Question about Refrigerators
Kenmore cold spot.model number 106.52284 side by side
All of the sudden both sides will not freeze or get cold...cleaned underneath the compressor is hot to touch. it comes on for about 10 sec then shuts off then comes on again about 3 min later keeps doing this..any suggestion.
  • kscott9700 Sep 05, 2008
    just thought you might like to know..that it was the relay.that you had told someone earlier on this web page that must have been a testimonial..but i am wondering if you told me it was the compressor fault..because i did not pay for the answer..you said it would be very expensive...however the total cost was 52.09.. thanks for your imput.but not impressed with fixya...sorry :)
    President:
  • 1,462 Answers
Compressor fault - expensive repair
Posted on Sep 04, 2008
  • douglas smith Sep 05, 2008
    i don't get paid for any answers so my diagnosis right or wrong is not influenced by money. i rather resent your implication
Won't freeze on freezer side ( defrosting) and won't get cold on refridgerator side
If you have confirmed that the unit is defrosting and the freezer isn't getting cold. Make sure underneath the refrigerator is completely clean and the fan is running underneath the refrigerator next to the coils. If this all checks out then you have a bad compressor or lost of refrigerant due to a leak in the system. One last thing: Is the cooling fan running in the freezer?
Oct 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerate not working freezer not working
sounds like the relay is bad replace the relay this should take care of the problem it is located on the compressor
Jul 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore side by side cold spot 4 years old just stopped cooling and freezing
Defrost problem is possibly the reason. I need to know the model number for example 213.25897 would be a way that Sears identifies their appliances. Let me know which model and we will go from there. Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartsandtechnicalservices.blogspot.com/
Jun 16, 2009 | Kenmore 50522 / 50524 Side by Side...
My kenmore refrigerator side by side
All the cooling takes place in the freezer and is blown over to the frig side so the frig side will start to warm up soon. Possible cause is the starting device to the compressor is faulty, compressor motor locked up or cold control faulty and not closing.
http://tclaundryrepair.com/home
Feb 19, 2009 | Kenmore Refrigerators
I have a Kennmore Cold spot Model # 57285791. The center strip where the two doors meet is extremely hot and everything in the freezer is defrosted.
2 things you neeed to check first of all clean teh coils underneath the refrig. then pull unit from wall and pull off rear compartment cover and see if the fan that cools compressor is running. it is possible the motor is jammed or bad. if the motor is bad you can put a house fan blowing into the comp compartment until you get it repaired.
Jan 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore cold spot refrigerator freezer
I would look to the condenser where the heat is removed from the refrigeration system for your problem. Check and make sure the condenser fan operates, check the compressor for operation. If the condenser is plugged with dust it will cause the compressor to cycle on its thermal overload protector. Normally in back there is a removable panel to access the condenser and compressor area. make sure you reinstall the cover after you are done. It is critical to proper operation and cooling of the system.
Jun 01, 2008 | Refrigerators
Refridgerator freezing food
dm, I'm not sure if the thermostat is mechanical or electronic. Assuming mechanical...and I do...turn it to the lowest number...does it turn off? If this works properly, the problem is likely not the control. Does the compressor turn off at any time? If not after an hour or so of operation, the stat could be defective. That's my first guess. Oh, have you made sure that you don't have the ducts in the freezer blocked? The would deflect too much cold air to the fridge section.
Next, defrost the unit and clean the condenser coils. This will help the unit work properly. Then, wait awhile with the unit off. Meanwhile, access the compressor in the rear of the unit. Find the largest pipe coming out of the compressor. Turn the unit on. The largest pipe should frost and then, in about 5 minutes or so...either cause condensation or dry out. If neither happens and the line is either not COLD to the touch or frosty, you're low on gas. If the unit is less than 5 years old, you may get warranty coverage on the sealed unit from the mfgr. Believe it or not, too little gas will cause freezing in some cases!
Nov 28, 2007 | Kenmore 53212 / 53214 / 53219 Side by Side...
REFRIGERATOR OR FREEZER IS NOT COLD OR WILL NOT FREEZE
Check freezer... for Frost build up and if Fan is blowing, Check condenser... To make sure clean, and the fan is blowing by compressor, Check Recirclating Vents in refrigerator... to make sure theres no blockage, CONTROLS ...should be in the middle setting,
Sep 11, 2007 | Kenmore 22.0 cu. ft. Side-By-Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
