Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Lsq7030lq0 cp1145460 when start to wash as noise come from center shaft look same lost theet transmission problem?
    Novelist:
  • 166 Answers
Transmission or the coupling connecting the trans to the agitator!
Do not run it! Get service out before you cause any more damage!
ngafm
Bless You,
please rate me before you sign of
Posted on Sep 08, 2008
Where is the lint filter on Whirlpool Washer Model LSQ7030LQ0?
There is no lint filter on your unit. What kind of problem are you having?
Apr 25, 2012 | Whirlpool Washing Machines
I have washing machine LG AUTO WF-T708TC..so now the problem is the washing run something very noise hear under the drum and if spin the noise very loud so now i try get some once experience to check this...
Doubt its the transmission is it a top load or front load? Either or it has a center shaft bearing and that is whats making the noise does it kinda sound like a jet engine firing up in the spin speed or metal grinding noise which that would be the center bearing and if it is the transmission you have to replace the whole tranny with a new one they don't sell parts to fix them unfortunately and its not worth fixing very expensive on both parts plus labor you be looking at $300 to $600 I would suggest buying a good quality used one or a new one but hope this helps and sorry for the problems its giving you.
Jan 10, 2011 | Washing Machines
Loud noise on spin cycle...sounds like a bad bearing maybe????? any advice on this noise?
It's hard to pinpoint it from your description. But it might be either the motor coupler, or transmission. Does it agitate alright with no noise? It could be center shaft bearings too if it only makes the noise in spin. Either way, with transmission, or center shaft bearings, the transmission needs to be removed. The motor coupler is a lot easier. It's what drives everything and is used instead of a belt. If the rubber is worn out, it can make an awful noise. If this helps, please rate my answer. Thank you.
Jan 07, 2010 | Whirlpool Washing Machines
Manual transmission noise
It's most likely your throw-out bearing. It's located very inconveniently on the front shaft of the transmission and the way to remove and replace is to pull the tranny from the car... While you're at it, inspect the clutch and pressure plates and the pilot bushing (located in the center of the flywheel).
Nov 23, 2009 | 1997 Nissan Maxima
I have a Bosch frontloader. I have had it almost 4 yrs. About 6 months ago or a little longer the tub has started to bouce terribly when washing heavy clothes such as jeans, towels, bedding. I have to...
The inside of the agitator where the transmission shaft attaches can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Aug 07, 2008 | Bosch Washing Machines
I have a Whirlpool Model# LSQ7030LQ0 washing machine. The washer is making a lot of noise and the agititator seems loose and is flopping around as it turns. If I grab on to the agitator I can stop it...
This "MAY" be an easy fix,
I have seen the main bolt that fixes the agitator to the drive shaft come loose.
If you can imagine the agitator as a cone, the top point of the agitator is a cap that should pull or clip off. If so, using a long extention shaft and a socket set, you should be able to tighten up the bolt.
Good luck and post back results
Jul 08, 2008 | Washing Machines
Whirlpool washer problem
run the waher in a high spin and lift the lid repeat this three or four times and your brakes will free up and begin working again
Feb 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whining noise, only in rinse and spin cycle, sounds awful.
Check the pump to make sure there isn't something stuck in it.
Dec 30, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
142 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
