Question about Sony (RM-SP50) Remote Control
Sony av remote
Thank you for any assistance available since we can't locate manuals. We have two children 3 and 5 who may have pressed something on remote and for some reason can't get it to work anymore. Have changed batteries. Lights flash but nothing seems to work. The model number listed is RM-
PP412 and it came with our receiver which is a Sony STR K850p.
thanks again...
  • Sony Master
  • 520 Answers
To reset the remote control to the factory default settings, simultaneously press the POWER , TV/VIDEO , and VOL- buttons. Go here for programming instructions; http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMPP412
Posted on Sep 04, 2008
I HAVE A PANASONIC PLASMA TV,SERIAL NO IS TH-37PG9U,THAT STUCK ON HOTEL MODE,IT HAVE PC,DVD,AND NORMAL CABLE INPUTS,BUT NOTHING WORKS,HOW CAN I RESET IT TO WORK,THANKS IN ADVANCE
Be careful with this !
One wrong mis-setting and you could cause problems with your set.
On the TV itself, find the manual buttons down the side and select
-/V button press down and keep it pressed down meanwhile, on your remote...
Press the AV or TV/AV button three times in quick succession.
(depends which remote you have).
First press -/V then while still pressed down, press remote AV button 3 times
The menu will appear and you can change the settings.....just don't play around with it, it will go wrong very quick. Just stick to the objective and you'll be fine.
Oct 17, 2016 | Panasonic Televison & Video
Sony AV STRDE475 remote altenative replacement
The assistant is right. It will be best to buy a new original remote control. In most cases a universal remote control won't function to all system. You can get the original one from the Autorized service center for Sony. http://electrohelponline.blogspot.com/ If you wish to get more details about the set-up codes to different other universal remote control, check this link. Pull up older posts by its sidebar. Set-up code list and proceedings to many popular remote controls are given in detail. Choose one out, which has set-up codes to Sony brand TVs, and the availability.
Jun 16, 2013 | Televison & Video
How ca I connect my wii nintendo and set top box together in KLV-32T550A
Look for something like this at your favorite electronics store...http://www.bestbuy.com/site/eForCity+-+3+Way+Audio+Video+AV+RCA+Switch+Switcher+Splitter+with+Cable/4655143.p?id=1218501028155&skuId=4655143&st=AV Switch&cp=8&lp=3
Copy all of that into your browser and you'll end up at best buy looking at a A/V Switch that can switch between 3 different devices so you don't have to change the cables...also, look for ones that are remote controlled that have more options...I just included this one as an example...hope this helps you!
Jun 12, 2012 | Sony Klv-32t550a Bravia Multi-system Lcd...
How to reset to factory settings
According to the manual, to reset all the function buttons to their factory settings, press I/O (O=Power button icon), AV I/O, {both of these buttons are at the top of the remote control} and MASTER VOLUME - {located on bottom right of remote control} at the same time.
Feb 03, 2012 | Sony STR-DE475 Receiver
I turned Zone 2 on on my Sony AV System and now can't turn it off. There must be something simple that I'm overlooking, I just can't find an off function. The remote says RM-AAE003 R on it. Thanks for...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-STR-DA5000ES-Receivers-manual/id/387ag920/t/2/
Page 18 tells how to reset the Receiver to its factory defaults. But if Zone 2 or 3 are on it won't work. Quite the Catch-22, huh?
It claims the RM-US106 should be the remote, which has explicit Zone Keys right on it.
This is SONY's own post for that remote (which requires its own manual) and it seems to be a dead end.
http://esupport.sony.com/US/perl/model-home.pl?mdl=RMAAE003&LOC=3
I
Mar 09, 2011 | Sony STR-DA5000ES Receiver
Some channels have come up "Program Blocked"
It would be easy to help you if you have provided as the exact model of your sony trinitron.
Anyways, I hope this might help you. I assumed your model is KV-20FV12.
try these steps using your remote
1. Press Menu button
2. Select Parental Control
3. Input 4357 as master password for Parental Control
4. On Custom Settings, select Unrated
5. Choose View All and then end the menu.
post back if this will not work
Feb 09, 2011 | Sony Televison & Video
Hi, I need help please. I lost my remote for my t.v and don't know how to change it to AV manually to basically watch movies. Can u please assist me. I pressed a few bottons and it worked, I just need to...
What is the make and model of your TV?
I suspect the button your pressed would be the AV/Source/Input Button It should be one of those names.
Thanks
Dustin
Jan 04, 2011 | Televison & Video
Programming my DishNet remote for my Sony AV System
Hi, the manual for the vip622 (the model I have... not sure what you have) says to use the following codes for Sony Tuners / Amplifiers.
639 645 650 687 728 729 730
(located in the Appendix)
See Chapter 10 here:
http://www.dishnetwork.com/support/documents/receivers/vip622/default.aspx
for instructions on how to program the AUX setting on your remote and how to set your remote to adjust the receiver volume while controlling the Dish receiver.
Mar 28, 2009 | Sony STR-DE597 Receiver
My tv remote control nas no av channal to set a playstation up on
Please press Video button on remote to switch to AV selection.
TV has most probably 3 AV inputs.
Feb 21, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Child lock
I also have a km0544 tv and the child lock is on however I lost the reote control for it some time ago when re-locating house. Do you have suggestions?.- Steve
Oct 18, 2008 | JC Whitney - Audiosonic 3-way Custom-fit...
Sony (RM-SP50) Remote Control Logo
867 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
