Kenmore 22422 Top Load Washer Logo
Posted on Sep 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I think it is the same proble as you discribe
My kenmore Heavy Duty 70 deries Extra Capacity Model 110. 92573200 doesn't drain, but i had some problem before hand. The lid switch wasn't working right so i put paper into the where the lid switch goes and worked ok for while. Now, i start my load and found water wasn't drain and timer doesn't work when the time click reach drain point. Is it because i had the lid switch problem? or just drain problem?
  • Anonymous Dec 29, 2008
    same problem
  • mfmwe Mar 27, 2009
    I have the same problem, but my lid switch works
Anonymous
Level 2:
  • Expert 116 Answers
  • Posted on Sep 07, 2008
Anonymous
Expert
Level 2:
Answers
116
Questions
0
Helped
54885
Points
249
Hey chiki76
You still have a lid switch problem. The switch has to be replaced. The switch usually comes apart or the clips securing them are broken
regards
Pressure switch broke off-need help fixing
Sears.com
Parts direct
Look it up by model number
Then part discription
And they will send you the part for a fee
Mar 18, 2010 • Dryers
1helpful
Kenmore heavy duty 70 series model 110-8237012
probably your drain pump leaking it has a seal right where it attaches to motor,,,,mine is leaking there but haven't replaced it yet! lol
Kenmore Heavy Duty 70 Series Leaking in the back
If you bought a new washer and you still have a leak, i guess it was not the washer but where it drains into. Sink or stand pipe has a leak. unless you are useing the old drain hose from your old washer. Dry up everything and look for the sorse of water with a bright light when the washer drains .
10helpful
3answers
How many cubic feet are in the Kenmore Washer Model 110 80 series
The cubic feet of the Kenmore washer model 110 heavy duty is 2.8 cubic feet. Measured to the top water line 14.5 inches and using the radius of the tub of 10.375 inches.
I have a kenmore heavy duty 70 series extra capacity plus. it's leaking water under the washer.How do i fix it?
This assumes that you have a basic Kenmore / Whirlpool top load, directdrive, neutral drain (it doesn't spin until the pump removes most ofthe water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Seethe Sears site sub-components for the agitator, basket and tub. It'spossible that one of the gaskets or seals has worn over time.
I'd also pull off the cabinet and check the hoses leading to and from the pump. It's also possible that the pump is leaking.
See the following for how to remove the cabinet.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Washer won't drain
Dear cbringer,
I have the same washer. I have had the same problem with it. It's the timer module. You can get additional help from http://www.repairclinic.com.
Hope This Helps,
Jay
2answers
Kenmore, heavy duty dryer, 70 series extra capacity, not heating
The following link explains how to diagnose a dryer "no heat" problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
If you require addtional assistance, please let me know. I hope this helps you diagnose your problem.
Alexander
vince
