Question about RCA F32649 32" TV
RCA F32649 32" guide plus TV
I shut my TV off lastnight and the TV worked fine. I went to turn it on this afternoon and all it did was "click" like it usually did when it turns on, however this time it did not turn on. I tried again and all it did was click a few times. Now when pressing the "on" button the TV doesn't respond at all. Any suggestions? Thanks,
Mike
  • Anonymous Sep 26, 2008
    Same thing happened to me when I returned home this evening! Despite the reviews I have seen on the web, this tv has been workhorse for the last 7 years, oh well I've been dying to get a plasma or lcd panel, and I just about have enough in the TV fund. Time to go shopping!
    Champion:
  • 252 Answers
You need to check the fuse ,maybe it's busted.
Posted on Oct 31, 2008
I have an 2001 RCA TV model F31317 it has a Guide plus. Is there a way to turn off the guide plus? I have went through the programing and can't find anything in the menu to suggest a way to turn it off. My...
You can disable this only by going into the Guide Plus+ menu. If you have the original remote or one that matches the feature, press Guide then Menu (sometimes you need to hold this for a few seconds), navigate to Setup (right arrow until it is highlighted). OK, Menu or the down arrow all let you enter the menu. Then use the up/down arrows to select Review Options. Select Off (only two choices). Press OK and exit the guide.
I hope this helps.
Oct 02, 2010 | RCA Televison & Video
Lastnight my family and I went fro a drive all was
Sounds like your alternator is bad and drained your battery. Try recharging your battery and putting a new alternator on it.
Sep 23, 2009 | 1999 Ford Expedition
No light, sound nor green button
maybe a lizard is die inside and shock your power supply circuit
Jul 01, 2009 | RCA 36F530T 36" TV
RCS HD Guide Plus TV
The condition of your TV called power supply overcurrent shutdown that's why you can hear a click sound. The TV is going into a protection mode to prevent further circuit damage. That's why it will not turn on or not powering up. I would concentrate on the power supply section board. Bad regulation of the incoming voltage could caused this issue although,there is a capacitor across the incoming line and nuetral.Maybe its leak or dry up and cause the problems,change it out with one of identical rating .I would probably also check the flyback circuit and flyback transformer although now you are getting into dangerous area,especially if you have no electronic experience background. It could be also be a loose ,crack or cold solder joint,a blown fuse,fusible links or other component .It could be one of several boards.Unfortunately the level of sophistication on these TV make it virtually impossible to diagnose them further without taking them apart and probing around with a multimeter and other tools.This TV is handy enough to take to a repair shop find a good one.You will probably have to pay $75 to $100....
Hope this may help you..
Regards,
VOTIT
DON'T FORGET TO RATE
Sep 03, 2008 | RCA L32HD31 32 in. LCD HDTV
RCA tv with guide plus comes on and off randomly
these tv's are bad for caps in power supply, fluctuations freaking your micro.
Aug 19, 2008 | RCA F36668 36" TV
Help me remove the Guide Plus Grid on my RCA television
Simply enter 00000 for the zip code and complete the set up process; if you're in Canada, select the USA as your country and use the zip. However, you MUST complete the set up, including allowing the TV to search for appropriate code. In the long scheme of things, location and codes don't really matter because you won't see the GUIDE again.
Mar 08, 2008 | Televison & Video
RCA TV f27422 TURN OFF THE GUIDE PLUS
Remove your zip code, I had the same problem, when I removed the zip code it went away.
Feb 09, 2008 | RCA F32650 32" TV
Guide plus rca tv how do stop it from coming up when turning on tv
I have a rca tv guide plus that has the back pannel lights on, but is unplugged, what is the problem?
Jan 04, 2008 | Televison & Video
RCA 27" TV Guide Plus
If you have the set off, and the cable plugged into the back of the set for a day or so, the guide plus should come back. It will sometimes take up to 48 hours. If it does not, there is a problem with the set and will require servicing. Good Luck
Oct 15, 2007 | RCA F25649 25" TV
RCA F32649 32" TV Logo
103 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
