Question about Hamilton Beach Water Cooler with Storage Cabinet
Hamilton beach 87330 water cooler
My water cooler fan constantly runs. It is suppose to cool and then shut off but it doesn't. Any suggestions??? Hamilton Beach will not help.
  • 2 more comments
  • Braves Sep 04, 2008
    Ours just started doing the same thing. It runs constantly and the blue light on the front is always on.
  • cinbin08 Nov 05, 2008
    Water cooler fan will not shut off. Hamilton Beach 1 year warranty is a joke. Still fighting with them. They want the unit sent back to them in California from Ohio. Not worth the UPS charges!
  • WWJDTime Nov 07, 2008
    I have the same problem and by the looks of it may other people do to. The unit just keeps cooling and cooling. The hot side works fine. I have tried draining the entire unit hot and cold sides. Left it unplugged for 24+ hours. Plugged in and turned on with no difference.
  • Anonymous Jan 08, 2009
    Mine also just runs and runs. It does cool the water, but I just turn off the switch because I am sure the electricity it exerts is astronomical!
5 Suggested Answers
refritech08
  • 149 Answers
SOURCE: Won't Stop Cooling
thermostat is stuck. try buying a water cooler control from a local supply house.
Posted on Apr 24, 2008
buddymcl777
  • 67 Answers
SOURCE: Frig not cooling
The thermostat has become defective or it has lost freon or the compressor has failed.
Unless it is the thermostat, It may not be cost effective to repair so check the cost of a replacement.
Posted on May 09, 2009
SOURCE: Hamilton Beach 87330 water dispenser: no auto shut off
The model 87330 uses two solid state cooler modules (look like little radiators} and two fans, one for each cooler module When you have the unit on cool, make sure that both fans are running, if only one fan is runing the unit never gets cold enough to shut off. If one of the modules is bad its the same story. I took mine apart today, if it was just the little muffin fan I might consider the repair but if anything else is bad, I will junk it out. I disconnected the bad fan and the associated cooling module wires off the control board and am running half cool + hot water, I am not saying to do this, this is what I have done.
Posted on May 14, 2010
SOURCE: Our Hamilton beach water cooler makes a constant
When empty of water remove the back panel and the cooling fins are most likely covered with an inch of dirt! Find an air compressor and blow out the dirt. It worked on mine!
Posted on Feb 19, 2011
Our Hamilton beach water cooler makes a constant noise as it cools the water. The cooler does not shut off once the water is cold. Series #A0370CT.
Feb 15, 2011 | Hamilton Beach Water Cooler with Storage...
Hamilton Beach 87330 hot water problem.
The two round "devices" on the tank are the operational thermostat, and the "safety" overtemp thermostat. It is usually the "operational" thermostat that fails, since it has to cycle a lot and arc internally. It is usually about 120-140 degrees F., and the safety thermostat significantly higher.
Feb 23, 2010 | Hamilton Beach Water Cooler with Storage...
How to clean/repair water cooler
I have a hamilton beach water cooler with storage cabinet # 87330. The cold water is not cold and the cooling light stays on. What is the problem and how can I fix it? Thanks!
Jan 07, 2009 | Hamilton Beach Water Cooler with Storage...
Cold Water not squirting out cold water
To resolve this problem, unplug the dispenser and let it sit for about 24 hours. I had this problem happen to me and I took the unit apart to find out the cause. I discovered that the the water cooling mechanism developed a big chunk of ice inside of it and it basically blocked the flow water. Allowing that ice to melt should resolve this problem. It did for us.
Nov 07, 2008 | Hamilton Beach Water Cooler with Storage...
Hamilton Beach 87330 water cooler
Hello! About 2 weeks ago, the same problem began on my Hamilton Beach water dispenser.
Last week, I called the HB service support, and they told me to do the following reset procedure:
1. Dispense 3 cups from the HOT water side, and also, 3 cups from the COLD water side.
2. Turn BOTH back switches OFF (the ones on the back of the water dispenser).
3. Unplug the dispenser, and LEAVE it unplugged for 24 hours.
4. After 24 hours, turn the back switches ON and plug it in.
5. Leave it on for 4 hours WITHOUT dispensing any water.
...it's been about 12 hours since I've dispensed water again for the first time, and so far, SO GOOD! I'll update if the problems reappear.
Sep 28, 2008 | Hamilton Beach Water Cooler with Storage...
Glen,
We purchaced this water dispencer about 2 years ago, everything was working normal, water heater works fine and the cooler would come on and go off normally,until you dispenced cold water and then the coller would cool down and shut of like it's supposed to.
Afetr a couple of years , one day it started cooling continuously and wouldn't stop, I've just shut the cooler switch off on the back of the unit until i can figure the problem out,unit #(87330).
I believe the problem is in the circuit control board, but with out further testing i can't be sure .
Sep 01, 2008 | Refrigerators
Won't Stop Cooling
Apr 24, 2008 | Hamilton Beach Water Cooler with Storage...
Hamilton Beach Water Cooler with Storage Cabinet Logo
184 people viewed this question
Top Hamilton Beach Water Filters & Coolers Experts
fixits
Level 1 Expert
Dan Webster
Dan Webster
Are you a Hamilton Beach Water Filter and Cooler Expert? Answer questions, earn points and help others
