Question about HP Photosmart 3210 Printer
HP 3210 All in One Printer Lid
Hi there I cannot close my printer lid, it is stuck. Is there a trick???
Carefully and I mean carefully spray some WD-40 into the elbows of the hinges. Carefully work the lid down and up until it is . Do not overspray into scanning area. Cover with a towel if necessary.
Posted on Mar 27, 2011
How do I replace color cartridge in HP 7410 all in one
Hi
open the printer lid (with power on) and wait for the cartridges to move into 'change position'. Then remove/replace cartridge(s) and close the lid.
Sep 18, 2014 | HP OfficeJet 7410 All-In-One InkJet...
The deck lid is in the up position and won't go flat. it was raised to add ink.
Look for a leg that's holding the lid in the open position. You'll have to press it to allow the leg to slide, and the lid come down.
Best regards,
--W/D--
Jan 22, 2011 | HP Photosmart 3210 Printer
Hp photosmart 3210 says carriage jam but there is none
Try turning the printer off, opening the lid and if you can either grab the carridge or it's drive belt, move it all the way to the far (right hand) end and close the lid. power it up. The action of the printer re-setting the carridge position should make it either free whatever debris may be jamming it or simply sort itself - out. If the carridge moves very freely, the drive belt/gearbox may be damaged.
If this doesn't help, it may be time to look for a new printer ?
hope this helps.
Jan 13, 2011 | HP Photosmart 3210 Printer
The plastic hinge on the cover of my HP 3210 printer cover is broken and a nearby electrical connector has been disconnected. can you fix the problem or suggest someone who can.
Me 2 I was changing a the yellow cartridge and try to close the lid and POW the hinge on the right side broke. I got the printer opened and had to disconnect three ribbon cables the 3.5 mm jack and one 6 pin connector plug.
Apr 28, 2010 | HP Photosmart 3210 Printer
After installing re-filled ink cartridges, both color and back & white, the printer message that shows ink level still shows low level ink? How do we resolve?
Try this procedure:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
Printer lid wont shut
Make sure you have successfully seated the cartridges you replaced. They may be preventing the lid from closing.
Dec 19, 2009 | HP Photosmart 3310 Printer
I cant close the lid of my
Same thing happened to my printer last night (never happened before) and I too am looking for some release latch....so frustrating and I don't want to force it closed...
Nov 10, 2009 | HP Photosmart 3310 Printer
3210xi printer top lid will not close
i have the same problem, this model it's totally trash!!
Oct 22, 2009 | HP Photosmart 3210 All-In-One InkJet...
Top of printer is stuck in the open position showing cartridges
i had the same problem: the acess cover was locked in the open position. i disassembled the whole lot including hinges( not a good advice). try some silicone spray( no mineral oil, but maybe cooking oil) directly into the hinge and bring some movement into the lid. there are no gears or latches that can lock the hinges.
Jul 18, 2009 | HP Photosmart 3210 Printer
My printer keeps saying Cover Open and won't let me do anything else
Hi All printers have a protruding piece of plastic on the cover / lid, when out of place it tells the printer the cover is open
When you close lid it is inserted into main frame which tells the printer that the lid is closed.
Look for this it may be damaged. If so roll a small piece of paper and insert ito the recepticle hole.
It will trick printer that the lid is now closed.
You will need to remove it each time you need to change inks etc...
Good Luck!
Tinteiros (Ebay)
Jun 02, 2008 | Lexmark Office Equipment & Supplies
HP Photosmart 3210 Printer Logo
150 people viewed this question
Seeker5211
Seeker5211
