Maxtor Model 32049H2 Slave jumper settings - Computers & Internet
  • 236 Answers
I would guess that it is a diamond max driver, and therefore the jumper setting for slave should be no jumper at all. But in case I am mistaken, here are all the jumper setups for Maxtor drives, choose the one that looks like your setup and then choose the correct Slave setting:
Posted on Sep 04, 2008
What settings in the bios with maxtor as slve and quantom fireball as master
There are no settings in the BIOS for setting up master ans slave drives.
The hard drives have jumpers for configuring master and Slave drives.
If your hard drives are IDE/PATA hard drives and you intend to install these drives on the same IDE cable then you can set the jumper on Quantum drive as Master and the Maxtor on Slave.
I suggest that you install the Quantum as master on the 1st IDE cable and the Maxtor as Master on the 2nd IDE cable for maximum data transfer rate between the two hard drived.
Any other devices that are connected to these IDE cables will need to be jumpered as Slave devices.
Mar 28, 2012 | Gateway Computers & Internet
I have a maxtor hard drive D740X-6L wut is the jumper set for slave
For slave u dnt need any jumper remove hard drive jumper and use reginout for ur registry error
Sep 01, 2010 | Computers & Internet
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
Hi i have a 10.1gb Maxtor model 31024H1 IDE hard drive and i need the jumper setting for slave
slave is NO jumpers at all
(Master) - The vertical jumper over the J50 pins is configuring the drive as a Master. The horizontal jumper over the J48 and J46 pins is in the Storage position.
(Master with CLJ) - The vertical jumper over the J50 pins is configuring the drive as a Master. The vertical jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
(Slave) - No jumper is required to configure the drive as a Slave. The jumpers over the J48, J46, J44 and J42 positions are both in the storage position.
(Slave with CLJ) - The jumper over the J44 and J42 positions is in the storage position. The jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
(Cable Select) - The jumper over the J48 position is configuring the drive for Cable Select. The jumper over the J44 and J42 pins is in the storage position.
(Cable Select with CLJ) - The jumper over the J48 position is configuring the drive for Cable Select. The jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
Oct 13, 2008 | Computers & Internet
Maxtor ata 80g drive jumper settings to slave?
PDF File
Work around, Set both drives to cable select, then the ide channel flat ribbon cable will determine which is master and which is slave.
But to answer your question, no jumpers= slave
Apr 14, 2008 | Computers & Internet
I have a Maxtor Model 54098H8 hard drive. I would like to use it as a slave drive. What are the jumper settings to use it as a slave drive?
To use as slave, it is no jumpers. Take off all jumpers and it could be used as slave.
Thanks,
Lolita
Apr 09, 2008 | Computers & Internet
Computers & Internet Logo
10,581 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
