Question about Dell Axim X50v Pocket PC
Wi-fi PDA connectivity problem
I've just got a Dell Axim X50v but it won't recognise my home wifi network. The network is based around a Belkin wireless router. My laptop works ok on network. Whe I run the WLAN utility on the PDA the site tab says that the network is recognised and the signal strength is good but when you look in the config tab there is no signal. Can anyone help. Thanks
  • 3 Answers
First, restart your pda by using your stylus and pressing the pin-hole sized button on the back of the PDA. There are sometimes a couple of different reasons why the pda wont recognize the network. Main Reason: Make sure you are at the home screen... Tap the wifi icon on the lower right corner of the pda. T hen make sure that the WLAN power is turned ON. Press the setting button. If you see your network in the list, tap on it. It should bring up a network configuration window. Make sure it says it connect to "The Internet". Then tap on the "Network Key" tab at the bottom of window. If you have no security settings on your belkin router, make sure Authentication is set to Open and Data Encryption is set to "Disabled". Then press "OK". That should Be it!!!! Let me know if this way doesnt work, or if something doesnt make sence!
Posted on Aug 15, 2007
I phone 5
What Type/Brand of router ?????
Apple's iPhone is a multimedia connectivity tool.
As such, the iPhone employs a sophisticated system to keep you connected to the web via WiFi signals so that you can stay up to date with email, mapping and media.
To use the iPhone's WiFi feature just follow these steps.
Tap a network.
If you have not yet used your iPhone's WiFi or if you're in a new WiFi area, the iPhone will show you a list of available networks.
Tap the network that you want to connect to in order to connect.
If there is a password required a little lock icon appears.
Enter the password to connect to locked networks and continue to surf the web.
Monitor your signal.
As you use your iPhone, especially if you're moving around, you should take a look at the signal strength of the connection.
The strength is indicated by a small, black broadcast symbol that stacks arches, or rounded bars, on top of one another.
The more bars there are the better the signal.
Make connecting to WiFi automatic or manual.
The iPhone is equipped to automatically search for available networks and connect you to one.
If you do not want the phone to search for networks, select the "WiFi" option on the phone's menu.
Then select either the on or off option of the "Ask To Join Networks."
Turning this option off requires that you find networks manually.
Forget a network.
Once you connect to a WiFi network once the iPhone automatically remembers the network and connects you to it at a later opportunity.
To forget a network so you don't get automatically connected choose the "WiFi" option on the menu.
Then tap the right arrow button next to one of the networks that the iPhone already remembers. Then tap "Forget This Network" to erase the phone's memory of the network.
Troubleshoot Wi-Fi Connection Problems on an iPhone
If you experience Wi-Fi connectivity issues on your iPhone, you may need to reset the Wi-Fi connection.
Your connectivity issues could be caused by the wrong password if you are having trouble logging into the Wi-Fi network or from a problem in your iPhone's settings.
By resetting the Wi-Fi connection, you are clearing out the previous settings created when you first connected to the network.
Tap the Settings icon on the iPhone's home screen, and tap the Wi-Fi tab.
Swipe the switch on the Wi-Fi tab to ensure Wi-Fi is enabled on your iPhone.
Tap the blue arrow button on the network tab you are connected to in the network list, and tap "Forget this Network."
Tap the "Forget Network" button that appears on the pop-up menu to confirm the action.
Tap the Wi-Fi Networks tab in the upper-left corner to return to the previous screen, and tap the network's tab in the network list to re-join it.
Press the Home button on the iPhone, and tap the Safari icon on the home screen to test the Wi-Fi connection.
Tap the blue arrow icon on the network's tab if the connectivity problem persists, and tap the "Renew Lease" button at the bottom of the network's window.
Tap the "Renew Lease" button on the pop-up box to confirm the action.
Tap the Home button on the iPhone, and tap the Safari icon on the home screen to test the network connection.
Nov 11, 2013 | Computers & Internet
Dell Axim X5 connecting to Belkin wireless router
What is the model of your wireless router? Does it support the B network your pda is?
also try installing ministumbler (wireless scanner program) to the pda
available on this webpage
http://www.stumbler.net/
scan around with the stumbler it should detect the network, if its set to the wrong band, G only for example it wont be detected set the router to mixed B / G mode.
Aug 13, 2008 | Dell Axim X5 Pocket PC
I can connect to a wireless network but cannot send or receive messages via e-mail or go on line. I have tried every possible combinstion, nothing works.
If you haven't already done so, go to 'Start > Settings > Connections tab > Wi-Fi > Network Adapters tab', and make sure the 'My network card connects to:' dropdown menu is set to 'The Internet'.
Just my 2 cents...
Regards, Carlos
Jul 16, 2010 | Dell Axim X50v Pocket PC
Dell Axim x50v PDA turns on when screen is tapped
If your PDA turns on when u press buttons if u go to settings u choose if u want it to turn on for any button or just the main button
Aug 06, 2009 | Dell Axim X50v Pocket PC
REINSTALLATION OF DELL AXIM 50 PDA
You will need the disk that contains the firmware. The best thing to do is check on Amazon or ebay and upgrade to the highest firmware your device can accept. I belive the cost for a downloadable copy is between $5-10. If you do this make sure to follow the instructions for you can irrevocably render the device useless. :-(
Apr 16, 2009 | Dell Axim X50v Pocket PC
I want to connect to my wireless Internet connection
If everything is working as it should. All you have to do is turn onyour Wi-Fi. You will then see a popup asking you if you would like toconnect.
You may need to add a compact flash wireless card:
  • http://wifi.aximsite.com/wifi-faq.html#_51-card
  • http://www.amazon.com/SPECTEC-Wireless-Networking-Connection-Notebooks/dp/B000BD9PBQ
You'll find a comprehensive axim wifi guide here: http://wifi.aximsite.com/
Oct 28, 2008 | Dell Axim X30 Pocket PC
Transfering files from Dell Axim X50v PDA to a Sprint Mogul PDA/Phone
Try setting up both PDA's on desktop, opening up 2 activesync files. Drag files from one to the other.
May 23, 2008 | Dell Axim X50v Pocket PC
Connecting to Internet with WiFi
to phill -
Axim X3 cannot connect to Wifi, only X3ihas built in wifi
Jun 20, 2007 | Dell Axim X3 Pocket PC
Cant save images in internet explorer
There is another browser out, I think it is called ftxPBrowser. It does tabbed browsing and you can save images. hope that will work.
Sep 19, 2005 | Dell Axim X50v Pocket PC
Wi-Fi
You will not believe me but I have a similar problem. I have also Belkin router at home and wireless connection with my e800 works perfect. A few days ago I have tried to connect my PDA to wireless router of my best friend. His wireless network is protected like mine and after configuration of all settings I had no success. The funny thing is that PDA show me the status CONNECTED but I can not use the internet explorer. Like I said, at home with my Belkin it works properly. I can really not explain what the problem is.
Sep 08, 2005 | Toshiba e740 Pocket PC
Dell Axim X50v Pocket PC Logo
331 people viewed this question
Clive
Clive
Alun Cox
