
Whirlpool Duet Front Load Washer
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
It's slow to fill
It's overfilling
It's underfilling
Hope this may help;
Aug 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GE WSXH208A Front Load Washer Logo
85 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
