Tv shuts off after 3 seconds
There is a vhs tape stuck
  • rella hoffman Oct 20, 2008
    vcr tape is stuck.when i power up it shuts down after 30 seconds.symphonic sc3813.how can i get the tape out? i know i will need to put a tape back in because the tv wont work without a tape in.
  • 28 Answers
You can eejct the tape manually by manually turning the motor on the right hand side of the VCR. Once you have reach the fully ejected position, try turning on the TV once more. If it still does not work, you might have to clean the mode switch mounted on the PCB, under the VCR mechanism. If it still does not work, the problem is going to need a repairman to fix.
Posted on Sep 18, 2008
5 Suggested Answers
techman
  • 3130 Answers
SOURCE: Stays on for 5 seconds, thinks it has a DVD or VHS tape in
I am afraid the set has a bad or broken tape transport, or better known as a bad tape carriage.
Posted on Jun 20, 2007
wyoed1
  • 211 Answers
SOURCE: TV wont stay on
The vcr carriage was probably damaged ( broken gear or carriage gear, etc ), As for repairing it, it may not be worth it and chances are, you won't find a new carriage for the unit. I have, in the past, disarmed the VCR unit and at least the customer could watch the TV. Thats not possible in every set, but it seems to work in the majority of them. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
SOURCE: TVSC1320 13 in. combo from January 2000 VCR Tape is Stuck
i took mine out with 2 butter knifes. 1 pressing on each side of the tape forcing it outward while pressing eject at the same time
Posted on Mar 20, 2009
  • 4234 Answers
SOURCE: A VHS tape is stuck in my TV/VHS combo unit.
I'm sorry to say that the solution as stated is not correct. This condition usually occurs because of belts that are slipping. In order to remove the tape, some dis-assembly is required. If you have not done this in the past, I would not suggest that you attempt this repair. This repair should cost about $10 in parts plus labor. It is possible that the IR LED is defective as well which can also cause this. This is a common failure and should be a simple repair for any shop.
Dan
Posted on Jun 04, 2010
Testimonial: "This helped also. Don S"
VHS tape will not eject and unit shuts down
It's not loading correctly. You need to open the cover (unplug first) and get familiar with the loading mechanism. You can get the tape out by rotating the loading motor wheel.
Mar 22, 2015 | Magnavox ZV427MG9 DVD Recorder/ VCR
Power off when inserting vhs tape
I had this problem when copying an old family vhs tape. I had to unscrew the top of the magnavox to access the vhs tape. Then, I gently removed the tape and replaced the cover. After winding the tape back, I put it in the player and immediately pushed fast forward for about 3 seconds before hitting play followed by d.dubbing. I was able to make a copy of the tape and did not damage my original.
Jul 30, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
My daughter just had a problem with her Philips tv. It has a built-in vhs player on it, and when she put in a tape, the tv started turning off. I turned it on and got a blue screen that says 't-eject'. I...
It is possible that the Tape mechanism is struck and so is shutting off the power to the unit. Since the power is shared it is possible that the cut off to the set is due to the error in the VHS player.
So in this case you will need to remove the VCR and get the entangled or the stuck up cassette from the player so as to reset the error. Also if there is a mechanical issue to the player must be checked.
Mar 18, 2011 | Televison & Video
Dan
Jun 01, 2010 | Televison & Video
Tape stuck in vhs players
Yes you can cut the tape, remove it and then go to radio shack or walmart electronics dept and get some special vhs repair tape.
Apr 27, 2009 | Sony SLV-D300P DVD Player/VCR
Magnavox 20-inch TV MWC20T6 must have vhs tape in. Knocking.
I think its your electrisity cause if both of them dont work
Jan 15, 2009 | Microsoft Xbox 360 Console
VHS carriage stuck
THERE IS A SENSOR SWITCH THAT TELLS THE MACHINE THE TAPE IS LOADED ... SOUNDS LIKE IT IS STUCK. PROBLEM IS ACCESS WITH COMBO'S. THEY ARE A PAIN TO GET AT. THE WHOLE BACK COVER TO THE TV MOST OF THE TIME HAS TO BE REMOVED,... I KNOW ITS NOT MUCH HELP BUT THE MANUFACTURES KNOW THAT... HOPE YOU CAN GET TO THE TRAY INSIDE. Joe_Rex
May 01, 2007 | Sylvania SRCD227 27 in. TV/DVD Combo
SERIES LXI TV & vhS
I'm guessing the "black thing in side" is referring to the actual tape itself- ribbon like which can be spooled out of the tape case. If so, then your VCR may have a mechanical problem of some sort, which results in a "no tape transport" or "no tape takeup" problem. If the latter, the right reel (takeup reel) is not being driven. Older VCRs often used a small rubber rimmed drive mechanism to drive this reel. Newer VCRs (10 years old or less) pretty much use a gear drive. Something may be broken here, or perhaps the gear is stuck. This gear assembly has to swivel back and forth, from left for rewind, to right for takeup or fast-forward. Unfortunately, you can't see the gear once the tape is in the machine, at least not from the topside. Suggestion: Take the top cover of VCR off, look for this gear, and see if it swivels freely, look for broken gear teeth.
Apr 14, 2007 | Rio Go Video DDV9475 Dual Deck VCR
Televison & Video Logo
396 people viewed this question
Top Televison & Video Experts
