Question about HP OfficeJet V40 All-In-One InkJet Printer
Do u have a link for the oficcejet v40 scanner?
Please i need help asap!
  • 234 Answers
Please be specific of the problem you have, even then try this link if it is any help for you:
http://h10025.www1.hp.com/ewfrf/wc/product?product=60630&lc=en&cc=us&dlc=en&submit.y=0&submit.x=0&lang=en&cc=us
Good Luck
Posted on Sep 16, 2008
2000 volvo v40
Below is the master help link provided to go through belt routing diagram:---Timing belt, drive belt, serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all types of car models?
Click the link below: ----
http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
----------This will help. Thanks.
Jan 22, 2012 | 2000 Volvo V40
I am looking for a n installer of HP officejet v40
HP OfficeJet V40 Drivers
Please visit the above link from HP Official Support. Select the Operating System you have on your PC and download the required drivers.
Hope it helps! Good Luck!
CreativeTECH
Feb 22, 2011 | HP OfficeJet V40 All-In-One InkJet Printer
Setting up fax on an officejet v40 printer all in one
Hi There
I have put a PDF files on my website for you to download.
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and print it strait off the website or save it to your PC then print it out.
Click LINK= http://www.4all2sell.com/pdf/HP-v30-v40-v40xi-v45-Manual.pdf
You will need a adobe reader to see this file If you not got an Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Apr 29, 2010 | HP OfficeJet V40 All-In-One InkJet Printer
I LOST MY HP OFFICEJET V40 MANUAL AND GUIDE AN DON'T KNOW HOW TO SET MY SCANER
Hi There
Gave it 10 minutes I just puting file on website for you.
Mar 03, 2010 | HP OfficeJet V40 All-In-One InkJet Printer
I have an HP Office Jet v40. No problems when I
Sannaer glass is dirty: Cleaning the scanner glass and white reference strip Follow the steps below to clean the scanner glass and reference strip: Remove any loose paper debris that may be present.
  1. Carefully clean the white reference strip on the underside of the scanner cover (or top cover) with a clean, lint-free cloth, moistened lightly with isopropyl alcohol. Clean only the white plastic part on the scanner cover.
  2. For those models that have a scanner glass, clean the scanner glass with a lint-free cloth, moistened lightly with glass cleaner. The HP Officejet K series and HP fax 1220 have a scanner opening instead of a scanner glass. Make sure that no debris is in the scanner opening. Use canned air to gently blow dust and debris from the scanner slot.
  3. Replace all removed components and close the unit.
  4. Plug the power cord back in and turn the unit back on.
  5. Make a copy to verify the lines are not present. If lines are still present and there is nothing visible on either the scanner glass or the reference strip, the unit will require service.
Instructions are on this HP link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu50325&lc=en&dlc=en&cc=us&product=60630&rule=30380&lang=en
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 03, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
Officejet v40
Hi
You probably just need the driver for it. You can find all the support you need for your printer at the HP website here, click the link.
http://search.hp.com/query.html?charset=iso-8859-1&lk=1&la=en&nh=10&st=1&rf=0&qs=&hpvc=sitewide&uf=1&qt=HP+Officejet+v40+All-in-One&ocoldqt=Officejet+v40&oc=28083
Hope this helps...
Feb 17, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
The scanner keeps saying that my USB is not plugged in and it is
There is a workaround without messing with drivers. I have the same problem if I use the buttons on the v40 and try to scan. I get the V40 can not connect to the PC message.
Workaround:
Go to Control Panel-->Scanners and Cameras
In there you will find: Hewlett-Packard OfficeJet V40 Scanner
Right click and select Scan. It will then start the scan wizard which will scan your document.
Jan 26, 2008 | Office Equipment & Supplies
HP officeJet V40
I do not believe you can share the scanner across the LAN as the software does not support this.
Windows only supports the sharing of certain hardware such as printers but not scanners, even though that is attached to the printer but uses different drivers and software to work.
Dec 10, 2007 | HP OfficeJet V40 All-In-One InkJet Printer
Scanning to computer
I had the same problem if I use the buttons on the v40 and try to scan. I get the V40 can not connect to the PC message.
Workaround:
Dec 03, 2007 | HP OfficeJet V40 All-In-One InkJet Printer
HP OfficeJet V40 All-In-One InkJet Printer Logo
20 people viewed this question
Ben Johnson
