How Do I reset my Foxconn 661MXPlus Motherboard to its factory Settings?
    Champion:
    Scholar:
  • 209 Answers
It is in the BIOS utility.
Posted on Sep 04, 2008
Could you plz tell me how to totally factory reset my computer as if i just bought it and never installed an app,my motherboard is a foxconn g31mx and i dont have the manual or factory disk
If I understand you right, all you have to do is to unplug the computer and remove the little button cell inside and leave it out overnight. This will wipe the CMOS RAM which contains all the configuration settings.
Dec 08, 2013 | Computers & Internet
What is the one time boot key for the Foxconn 661MXPlus mother board? to enable me the option of which operating system on which hard drive to select? Thankyou
Start your PC. Press Delete button from keyboard,it will open your BIOS setup.
Now go to boot options and select your hard drive to boot.
Hope this will help you.
Thanks for using FixYa.
May 17, 2011 | Foxconn 661FX7MF-S Motherboard
Does the 661MXplus support optional boot up of of hard drives@
yes in cmos but if you do not know how to use cmos do not go there if you have a friend that knows how it and only then ok jim
May 15, 2011 | Foxconn 661FX7MF-S Motherboard
How do I reset on a 865mo1 foxconn motherboard Bios,Do I just take out the battery for an hour, will it need to be reinstalled
Removing the button type battery on the motherboard is the most common way to restore your Bios to the factory default settings, several minutes is sufficient. You will need to reset the date and time but everything else will remain as normal. Take care to discharge any static electricity in your body by touching the chassis (PC case) before touching the motherboard, also remove mains supply, obviously. Hope this helps.
Nov 11, 2010 | Intel Foxconn Motherboard
Computer turns on then shuts off.
Hi there.
Have you tried clearing CMOS? look on the motherboard for the battery, the jumper should be near that and with most motherboards should be marked with "CLR_CMOS" like this >>>>>
If you cannot find the jumper then chances are the board does not have one so to clear the cmos you have to take the motherboard battery out for an hour or so making sure you remove the power cord from the back of the machine, also take out and reseat the memory
Please post back with the results and more help if needed, good luck and thanks for using FixYa!!
May 21, 2009 | Foxconn 661FX7MF-S Motherboard
Can not find where to put the PWR S/W on MB
look on the mother board for a group of pins, two rows, the top row will have one less pin then the bottom row. right next to the missing pin is the two pins needed for your power switch. touch a screw driver to one of those two pins one at a time and that will tell you which one is pos.
Apr 12, 2009 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Need help
Do you have all the power supply cords fitted into M/board
M/boards nowadays have 1 large white plug and sometimes 1 smaller 4 pin one or an 8 pin one
Does your power supply have them if not you will have to upgrade tou power suplpy
Aug 15, 2008 | Foxconn 661MX Motherboard
Cannot Install Windows
Well it sure sounds like an overheating problem, and 77 degrees celcius is way too high, specialy if it's right after boot! try reseatting the heatsink and make sure the repair place put a thin coat of heatsink compound paste on the processor. You need to bring that number down so really pay extra attention to the heatsink.
The next thing would be a bad memory module check out http://www.cas411.com/ShowArticle.aspx?ID=66 , it talks about surprising behaviors of PCs when a memory goes bad.
Hope this helps!
Alex J.
Mar 23, 2008 | Foxconn 661MX Motherboard
Intel 2.8G\400MHz problem
I would agree that 50% of the time you may get away with putting a working Hd with windows on it to run when changed to another board. When you change your motherboard, there are certain entries in the system registry that are looking for the components of the old motherboard. If the registry does not find these components, the system can become unstable.
The fact that you got windows to some what start is a good sign for the Hd. Try setting the CD as first boot device & have your windows XP in the drive. Do a format & install. I'm sure windows will install. Since you have three boards all the same you will only have to do this once. Foxconn warrants all Mb for life. You can always call at 580-272-0035
Mach Speed Technologies, Inc.
110 East 10th Street
Ada, Oklahoma 74820
Jan 08, 2008 | Intel Celeron D 2.8GHz 478-pin 533MHz CPU...
Computers & Internet Logo
137 people viewed this question
David Payne
David Payne
