1. Raise the handset on any telephone in the Panasonic Telephone system.
2. Press the "INTERCOM" button and dial 165.
3. When answered by the Auto Attendant, dial # XXXXX * 9 9 8.
(Pound Six Star Nine Nine Eight)
4. Enter the Administrator Password. Followed by a #. (Pound) If required.
5. Dial 5 to "Modify Message"
6. Dial 1 to "To Change The Company Greeting"
7. Enter the Company Greeting Number from 1 to 32.
If you are not sure of which Company Greeting Number to change, then start with 1.
The Panasonic Voice Mail system will actually play the greeting to you.
Then you can determine if it is the correct one you want to change.
If it isn't, you can dial 2 and move on to next greeting and so on.
If you select a greeting number where there is no greeting recorded,
the Panasonic Voice Mail system will prompt you to record one at that time.
You may dial *1 (STAR ONE) to skip recording and return to Step 7.
8. When you have found the Company Greeting you want to re-record
follow the system prompts to record and save your new greeting.
Note:
You can change the Company Greetings remotely from anywhere.
1. Call the main number of your business.
2. When answered go to Step 3 and follow the same procedures.
3. When completed....Hang up....
SOURCE: how do I set up voicemail
The voice mail extension is dependent on the system it's installed.
In a TA series, the extensions are either 107 or 115. An 848 could use 165, 500 or whatever number the installer assigned.
Your best bet is to go to the "back room" and find the Panasonic branded phone system and voice mail..if there is one, and post back.
Carl
SOURCE: help how to set-up a voicemail on panasonic
CLICK HERE for your owners manual in PDF format.
This phone does not have voicemail capabilities. Your company's voicemail system is seperate.
You can find Voivemail notification settings on page 10 of the manual.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
SOURCE: Panasonic kx-tga101cs incorrect voicemail message
Press and hold "Clear" until it beeps. It will clear the invalid voice mail msg.
SOURCE: KX-T7633 Voicemail rings
The Voice Mail feature is set by your phone company, not by the phone. Typically the phone company will set it for 20 seconds, or approximately 4 rings. This is called your voice mail "Ring Cycle"
Call them up (the customer service number should be on your phone bill) and they should be able to increase or decrease your ring cycle for you at no charge.
SOURCE: How do i Names to Extention numbers on the Panasonic KX-T7636
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system. From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook press Program * * or Program * # followed by the system password ( default is 1234). Now press 004 and then ENTER. Enter the extension number you want to change. Now enter the name (the same way as texting on a cellphone) To save the changes press AUTO DIAL / STORE. To go to the next extension press NEXT on the screen. When you are done lift the handset and put it down to exit program mode.
PLEASE rate/vote this answer if it was helpfull.
THANK YOU
