Question about Kitchen Ranges
I have a Westinghouse Silhouette upright natural gas oven which burns out Solinoid valves within a couple of months. I recently had the solinoid replaced under warranty & was advised that it was being caused by a falty ingnition pack. They have told me that this part is now unavailable. Please advise if this is correct Model # GWC 705 FWNG 00 sERIAL # 33702205
  • Sulsie05 Sep 10, 2008
    Is the phone number an international # as it is not recognised in Aus...I tried it as 4427873 also
  • 594 Answers
I have sent an inquiry let me see what they say
Posted on Sep 04, 2008
  • Cameron Viseth
    Cameron Viseth Sep 05, 2008
    You will need to contact westinghouse here is the number. your stove is made by salton and they keep giving me the run around. online so they told me to contact them by phone. So i am passing the number along. 1-(866)- 442-7873.
    Please do not forget to rate and comment about your experience.
  • Cameron Viseth
    Cameron Viseth Sep 10, 2008
    im sorry the number i gave you is for the usa. they do not have an international number.
Main burner and pilot go out on oven after 30-45 seconds. you hear a click when it goes off
loud click may be solinoid valve, wich is inside the gas valve. check continuity within gas valve coils. if there is no continuity replace gas valve
Dec 02, 2013 | Pool & Spa
I HAVE A PO 401 CODE HOW DO I FIX THIS PROBLEM ON MY MERCY 2002 MOUNTAINEER
That could be a couple things, it could be your DPFE, your EGR valve, or the EGR valve solinoid, or it could be the vacuum leak as well.
Oct 23, 2013 | GE Eterna EGR2000EMBB Gas Kitchen Range
De Dietrich 230 eco 170 hot water boiler fault. error code 14 (no flame),gas present at inlet to multiblock valve,1st stage valve opens but no gas flow.I have tested and checked pcu board,solinoid...
Sis you put in this gas valve recently .if yes make sure it's in the right direction .There is a arrow at the bottom of the valve to let you know how to put it in
Jan 09, 2018 | Heating & Cooling
My rear driver side door will not lock using the keyless entry, i have to manually push it down for all the others doors to lcok & activate the alarm.
There is a solinoid in your door that actuates the locking mechanism. If one of the wires is loose, or somehow disconnected it will not work. Since the others work, unless your car has a fuse for each door, the problem will not be a fuse. It could be that the solinoid in that door is burned and requires replacement. A test light on the solinoid contact when trying to lock it will demonstrate whether there is power TO the solinoid. If there IS power to the solinoid, the solinoid is bad, if there is NOT power to the solinoid, you must find the disconnect. Usually it is one or both of the wires connected TO the solinoid.
Apr 07, 2010 | 2005 Honda Accord
Magic chef model 9495XRB on bake igniter comes on but no gas Broil works ok
Hello there:
These ovens have a gas regulation valve that is on the back ov the oven along with a solinoid valve
The gas reg valve will regulate how much gas goes to the oven if this fails there wont be anuy gas getting into the oven so check this
Also the gas control valve or solenoid valve is the valve that opens up and lets the gas into the oven so if this fails there wont be any gs getting into the oven so be sure to check this as well
Now you may also want to make sure that all of the gas tube is clean really good and if it is than i would have to suspect that either the reg valve or the solinoid valve is either clogged or needs to be replaced i would remove the outlet side of each of these items 1 at a time i have said earlier and see if you get gas to the outlet side if so good move on to the next component till you find the one that does not have very much gas or no gas coming out of the outlet side this will be your problem part simply remove the part and get a new part then hopefully this will take care of the prolem
Hope this all helps you very much please post me if you need any further help
Best regards Michael
Feb 10, 2010 | Ovens
I have Britony combi SE.It keeps cutting out error 70 and 80 . Ichance the pcb three months ago if that helps
tour gas valve or solinoid is faulty,check you have 240dc across the solinoid,if you have then its the gas valve,if not its your solinoid,but check you have spark at the ignition electrode first,if not check the continuity of the harness,the harness are the two yellow or orange wires from spark generator on pcb to ignition.
getting confused,mail me i will go through it for you
Jan 24, 2010 | Combi Centre DX - Mango
I have a hobart 135 welder that is not working right. The gas keeps running when your not welding. When you plug it in it sounds like something is running inside without it being turned on. Do you know...
This sounds like the gas solinoid, first, check the gas flow, this should be 12 - 15 ltr per min: if thegas flow is to high it will hold the solinoid vale open. you can reduce the gas flow to a minimum, then check to see if the solinoid closes and opens, if not the iether the voltage to the solinoid is too low or the solinoid plunger is damage, replase the solinoid. lets know .
Nov 17, 2009 | Hobart Handler 140 Mig Welder
Used oven purchased in US to work in Trinidad and Tobago (Caribbean) Only LPG Gas is supplied here, it seems as if the gas type is not what the oven was designed for. Main burners fires up and then cuts...
Hi i was reading your problem go to the appliances parts store tell them you need a gas valve Regulator that will change it from lpg to natural gas its natural gas it needs on the the 10 psi i think it should go back on the 25 psi thats only Regulates the flow of gas to high an to low dats all..i can be reach babeboz2000@yahoo.com
Nov 14, 2009 | Blodgett DFG-100 Gas Single Oven
2003 honda cb250 no start
starter solinoid has got wet,spray the electrics with wd40 to displace the water. if this does not remedy the fault then the starter solinoid will have to be replaced..hope this helps
Jul 02, 2009 | 1998 Honda CB 250 Nighthawk
Kitchen Ranges Logo
115 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
