Question about Timeslips Computers & Internet
Timeslips 2005 Loaded software--timeslips 2005-- onto a new computer and now my other computer cannot run the software. It worked fine before I put the software on the new computer. Old computer was eaten up by some kind of bug and hit the dumpster.
cammedic
  • 667 Answers
SOURCE: importing pictures to computer from camera
Try here: http://www.dll-files.com/dllindex/dll-files.shtml?ptpusb
Posted on Jan 10, 2008
CrissLine
  • 75 Answers
SOURCE: I have a samsung g600
that depends on what computer are u using or what operating sistem XP,Linux,etc the problem comes from the operating sistem maybe is to old and has some bugz try to restore ur op sistem
Posted on Apr 23, 2008
  • 10406 Answers
SOURCE: transferring music files with a memory stick
Insert the memory stick into a USB port on your computer.
Windows will recognize the device,
and give you a choice of applications, i.e., play music with Windows Media Player, or, use Windows Explorer to browse.
Select Windows Explorer.
Click to select the files/folders.
Choose "Copy Files".
Copy into your "My Music" folder on your new computer.
Posted on Nov 14, 2009
SOURCE: This printer will not communicate with a new
Can some one phone me to help me with this printer hook up 905 450 7497 Thanks Marjorie.
Posted on Dec 31, 2009
  • 371 Answers
SOURCE: Loaded autodigitizing onto our new computer with
There is an update for dongles and windows 7.
Info on Husqvarna Viking website - http://www.husqvarnaviking.com
When installing the 4D Embroidery System onto Windows 7 computers, the dongle drivers may not initially work correctly, as the 4D Embroidery System installs a set of dongle drivers which were created before Windows 7.
Download and install the latest dongle drivers prior to installing the 4D Embroidery System. Failure to do this, may result in the "Dongle driver not found (E0009)" when you try to open the 4D modules.
Please follow the steps below to install the latest dongle drivers BEFORE installing the 4D Embroidery System
  1. Download and install the latest Dongle Drivers.
  2. Insert your 4D Dongle.
  3. Install your 4D Embroidery System software (and all updates).
  4. Open your 4D Embroidery System software to confirm that your dongle is working correctly.
If you installed the 4D Embroidery System software before installing the latest dongle drivers and if you experience problems such as the error message "Unable to start hasplms service..."; download and install the latest Dongle Drivers.
Link to dongle drivers - http://www.vsmsoftware.net/downloads/HASP/haspusersetup.exe
Good luck.
Posted on Feb 13, 2010
Tip
How To Diagnose Timeslips v9.0 and Higher
This feature is only available in Timeslips v9.0 (Service Release 11), v9.1, and higher. If you have a Service Release of Timeslips v9.0 lower than SR11, please download it from <a href="http://www.timeslips.com/Support/downloads"><b>http://www.timeslips.com/Support/downloads</b></a>. Be sure to install the update on each computer that has Timeslips installed.<br /> <p style="font-style: italic;"><br /><br /> <p style="font-style: italic;">If you have not already installed Station Administrator, install it from your Timeslips CD-ROM using the Custom installation option and selecting only Station Administrator. If you are using Timeslips v9.0, then you must reinstall SR11.<br /><br /><br /> <p>We recommend performing this procedure on every computer when you:<br /> <ul> <li>First install Timeslips</li> <li>Update Timeslips</li> <li>Update your computer's operating system</li> <li>Experience data corruption</li> <li>Experience errors starting Timeslips that tells you to use this feature</li></ul>Prior to performing the Diagnose This Computer procedure you must exit Timeslips as well as any other program which may access the Borland Database Engine (BDE). If you are unsure what programs may use BDE, close all other programs.<br /><a></a><b></b><br /><br /><a></a><b>Steps to perform the Diagnose This Computer procedure:</b><br /> <ol> <li>Close Timeslips and any other program that uses the Borland Database Engine (BDE).<br /><b>Note</b>: If you are unsure what programs may use BDE, close all other programs.</li> <li>Open Station Administrator on the computer you wish to diagnose.<br /><b>Note</b>: If you have not installed Station Administrator, install it from your Timeslips CD-ROM using the Custom installation option and selecting only Station Administrator.<br /><b>Note</b>: If Timeslips is operating in a network environment, and Station Administrator is not installed on the workstation, then use Windows Explorer to locate and run <b>Statadmn.exe</b> from the Timeslips installation folder on the server. [From the Windows Toolbar select <b>Start</b>; <b>Run</b>; <b>Browse</b> to locate and open <b>Statadmn.exe</b> from the Timeslips installation folder on the server.]</li> <li>In Station Administrator select <b>Options</b>; <b>Diagnose</b> <b>This</b> <b>Computer</b>. Click <b>OK</b> to confirm that all programs using Borland Database Engine are closed. Station Administrator will attempt to analyze your system.</li> <li>When <b>Analyze System</b> completes, the Diagnose This Computer dialog box will open and alert you to problems with your Timeslips database and operating system. Each of the four areas has an associated Fix button. If any Fix button is enabled, click it to either solve the problem or receive instructions for doing so. Click <b>Help</b> for further information.<br /><b>Note</b>: Even if no problems are reported, Station Administrator may make other necessary changes (<a href="http://kb.sagesoftwareonline.com/cgi-bin/sagesoftwareonline.cfg/php/enduser/popup_adp.php?p_faqid=14967&p_created=1122586187&p_sid=TUvWvcnk&p_lva=15461&p_li=&p_redirect=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MjE4LDIxOCZwX3Byb2RzPTUxMzQsNTE0MCZwX2NhdHM9JnBfcHY9Mi41MTQwJnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTE*#does">see above</a>). </li> <li>If you have experiencing data corruption errors click <b>Change Operating System Settings</b> to open the Windows 95 and 98 Settings dialog box and unmark <b>Enable file system caching</b>. Click <b>OK</b> to return to the Diagnose This Computer dialog box. </li> <li>Click <b>Done</b>. If prompted to do so, restart your computer.</li></ol>
on Feb 21, 2011 | Computers & Internet
Program stops working
Uninstall it and reinstall it!
Mar 04, 2014 | Sage Software Sage Timeslips 2011
I have a new computer,my finepixviewer was installed on my old one worked fine. I have down loaded my finepix Cd onto new computer. It has insalled ok but will not conect to server to down load extra...
Did you try contacting Fujifilm online support? This may be because you have not registered from the new computer to whatever program you are trying to connect. If your problem is about running the software already installed, why not consider using third-part software to download, and edit your photos. picasa for example.
Please rate fixya answers
Mar 10, 2011 | Fuji FinePix A500 Digital Camera
Timeslips error: Directoty in use
Mine is exactly the same except for the version. My version is 19.0.0.0448. any suggestions on how to fix it
Dec 29, 2009 | Timeslips 11 (TSW11RT) for PC
I need to reinstall Timeslip 2006 on a new computer and it's not letting me. I have the configuration code, serial number, installation code, and it's not working. Thank you.
I'm not positive with Timeslip but it sounds like a similar situation as with Adobe products. You probably need to uninstall the product from the original computer. Part of the uninstall will most likely send a message back to the software publisher that your license key is no longer being used. Then when you install on the new computer, you will be using an unused license.
Sep 11, 2009 | Sage Timeslips by 2006 Full Version for PC...
Timeslips 2008 will not boot up (Vista)
Do you mean to say Timeslips does not run on vista? If that's what you mean try re-installing it as administrator by right clicking on the .exe then select run as administrator also check for system requirements
http://www.timeslips2008.com/popup_requirements.htmlout the system requirements
Jul 03, 2009 | Sage Timeslips 2008 Full Version for PC...
My Timeslips Version 11 does not print the full bill template anymore, and so my firm name does not appear on the bill. It seems like there are other random changes that occurred after I refused to...
This is the Sage Timeslips support page. It may help answer your question. Good luck.
https://support.na.sage.com/selfservice/microsites/msbrowse.do?UMBrowseSelection=SG_SAGETIMESLIPS_1
Dec 02, 2017 | Timeslips 11 (TSW11RT) for PC
Importing pictures to computer from camera
Jan 10, 2008 | Fuji FinePix S5700 Digital Camera
Computers & Internet Logo
Top Timeslips Computers & Internet Experts
Iqbal Husain
Iqbal Husain
Hjalmer Lamminen
Hjalmer Lamminen
Neal Marrison
Are you a Timeslips Computer and Internet Expert? Answer questions, earn points and help others
