Question about Singer 7462 Mechanical Sewing Machine
The threading is getting tangles in the material from the bobbin in the bottom. Is a setting on too high? i do not have a manual for this machine
Have you tried downloading a manual online? Which machine do you have? It sounds like the bottom bobbin may be in the machine backwards.
But I am certainly not an expert.
Posted on Sep 06, 2008
Help with Euro Pro 9000, the thread keeps getting tangled up in the bobbin area..
When I had this problem, even though I have been sewing for years, I was just not threading the needle properly. Make sure the presser foot is raised when you thread the needle. Another reason is that the thread is too old, the needle is not the correct size or type for the material, neither is the thread. Hope this helps. It's usually nothing to do with the bobbin, but the upper thread.
Jul 11, 2014 | Euro-Pro 9000 Mechanical Sewing Machine
Handwheel is locked down
Several things to check. Did the needle break and jam in the bottom? Is the needle bent or did it jam in the bobbin area? I had a 'knot' of thread build up on the bottom and it hooked itself into the metal clip on the bobbin so that the needle couldn't raise. If thread jams in the bottom cut the threads until you can free the hoop and material. Check the bobbin for pieces of thread and fuzz. Check to see if the bobbin case or the throat plate is scratched or bent. If you are stitching Free Standing Lace on this machine or a piece with over 20,000 stitches I recommend starting with a new full bobbin and a new needle. As you get toward the bottom of the bobbin, thread seems to have a high likelihood of tangling or looping and will cause a jam which means the handwheel locks.
Sep 23, 2013 | Brother PE770 Computerized Sewing Machine
Worked great until the needle broke and now the bobbin thread bunches up
Hello
Clean out the bobbin area if there are any thread tangles there.
If the bobbin does not fit snugly into the bobbin case, then get new bobbins. You need class A or 15 and they do not cost very much. Make sure they are plastic and not metal.
Refer to the maintenance section of the manual - see the configuration of the bobbin case and shuttle race? The bobbin case as an extending arm and the race a notch. When inserting the bobbin case into the shuttle, turn the handwheel so the needle is at it's highest position. Then lift the lever on the back of the bobbin case and insert the cast into the shuttle, arm pointing straight up toward the bed of the sewing machine.
Now thread the machine with the presser foot up - always - and see if the tangling stops.
There should be a tension setting for your bobbin thread, as well as your top thread. It sounds to me like your bobbin tension setting is not in sync with your top thread.
most common solution to this is to remove the top thread completely from machine and re thread it with the presser foot UP not down. This will allow the top thread to engage properly in the top tension disc
Aug 10, 2011 | Brother LS-2125 Mechanical Sewing Machine
The machine sews normally then once in awhile the material gets stuck in one position, does not move. The bobin thread seems to be a bit tangled in the bobbin case. What is going on?
Your bobbin may be wound uneven, try winding a fresh bobbin and make sure that you are using the same weight thread in the top and bottom. And try a fresh needle.
Oct 08, 2010 | Singer Inspiration 4205 Mechanical Sewing...
14SH654: Singer 247 Machine runs fine and then bottom bobbi...
Try using a style 60 or 66 bobbin. I had the same problem at first, and someone on-line suggested the different bobbin. I use a style 66; instead of having a flat bottom and top (and all those holes), it's shaped something like a bagel. Now my machine works beautifully.
May 16, 2010 | Singer 14SH654
Tangled bobbin
are your bobbins wound tight? allso do you have dust caught in the bobbin case at the bottom of your machine?make sure and clean out all bits of dust and fabric. as this will cause problems like this one.
unscrew the needle plate. dust it all out. allso use a small lcoin to unscrew the sewing plate. saves time.
Oct 01, 2008 | Brother LS-2125 Mechanical Sewing Machine
Amatur Sewer?threads tangled below
Stop sewing! You need to adjust your tension. Your book will explain exactly how to do this. If you can't find your book, try setting the tensions to the same number. If your tension adjustments have a mark at a certain number, use that setting for most materials. If not, try setting it to about 3.
To test your settings, thread your bobbin with a different color, then do a test stitch. Check the top and bottom stitches for a spot of the other color thread showing through. If the bobbin thread shows in the top, raise the bobbin tension setting a bit and try it again.
Hope this FixesYa!
Aug 11, 2008 | Singer 3116 Simple
Kenmore model 385. 12912890
Make sure your machine is set to feed material. There may be a switch or knob somewhere on your machine to lower the "feed dogs" (the little metal teeth that pull the material through the machine). If they are down, the material won't feed so the machine will sew in place. More likely, since its knotting on the bottom, your machine is probably not threaded correctly. Rethread the machine, and try again.
Yes, the thread on the bottom IS the needle thread.
Nov 25, 2007 | Sewing Machines
Bunching thread underneath
When your thread is bunching at the bottom, your top tension is not tight enough, or you did not thread the machine correctly. Make sure the thread goes through the tension blades. Check your manual how to do it properly. you can check if there is any tension by pulling on the thread before threading through the eye of the the needle, and with the presser foot down. By pulling with the left hand and adjusting the tension with the right hand you should be able to feel a difference. Normal setting is between 3 and 5
Oct 12, 2007 | Singer Featherweight II 117
Upper thread getting tangled in the bobbin
Always remember T-N-T. Thread, Needle, Tension. Assuming its threaded properly, is the needle all the way in and facing the right direction? These symptoms also suggest the bobbin may be in the bobbincase upside down thus turning in the wrong direction. Hope this helps.
Aug 21, 2007 | Euro-Pro 416 Mechanical Sewing Machine
Singer 7462 Mechanical Sewing Machine Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
