Question about Acer Aspire 1642ZWLMi Notebook
Audio glitches recently the audio on video or mp3 playback has been glitching heavily - upon running the task manager the cpu is running at 100% usage and i can't work out was program or process is using it. Despite attempts to update the drivers etc nothing seems to sort the problem out. Does some kind person have any ideas what i might do?
  • 81 Answers
When your CPU is staying at 100% run, that means you likely have gotten a virus or some serious spyware. Those can affect your audio and video playback, because some viiruses and spyware attach through your audio/video. try running your antivirys software; you can also try doing a system restore. if that does not work, you will probably have to reformat your hard drive and then do a fresh install of your operating system.
Posted on Sep 04, 2008
I have a computer [AMD athlon(tm)]xp 1800+ 1.50 GHz]. My problem is when I switch on the system,the OS will open and i don't open any application then if i see in 'Task Manager - performance' there the...
Type "msconfig" on search bar there will be bar "startup apps" click that and click on disable all and restart your system...hope it works... Regards: imran
Sep 19, 2014 | Computers & Internet
Acer aspire one D250-0BK keeps freezing
There are many things that might cause your PC to run slowly or restart at time and then. It could be a fragmented disk; fragmented registry; a virus, Trojan, or spy ware; high CPU and/or utilization due to too many programs running; high disk I/O; or something else.
To check your CPU and memory utilization, run Task Manager. You can start Task Manager by pressing CTRL+ALT+DEL and then clicking on the Task Manager Button. In Task manager, click on the Performance tab and check CPU Usage and PF Usage. PF Usage is an indicator of memory usage. If one or both of these is high, click on the Processes tab, and sort the columns by CPU or Memory to see what processes are consuming the resource. If you are not sure what the process "Image name" is for, Google the name and you should find what the process is for.
If your CPU and memory usage are reasonable, then you may have a different issue. Even if you running anti-virus software, it may be beneficial to scan your PC with another scanner to check for viruses. No anti-virus software is 100% perfect at catching everything. Here are a few good free online virus scanners that you can run to check your PC: 23&pkj=RRJEDTKJBTVISBYWWYP
Nov 05, 2011 | Acer Aspire One PC Notebook
My Toshiba satellite pro M10 very slow.
check your system performance thru task manager. check for CPU usage. usually COU usage is 1% to 10%. if your CPU usage would peak from 10% to 100% there is a huge possibility that there is program running on your computer that eats up your memory. Or it could be spyware/malware
Mar 27, 2010 | Toshiba Satellite Pro M10-S405 Notebook
D865 Intel Motherboard overheating
The 50% useage of the CPU is the problem not a fan issue. You have a memory glitch or IRQ setting causing this. Go back to basics look for a Video problem or shared memeory - does this board have onboard video, does it have onboard audio, have you installed a add in video/audio card? Check your bios settings, look at shadow memeory useage.
Jul 24, 2009 | Intel D865PERL Motherboard
E-System laptop with slow dvd playback
This can be a bit of a tricky one to figure out. My initial response would be that you have another program or process that is causing your computer to play 'choppy' video. When you have a newer computer that was recently working just fine and now all of the sudden the video is choppy, it is usually due to another process using CPU cycles that are so important to video playback.
Start playing a DVD, but don't go to full-screen mode. Open the Task Manager. Right-Click on the task bar and select Task Manager. Click on the 'Processes' tab. There is a column labeled CPU, click on the heading 'CPU' twice. This will order the processes in order from highest CPU usage to lowest. The top two processes will most likely be your DVD player and the process that is causing your choppy playback.If the offending process isn't essential (i.e. anti-virus), then click on said process and then click the "End Process" button.
Hope this helps.
Mar 09, 2009 | Computers & Internet
My music periodically cuts out and this hasn't happened until about a week or so ago, could you tell me what the problem is please? i really enjoy your web site. anxiously awaiting an answer, thank you so...
playback your music as usual and press ctrl/alt/del all at same time you get task manager up. select the tab processes. where it says cpu press twice so that it shows cpu usage highest first. monitor this when music cuts out look to see what processes are taking up most of the cpu usage you probably find that a background process ie antivirus, updates etc etc will be making the cpu work hard and that what causes the music to cut out as cpu being heavily used by background processes. some can be cancelled or rescheduled so as not to cause problems.
Oct 07, 2008 | Computers & Internet
Perfect picture but audio glitches...
audio "glitches" or dropout is a typical symptom of tape path misalignment. find a good local repair shop (are there any more of us still around?) and they should be able to perform this relatively simple alignment.
Sep 21, 2006 | Sony DCR-VX2000 Mini DV Digital Camcorder
Acer Aspire 1642ZWLMi Notebook Logo
62 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
