The ancillary belts routing diagram for a 1998 VW Passat 1.8 Turbo
AC = Air Conditioning
CS = Crankshaft
F = Fan pulley
G = Generator
PAS = Power Assisted Steering
T = Tensioner pulley
WP = Water Pump
1. Viscous coupling removal (lock the viscous coupling).
2. Lock the ancillary drive belpassat 1998,4cylinders, turbo, what is - tdisline_825.jpg>
4. Remove the coolant pump drive belt.
5. Remove the ancillary drive belt.
6. Release the A/C tensioner if vehicle is equipped with A/C (Air Conditioning).
7. Remove the A/C compressor drive belt.
Below is the master help link
provided to go through belt routing diagram:---Timing belt, drive belt,
serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all
types of car models?
Click the link below: ----
http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
For water pump replacement i suggest you to check the help link
provided below.
click the link below :----
Water pump replacing procedure for all vehicles?
http://technoanswers.blogspot.com/2011/11/water-pump-replacing-procedure-for-all.html
HOW TO REPLACE A WATER PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-water-pump.html
How to route Water Pump Belt for 1992 Oldsmobile ?
http://carbeltrouting.blogspot.com/2011/12/how-to-route-water-pump-belt-for-1992.html
How to replace Water Pump on Car ?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-water-pump-on-acura-car.html
How to Remove Water Pump?
http://technoanswers.blogspot.com/2011/12/how-to-remove-water-pump-on-toyota.html
Where is Water Pump located ?
http://technoanswers.blogspot.com/2011/12/where-is-water-pump-located-on-toyota.html
This will help. Thanks.
How
How
How to Remove Water
Pump?
----------Below is the master help link provided to go through belt routing diagram:---Timing belt,drive belt,serpentine belt,accessory belt,fan belt,engine belt routing diagrams for all types of car models?
Click the link below :----http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
----------This will help.Thanks.
For water pump replacement i suggest you to check the help link provided below.
How to route Water Pump Belt ?
