Question about Vector 995 Radar Detector
It keeps flashing Self Cal 4. I really wanted to try to repair this myself, any suggestions? Is there an internal reset button? Or some combo of the buttons?
  • gburggraf Jan 01, 2009
    keeps beeping sound and say needs service
    Problem Solver:
  • 6 Answers
You will not be able to fix it.
Maybe you want to sell it, I'm interested.
ssilvviu@yahoo.com
Posted on Nov 08, 2008
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
How do I stop the door lock from flashing on my self cleaning oven
Hello Brian Pelletier, thanks for your inquiry!
I understand that you are having issues with your door not locking upon using the self-clean feature. It sounds like a possible issue with your EOC (Electronic Oven Control) or dock latch assembly. I would suggest unplugging your range if possible or flipping you breaker for ten minutes to perform reset. If the light continues to flash you may want to seek assistance from a professional for proper diagnosis and repair. -Matt
Oct 13, 2014 | Frigidaire 30 in. Electric Self-Clean Coil...
Electrolux Icon Oven self cleaning won't start- the lock button keeps flashing. Yes, the racks and rack holders are removed.
Good Afternoon Friend,
I understand that you are having trouble with your Electrolux Icon oven, model# E30SO75ESS, and running the self-clean cycle. I see that the lock button keeps flashing and that you have the racks and rack holders out. I suggest following the steps below to run your self-clean cycle:
    1) Place the rack holders and the racks in your oven.
    2) Reset your appliance, by shutting the power off at your homes circuit breaker, for 3-5 minutes.
    3) Restore power.
    4) Reset the clock, by pressing the "Clock" button then press the number "2". Enter in the time of day, and then press the "Clock" button again.
    5) Start the self-clean cycle with the racks in your range. This is to make your oven recognize that the racks are in the oven.
    6) Take the racks and rack holders out and start the self-clean cycle again.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your oven status has changed successfully.
    -Best Regards-
    WP
May 18, 2014 | Electrolux ICON Designer E30SO75ESS Oven
My Nintendo 64 will reset randomly after playing it for a while. I know for a fact the reset button isn't stuck. I've heard it could be a short in the system, or the AC power supply is bad. Will...
Well you know on how computers will re set them selves when they have an error in the software
so put it this way a N64 internal parts are like a computers pieces but a simple software so when it resets its self it acts like its going to repair its self but this is inpossible so it will just keep on redoing then. error in the software then.
Jul 18, 2011 | Nintendo 64 Console
Need to know how to calibrate dw077 laser
Hold down the ( V ) button while powering the unit on. THe puts the unit in cal mode for the Y axis. Hold down the up button while powering on the unit, this puts it in cal mode for the X axis. that is as far as I have gotten.
Paul
Apr 01, 2011 | Dewalt DW077KD T Self Leveling Rotary...
Vector 940 works for a moment, then flashes ?L03 CAL ?MARKERS
just turn off the sws messages.
it probably recieved a jumbled signal from a "roadworks traffic control unit".that it couldn't understand.
Aug 31, 2009 | Pro RX65 Radar Detector
Olympus OM-4 Shutter Release Button Stuck
  1. First ry to reset the Self Timer lever.
  2. Try to change the aperture.
  3. Try to unscrew the lens
  4. Open the film chamber slightly (just to loosen any lever that has got stuck)
One of these operations would dislodge any normal lever jam. If these fail to solve the problem, take it to a repair shop.
Jan 26, 2009 | Photography
TV won't turn on, flashing red light
This indicates "vertical stop," meaning that the TV's vertical output circuit is not working. A number of thing can cause this: failure of the vertical output IC or related components; bad solder connections to the vertical output IC (a common problem); power supply trouble keeping the vertical circuit from operating (also a frequent cause). Without having the set available, it's impossible to offer any suggestions for you to attempt repairs beyond looking for bad soldering. Other troubleshooting would require the circuit diagram (often available from the internet), tools and experience working on a live chassis. If you really want to keep the set and don't feel up to self-repair, it might be worth getting an estimate from a shop. These Sonys are nice sets.
Jan 23, 2009 | Sony KV-36FS100 36" TV
4 flashing red lights
  1. Make sure that the AV cable is correctly connected to the Xbox 360 console.
  2. Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
  3. If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
  4. If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
site that explains codes:
http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Dec 18, 2007 | Microsoft Xbox 360 Console
Service messge
Same prob here....flashing service mesg...Maybe it is programed to keep the service department profitable.
Oct 13, 2007 | Pro RX65 Radar Detector
Canon A75 won't power on
The only advice I can give is to check for a fusible link close to where the battery cables connect to the PCB. Look for a component with an F prefix eg f1001 or f001. I never desolder the fuse if it's open circuit, I just break a glass type fuse and solder the wire across the surface mount component. Just make sure the fuse wire is the same value as the original.
Jun 15, 2006 | Canon PowerShot A75 Digital Camera
Vector 995 Radar Detector Logo
511 people viewed this question
Top Beltronics Vehicle Parts & Accessories Experts
John Nolan
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Beltronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
