Question about Konica Minolta DiMAGE A1 Digital Camera
What is the available shutter speed range? - Konica Minolta DiMAGE A1 Digital Camera
    Master:
  • 425 Answers
AF single or AF continuous can be selected. In AF single mode, focus is calculated and set when the shutter-release button is pressed partway down. This mode is mainly useful for a stationary subject. In AF continuous mode, camera continues to focus on a moving subject even when the shutter-release button is pressed partway down. It is convenient to capture the moving subject. When setting spot focus point in AF continuous mode, subject tracking can be used. (Subject tracking can be turned on/off by the recording menu. ) When selecting the Spot Focus Point, Full Time AF can be used*. * Full Time AF can be turned on/off by the setup menu. * Sensors mounted on the grip and eyepiece detect when the camera is held.
Posted on Sep 15, 2005
    Master:
  • 425 Answers
The DiMAGE A1 controls shutter speed in the range of 30 sec. to 1/16000 sec. in 1/3 increments. (at bulb maximum 30 sec.).
2 Suggested Answers
toto
  • 425 Answers
SOURCE: shutter speed
The DiMAGE E223 controls shutter speed automatically between 1 sec. and 1/1000 sec.
Posted on Sep 19, 2005
My camera flash when on the shatter speed does not increase above 200
The fastest shutter speed with flash is 1/200 of a second. Due to the design of the shutter, the entire frame is not exposed at faster speeds. See the box "Shutter Speeds Available with the Built-in Flash" in the "Flash Mode" section of the manual (page 70 in my copy).
Apr 08, 2013 | Nikon D3100 Digital Camera
I am in the "s" mode for shutter speed priority and i cant change the shutter speed i use the scroll to get the arrow above the shutter speed on the view finder and from then i cant figure out how to...
Are you pressing the jog dial to save the setting? Here's what your book says:
  1. Turn the Mode dial to P, A, S, M, or C.
    The mode options are displayed.
  2. Use the jog dial:
    • Press the jog dial to open a setting.
    • Press the jog dial to save the setting.
    NOTE: Available options are white. Unavailable options are grey. Red options are out of range and may cause unacceptable image/print quality. Adjust the value higher or lower until it turns yellow.
Jun 11, 2010 | Kodak EasyShare DX7630 Digital Camera
Indoor picture are dark when using flash---seem like the flash and the camera are not in sync minolta 7d digital camera
If you are in Manual Mode and you set your shutter speed too higher (ie above 250th sec) the shutter blind passes over the sensor when the flash goes off causing a dark section in the photo. Lower the shutter speed to get a better sync. Some camera's default sync speed is 1/60th of a second and sometimes user adjustable.
Remember the longer the shutter speed, the more light will register in the photo. Also boosting the ISO will help extend the flashes range and also record more ambient light for a more pleasing and balanced photo.
Sep 04, 2009 | Cameras
Olympus C-8080 sticks at f8.0
You're confusing aperture with shutter speed but your camera is operating normally. The C-8080's smallest aperture is f8 and cannot go further.
The ranges available are:-
Wide: F2.4, F2.5, F2.8, F3.2, F3.6, F4.0, F4.5, F5.0, F5.6, F6.3, F7.1, F8.0
Tele: F3.5, F4.0, F4.5, F5.0, F5.6, F6.3, F7.1, F8.0
Shutter speeds are:-
15, 13, 10, 8, 6, 5, 4, 3.2, 2.5, 2, 1.6, 1.3, 1, 1/1.3, 1/1.6, 1/2, 1/2.5, 1/3, 1/4, 1/5, 1/6, 1/8, 1/10, 1/13, 1/15, 1/20, 1/25, 1/30, 1/40, 1/50, 1/60, 1/80, 1/100, 1/125, 1/160, 1/200, 1/250, 1/320, 1/400, 1/500, 1/640, 1/800, 1/1000, 1/1250, 1/1600, 1/2000, 1/2500, 1/3200, 1/4000 sec
I cut and pasted the above figures rather than typing them all from:-
http://www.dpreview.com/reviews/olympusc8080wz/
Jun 28, 2009 | Olympus Camedia C-8080 Wide Zoom Digital...
Panasonic DMC FZ30 shutter speed adjustment
set to s -then adjust using command wheel by thumb- 8 secs to 1/2000
Jan 20, 2008 | Panasonic Lumix DMC-FZ30 Digital Camera
Slow shutter speed
from the manual: Using Shutter-Priority Mode 1. Set the mode dial to S (shutter-priority) and a yellow arrowhead on the screen points to the current shutter speed. Press the jog dial and the current shutter speed turns yellow. 2. With the current shutter speed displayed in yellow, rotate the jog dial to select the speed you want to use. 3. Take the picture. If a workable aperture isn?t available for the shutter speed you?ve selected, the shutter speed indicator on the screen flashes when you press the shutter button halfway down. You can use the setting as is, or press the jog dial down to select the shutter speed again and rotate it to select a new shutter speed.
Jun 03, 2007 | Sony Cyber-Shot DSC-F717 Digital Camera
Shutter speed
Sep 19, 2005 | Konica Minolta DiMAGE E223 Digital Camera
What is the range shutter speed?
The DiMAGE A2 controls shutter speed in the range of 30 sec. to 1/4000 sec. in 1/3 increments. (at bulb maximum 30 sec.) The speed, 1/4000 sec. is controlled only when the aperture is f5.6 or over in P and A mode. The highest speed in S and M mode is 1/2000 sec. The lower range depends on the set camera sensitivity. ISO800: 4 sec., ISO400: 8 sec., ISO200: 15 sec., ISO100 and ISO64: 30 sec.
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
What is the available shutter speed for the DiMAGE 7?
The DiMAGE 7 has an available shutter speed of 4 sec. - 1/2000 sec., plus Bulb.
Sep 15, 2005 | Konica Minolta DiMAGE 7 Digital Camera
Aperture Priority Mode - an undocumented feature
In addition to the "quirks" of the Landscape and Aperture Priority Modes (neither mode works as documented!)..... The camera also behaves differently in full Manual Mode (it changes the settings, whether you want it to or not to compensate for available light)... At lower Zoom Levels, the camera will adjust the Shutter Speed Only, to try and compensate for available light... For example: with the Camera preset to F5.6 Aperture, and 1/48 sec. shutter speed, the camera will adjust the shutter speed between a range of 1/30 to 1/291 sec, to try and "auto expose" the shot for lower or higher light levels, even though you're in manual mode. At an Aperture Setting of 2.8 and 1/48 of a second, the number of internal steps in shutter speed the camera is willing to take, increases dramatially - for example: shutter speeds up to 1/600 of a second, even though you have the shutter set to 1/48 in manual mode. The camera WILL NOT attempt to adjust the Aperture to compensate for proper exposure in available light (OR WILL IT??).... It depends on your Zoom settings! It won't if your're near to full wide angle, but IT WILL if you are using the Zoom. Once you cross some unknown zoom threshold (it doesn't have to be at full zoom), then the camera begins to change both the Aperture and Shutter speed to compensate for available light, even though you are in "Full Manual", versus Auto Exposure Mode. In Manual Mode, (as in Aperture Priority Mode), the amount of change the camera is willing to make to your settings, appears to be related to a preset number of internal steps, with the number of steps dependent on both Aperture and Zoom Settings, before it gives an EV Warning for Over or Under Exposure conditions.... The type (shutter speed only for wide angle, shutter and aperture for zoom) and amount (number of internal "steps" it takes to increase/decrease shutter speed and increase or decrease aperture), is dependent on the amount of zoom you are using for the current shot.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Konica Minolta DiMAGE A1 Digital Camera Logo
57 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Computer Links
Damen Wong
Damen Wong
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
