Question about Lexmark X73 All-In-One InkJet Printer
Lexmark x73 Printer
When I push the paper feed button on my printer, its starts pulling the paper down then it starts pulling only on the right side causing a jam. Any suggestions?
  • Anonymous Sep 07, 2008
    ditto problem - paper will no feed - roller turn but do not catch paper to pull it thru
    Champion:
  • 200 Answers
Push the paper a little bit to help the printer to pull it correctly if not working then there is a problem with the rollers and that would be a hardware issue and needs to be fixed at the shop.
cheers
Posted on Sep 03, 2008
Feed system Problem Lexmark x73
More possible for printer not feeding is paper jump, and stock up jump sensor, look hook type near roller sensor mechanism if still free in move, or if dirt, then try to feed paper manually and look for any obstruction.
Mar 21, 2010 | Lexmark X73 All-In-One InkJet Printer
My Lexmark X73 made a snapping noise and stopped
My printer did the same thing, after tearing into it, I found one of the plastic gears had broke in two.
Aug 08, 2009 | Lexmark X73 All-In-One InkJet Printer
My computer says that my printer is offline.
Please follow the steps given below to perform a self test on the printer:
1. Switch off the printer.
2. Press and hold down the paper feed button.
3. While keeping the paper feed button depressed, turn the power back on.
4. When the printer starts to print, release the paper feed button.
5. When the first page is printed, switch off the power (otherwise the printer will keep on printing).
Apr 04, 2009 | Lexmark X73 All-In-One InkJet Printer
Lexmark z2300 printer won't pull in paper
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 03, 2009 | Lexmark Color JetPrinter Z23 InkJet
Lexmark X2250 uneven paper feed
Oct 02, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmarkx73 Won't feed paper through while printing
Jul 13, 2008 | Lexmark X73 All-In-One InkJet Printer
Paper feeder won't follow through
The feeder mechanism has so to speak come undone and the printer needs taking aprt and putting back together with the feeder and the cogs interacting with eachother. Ther is a small metal clip lick tensioner to keep it in contact with the cogs, if the clip has come off it just needs securing back in place.b8ec9a2.jpg
Dec 26, 2007 | Lexmark X73 All-In-One InkJet Printer
Lexmark X73 print/paper problem
Same problem here. Went thru a few tests with Lexmark but didnt help. They next said it would be best to get new one since repair cost would be higher. Thru front door I do see a spring that moves freely. That must be broke. After their help they sent email for 20% off.
Sep 12, 2007 | Lexmark X73 All-In-One InkJet Printer
Lexmark X73 All-In-One InkJet Printer Logo
93 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
