I've tried the "hold on to power button while resetting" methods (and similar variations)....
(More)
I've tried the "hold on to power button while resetting" methods (and similar variations). However, each time the test sequence comes on, it doesn't end with a beep sound. Instead it keeps repeating itself over and over.
TIA.
My window unit cuts off and displays E1 flashing. I have unplugged the unit, cleaned the filter and...
(More)
My window unit cuts off and displays E1 flashing. I have unplugged the unit, cleaned the filter and replaced, but it continues to cut off after about 3-5 minutes without cooling.I's a Sharp Energy Star, model number S120FX
I have a sharp window unit that has worked for the last 4 years or so. I was installing it this...
(More)
I have a sharp window unit that has worked for the last 4 years or so. I was installing it this spring and the compressor will not engage. But when i run it through the self test / reset (hold power button and plug in) i hear the compressor engaging. I have the front panel off and i have checked all the connections, the temp sensor reads correctly and throws no codes. I did drop it from the height of a toilet when installing it. Perhaps that has something to do with it. I have a car aircon pressure gauge around, is there a place/way to hook it up maybe?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
