Maytag MFI2067AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
Posted on Aug 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello, my freezer handle broke on my Maytag refrigerator model #MFI2067AES. I need to know how to get a replacement. Can you help?
Anonymous
Level 3:
  • Maytag Master 43,501 Answers
  • Posted on Aug 10, 2011
Anonymous
Maytag Master
Level 3:
Answers
43501
Questions
0
Helped
10835088
Points
101584
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Mfi2067aes digital display is dark
I think that that may be caused by a defective 67006294 Dispenser Control Board. .. Item location 13 in this PHOTO. I am here should you have questions, Thanks John T. Appliance 911
Tempreture won't adjust
Digital? Is MFI206AES the correct model number? I cannot find a model number in the US database like that, Sea Breeze
Electricity off want to reset temperature. What should frig and freezer be set?
Temperatures are preset at the factory at 38 degrees or 3 C in the refrigerator compartment and 0 degrees F or -18 C in the freezer compartment. Here is a link=> MFI2067AES User Manual to the user manual for your model that explains how to set the temperature, I am here should you have questions Thanks Sea Breeze
2answers
Handle on bottom freezer door is loose. Screw on bottom of handle appears to be neither a philips or flathead screw. just seems like a teeny tiny rivet.. Inside the handle is a floating "ball"...
Hello, You need to look at the screw at the bottom of the handle. I know this is difficult to do; however, you have to establish what type of inset screw you have to faster. Most probably, it is a four or five star screw. You have to have a certain head screwdriver in order to turn the screw in order to secure the handle. When you identify the head of the screw -- as in four or five head screw -- place the screw driver into the screw and turn until it is firm.
If this does not work, refer to the manufacturer's manual to find a solution.
Hope this works for you. Dana
Maytag digital panel click on, then off. Refrigerator is warm.
The fault may have three places that it could come from. The Digital Logic Panel itself the motherboard or the low voltage transformer. If you like I will help you, Let me know, Thanks, Sea Breeze
How do I initiate defrost in a Maytag tri-door
Try this open the freezer door and flick the light switch 6 times, like flick, ----- flick,----- flick. If 6 does not work try 8, cant remember.
1helpful
Icemaker makes ice but wan't despense, also water wan't despense
i have model mfi2067aeb . the ice maker won't dump the ice. the arm is up that tells when the tray is full. can't get it down.
3answers
Mayteg refirgerator
French Door “ICE-2-0” Bottom Mount
Freezer Refrigerators with
Ice & Water Dispenser
Maytag Models: MFI2568AEB MFI2568AEQ MFI2568AEW MFI2568AES MFI2067AEB
MFI2067AEQ MFI2067AES MFI2067AEW
Amana Models: AFI2568AEB AFI2568AEQ AFI2568AES AFI2568AEW
cusTOMeR COMPLAINT:
Ice dispenser door continually opens and closes and/or user display flashes on and off intermittently.
cause:
Power supply circuit on high voltage control board may fail.
cORECTION:
Order and install high voltage control board kit PN 12920710. The kit includes; control board, installation and programming
instructions, return label and card for the old part.
Note: As with all Refrigerators of this type, the correct “Personality Code” must be programmed into the new control board
per the instruction sheet provided.
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
