Question about Pioneer Audio Players & Recorders
Have replaced laser and spindle motor. Tried variouse acjustments. The spindle motor will turn, the traverse will search up and down, it makes the usual noises while the laser is picking up some signals but at the end it does not recognise a disc. We are a service center. I have never been able to get one of these models to work. Am I missing something here? Are there any other common faults causing this problem. Has it to do with alignments? (Have tried variouse settings with no success including stting a different turntable height, adjusting laser to variouse settings etc. Please can you suggest something? Eric Pal Tech Services
  • service_tsv Sep 04, 2008
    THANKS DAVE
    THE MODEL NUMBER IS PD-M427
    ANOTHER REPLAY WOULD BE APPRICIATED
    ERIC
    President:
  • 624 Answers
If this is a Pioneer CD player, you may need to do a grating adjustment. Do you have the service manual? What model number is this?
I may be able to help you more with this information.
The grating adjustment is needed on many different Pioneer CD players, mostly the older models. There is a smaill area on the pick up with a copper colored plate that must be moved just a little one way or the other. You put a very small flat head screwdriver in and move this copper plate just a little one way and then try again the other way if it doesn't work the first time.
There is a jig set up that Pioneer outlines in the service manual to do this properly. You need an O-scope as well to moniter a point on the jig. I have done this before without using the jig or O-scope, but it is more presise with these things being used.
This procedure needs to be done in the test mode so the disc is spinning constantly and then do the adjustment while watching the O-scope to know when the adjustment is at the proper position.
If this is a model that I have the service manual for, I can outline the procedure very well for you. But first I need to know the proper model number which I did not see in your post.
Let me know,
Dave
Posted on Sep 04, 2008
  • Dave DeGain
    Dave DeGain Sep 04, 2008
    I checked and could not find the service manual for the model you have. I even checked on Pioneers service website and they have no manuals or bullitins for it either.
    The bottom line is I can not give you the details I hoped to have.
    Since this is a 6 disc changer with a magazine, it has the traverse deck (pick-up assembly w/spindle motor) on the top of the cd mech with the pick-up right there with the laser pointed down. This means that you should be able to see the area that needs adjustment very easy and get access to it with out any trouble. As I stated before, there is a small copper colored piece of metal that needs to be adjusted. You can look right at the pick up and see it, it has a notch in it where a small flathead could fit into. That is the spot to use for moving that copper piece inside the pick up. You would then just move that copper piece a very small amount one way, just nudge it a hair, then try playing a disc again. If it doesn't work, nudge it a little more, then try playing a disc again. If it still doesn't work after 3 or 4 nudges, nudge it back the other direction a few times while trying to play a disc in between each nudge of the copper piece.
    If you have changed the spindle hieght and made adjustments to the laser power on the pick up, you may need to have a new pick up and spindle motor if you can't get those things back to the original settings. This adjustment may not work properly if the laser power is too high or too low, or if the spindle table is too high or too low. You can adjust the laser power output by monitoring the eye pattern with an O-scope and then adjust it to about 1.2 volts peak to peak That should put you right where you need to be. The spindle table you will just need to wing it and make sure it doesn't look too far away from the disc when loaded with one.
    I wish I could have had the service manual for it, but I don't. So this is the best information I can give you. You may want to just order one from Pioneer since you said you work on a few of these and could never get them to work. The one-time investment for all the exact information on the grating adjustment would be a great help to you in the future. The service website that I accessed for Pioneer did not have anything on this model, but that is because it is a little too old. They do have hard copy service manuals you can order and have shipped to you. I was looking for a PDF to download which they have lots of, but only back to a certain year. Everything else older is only hard copies.
    I hope this helps, and a good rating would be appreciated.
    Thanks,
    Dave
The DVD player tried to read the DVD and stopped. It said H07 and then display reads STOP
Many Panasonic DVD units use a traverse unit (spindle motor/laser assembly) - and the H07 error indicates a failure of this component block (the spindle motor is the part of the unit which fails first).
This part is not repairable, it can only be replaced by a qualified authorised Panasonic technician - then it must be aligned and the firmware updated/configured to the player. The problem with this is the costs involved; a new spindle motor/laser unit (through Panasonic directly) would cost around $200 trade plus the labour/fitting/alignment - it could be a further $200 - making it uneconomical to fix - since this would be about the price of a new player.
However, you can submit the unit to a service centre, for a quote on the likely part/labour cost(s), then make a decision afterwards - whether to go ahead with the repair or cut your losses and buy a new player.
Blu-Ray players (with DVD playback support) are becoming cheaper to buy nowadays while repairs to DVD players become more expensive. It's up to you.
Mar 28, 2011 | Panasonic Televison & Video
MY DVD-RV32 IS SHOWING H07
Ah, the classic H07 error code. It means the spindle motor part of the traverse unit (which also contains the laser) has failed. Because the traverse unit is a multi-operation device, the cost of a replacement could be considerably higher than the retail price of a brand new player, along with the labour costs to configure and align it; therefore making any repairs to this one uneconomical.
If you want to get it fixed, by all means take it to an authorised service centre and get a quote, then you can decide afterwards whether or not to go ahead with the repairs to this one, or buy a new player. It is up to you.
Mar 08, 2011 | Panasonic DVD-RV32 DVD Player
I am unable to play DVD's and receive error message HD7. How can I fix this? I own Panasonic DVD-RV32 player.
I think you mean H07 - this means the traverse unit (which contains the spindle motor and the laser in one assembly) has failed. The spindle motor is the most likely problem; unfortunately this is not repairable at consumer level, it would need to go to an authorised service workshop where the whole unit would be replaced in the player, which would include a brand new laser. The other snag is the cost - a new traverse unit can cost around $200 + labour (including alignment and firmware upgrades)!
Save yourself the agony, and simply replace the whole player - cheaper than repairs. The RV32 was not Panasonic's best DVD player model.
Mar 01, 2011 | Panasonic DVD-RV32 DVD Player
Panasonic DVD Player. Reads DVD then says HO7 and then STOP. PLAY DOES NOT PLAY
Common failure of the spindle motor/laser assembly. Also known as the traverse unit, which can cost more than a new player to replace. Not a consumer-repairable part.
Feb 26, 2011 | Panasonic Televison & Video
Please help me to solve the problem with error H03 of DVD-LX8. Thanks a lot.
These H errors may refer to either the laser pickup or spindle motor or both. In this case, H03 and H07 are both spindle motor related. The only trouble is that this part is not serviceable, you cannot dissect it to clean it etc., so it must be replaced (most models I have dealt with have the laser/spindle motor as one part - known as a traverse unit) along with the laser which is also part of this device.
If you cannot hear any discs spinning when you load them, and you should be able to, then the motor within the traverse unit has given out. This can be expensive to replace unfortunately. I advise that you probably take the player to a repair shop - preferably an authorised Panasonic agent, get a free quote and make a decision afterwards as to what you wish to do.
Feb 17, 2011 | Panasonic DVD-LX8 Portable DVD Player
When trying to play a dvd , it shows H07
Traverse unit (spindle motor & laser assembly combined) is most likely faulty. The motor part usually fails first, which stops the discs from spinning, so the inbuilt laser cannot read them, hence the error code. This can be expensive to replace.
Jan 28, 2011 | Panasonic DVD-RV32 DVD Player
It stops playing the disc and says h07
This is a fault with the spindle motor
Dec 10, 2009 | Panasonic DVD-RV32 DVD Player
H02 code after inserting DVD
Hi,the spindle motor on the traverse deck of the laser is faulty.Replace it and the machine will function again.
Aug 14, 2009 | Panasonic Televison & Video
THANK YOU DAVE, THE PIONEER PLAYER MODEL NUMBER IS PD-M427 IF YOU COULD BE SO KIND AND INSTRUCT ME WITH MORE DETAILS ON ALIGNMENT /SERVICE MODE PROCEEDURES WOULD BE APPRICIATED. I AM REPETING THIS TEXT...
As you are a 'service centre' you should know to check the laser power with your laser power meter before anything else after checking the sled motor and spindle motor, assuming the laser is lighting.
It is simple, follow the service alignment procedure as laid out in the service manual from Pioneer. Ref RRV2905 page 22.
Mar 14, 2017 | Pioneer Audio Players & Recorders
Panasonic SC-HT75 Home Theater system
Laser/traverse deck needs replacement.Spindle motor fails to spin.If loaded disk will not turn give it a slight push to get it started.If it runs the motor is bad and the traverse deck needs replacement.Not an easy fix.You need to know specific procedures and alignments.
Dec 26, 2007 | Panasonic SC-HT75 System
55 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
