Question about Dell Inspiron B120 Notebook
How to turn on wireless internet
Without plugging a usb
  • 3 Answers
Well I don't think the stock B120s come with built in wireless by default, mine didn't
Posted on Jan 03, 2009
    Genius:
  • 2,028 Answers
I don't follow you on "without plugging a usb" so I'm going to give you some advice, if I'm wring or have the wrong machine, please correct me, before you rate me.
I believe this machine has a built in wireless card. If so, then you need to follow the link below and download the wireless drivers for it. If the wireless drivers are already there, then you need to uninstall them and reboot the machine. The machine will find the wireless card and reinstall the drivers automatically. Many time this type of problem is a driver glitch, and this procedure will fix it. If it doesn't have an internal wireless card installed in it, it does have the slot and you can purchase one to go in it. Here's the link for the Inspiron B130 wireless drivers. You'll find the wireless drivers in the network section, and you may have to try more than one if you don't know the make and model of the wireless card.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INSPIRON1300/B130&os=WW1&osl=en&catid=&impid=
Posted on Sep 06, 2008
Magic Jack Plus worked in USB and then Internet on computer stopped working
It's got the wrong gateway setting. Without a gateway (router) to the Internet it can only see local network stuff. I suspect the Magic Jack is still trying to be the gateway but it has no Internet. Stop Magic Jack doing this and it should work.
Feb 27, 2015 | Computers & Internet
Motorola SBG6580
Open Device Manager and set the wireless adapter Power tab to not turn off to save energy. Or modify Sleep mode to not turn off wireless adapters and USB devices. USB if you use a USB wireless adapter.
Jan 29, 2018 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
Hello My WNA3100 Wireless adapter keeps dropping my connection about every 4-10 minutes and the solution is to unplug the adapter and plug it back in. This has become more than a slight annoyance and
desktop or laptop computer ?
try moving your computer to a different area to gain maximum frequency / range
Click start control panel network and internet look for wireless
"Allow the wireless LAN radio to be turned off when inactive" might be ticked untick it
Right-click the wireless icon in the lower right corner of the desktop.
From the pop-up menu select "Enable."
This activates the wireless Internet options but it does not turn on the wireless receiver.
Push down on the wireless button or wireless switch on the top of the keyboard.
After a moments time the switch or button lights up, signifying the computer is ready for an Internet connection.
click start Control Panel - Network Connections - right click on 'Wireless connection'
(or similar) and click 'enable'.
if this fails to fix the problem
try unplugging the usb wireless device
uninstall the netgear software in the add/remove programs in the control panel reboot and then reinstall the software then plug in the usb wireless adapter
hope this helps
Oct 04, 2012 | NetGear WirelessN 300 USB Adapter WNA3100
I am trying to connect a wrt150n wireless linksys router to my dsl. I am using a desktop windows 7 and laptop windows vista. Please help, I have tried everything but it just does not want to work.
unplug everything, including ethernet cables. then work in this exact order.
if you get a wireless signal and no internet, plug a computer in into the router in one of the available ports and check for internet. If no internet, unplug everything and test the modem without the router. If internet available without the router, then follow these instructions
  1. plug phone line into modem
  2. plug power into modem
  3. wait for all lights to become steady
  4. plug ethernet cable into modem
  5. plug other end of same cable into port labled "internet"
  6. wait for lights to become constant on both router and modem
  7. check your wireless device for wireless service.
if you dont get a wireless signal at all, plug your device into the rear of the router and type 192.168.1.1 in the adress bar
the password and username are both "admin" or simply leave the password blank if that doesn't work
navigate to the wireless option and turn on the wireless transmiter.
GOOD LUCK AND PLS RATE THIS POST!!!!!!
Dec 01, 2010 | Linksys Wireless-N WRT150N Router
Can not connect without resetting router each time from base
try and update the wireless G's firmware....
it should solve your problem....
Jan 28, 2009 | Linksys Wireless-G WRT54GS Router...
Usb adapter
if the router is already set up the usb dongle software will need to be used to connect to the router to allow a connection without the need for a cable as the dongle will see the wireless signal
Aug 31, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Wireless USB Adapter not wanting to open.
Hi This problem usually happens when the usb adapter as been plugged in before the software as been installed, try uninstalling the software restart your computer then reinstall your software, once finished close computer down plug adapter into usb port then re-start the computer hopefully this will work and you can configure the wireless settings via Netgear Network.
Aug 07, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Belkin G+ Wireless USB Adapter
What OS (Operating System) are you using??
If it's Windows 2000, XP, Vista or 7, then they MUST have any USB device plugged into the SAME USB port, or it screws up the OS.
Try going to Control Panel (Classic View), then choose SYSTEM to get into Device Manager, go down to USB and see if ANY Belkin adapters are listed (assuming the USB adapter IS Plugged In) - if you see any listed, double-click the adapters and choose to uninstall then.
If that doesn't work, then reboot, pressing F8 repeatedly before the Windows "Splash Screen" shows up. After repeatedly pressing F8 on Boot Up, you should select SAFE MODE (just the choice that only says SAFE MODE). Once SAFE MODE comes up, open Device Manager the same way you did before, then go down again to USB and Delete ANY & ALL Belkin USB adapters listed.
Then reboot and see it it recognizes the Belkin USB adapter now and hopefully will let you setup it's Software.
If you like this, please RATE me .... Thanks
May 18, 2008 | Belkin F5D7010TTSN-W WIRELESS 802.11G...
WIRELESS MODEM
Pcg U1 doesnt have wireless card. But is has PC card slot. You can buy a PCMCIA wireless card or USB wireless to get access to wireless internet access or PCMCIA modem if you use a modem to access the internet.
I hope this help
Jan 25, 2008 | Sony VAIO PCG-U1 Notebook
Dell Inspiron B120 Notebook Logo
525 people viewed this question
Alun Cox
