Question about Oster 12-Bottle Wine Cellar - Black
How do you replace the Oster 12-Bottle Wine Cellar Fuse
Please explain to me (like a 2 year old) how I can replace this fuse. I opened the back cover, I located the fuse in the black covering and I've purchased a replacement fuse - how do I get into that black covering and replace it?
If you don't mind, step-by-step instructions would be greatly appreciated..
thank you!
Lisa
How do you replace the fuse?
Posted on Sep 30, 2008
2 Suggested Answers
  • 7 Answers
SOURCE: Fan doesn't work on oster wine cellar
First question, do you have power to the unit and the cooling fan is not working? If this is the problem then sounds like one of the two fuses in back panel has burnt out.
Posted on Feb 23, 2009
Wine Cooler Does NOT get cool.
Here is the web site to locate your closest oster service center. They should be able to tell you what their charge will be up front so that you can compare that charge to the cost of a new one.
Now days, sadly, many of these items are too costly to repair so they go to the landfill..
http://www.oster.com/CustService.aspx?content=center
May 21, 2009 | Oster 12-Bottle Wine Cellar - Black
Oster 12 bottle wine frig, how to set temp instructions please
I suggest you return that puppy as fast as you can.
The company that makes them took bankruptcy and warranties are no good.
To top it off the fans usually **** out in 6 mos or so.
May 15, 2009 | Oster 12-Bottle Wine Cellar - Black
Wine cooler temperture
blown fuse in back panel, there are two of them, one you can see, one is in black shrink rap, this is probably problem fuse. It was on my unit and had to cut away the shrink rap and solder in new fuse. Found the problem fuse in top left of panel in back of unit, hope this helps.
Jan 19, 2009 | Oster 12-Bottle Wine Cellar - Black
Dec 30, 2008 | Oster 12-Bottle Wine Cellar - Black
Adjusting temp
I think your problem is a fuse in back panel has burnt out....you will need to replace it, Tthere are two fuses and one is easy to see and as usual the easy fuse is not the problem, the fuse you need to replace is probably the one in a black shrink rap on top left side of the panel. You will need to cut shrink rap off fuse and find wires. Next step cut and solder in new fuse. I belive the fuse used is a 5 amp 250v, I put in a 6 amp to repair.
Dec 28, 2008 | Oster 12-Bottle Wine Cellar - Black
The fan does not go on
Ther are two fuses in back panel of unit. One fuse can be seen other is hidden top left of panel and is coated in black shrink rap. I had to replace that fuse to correct the problem. Problem is I had to cut away shrink rap and resolder another fuse, you may have to have someone who can do this look at your uint. Hope this helps.
Dec 19, 2008 | Oster 12-Bottle Wine Cellar - Black
No response from company on Oster 12 bottle wine refrigerator
just replace the 5amp fuse on circuit board with a 6.3amp. tada!
use an exacto knife to remove the shrink wrap on both ends of old fuse. heat ends with a soldering iron and pull away old fuse. solder new 20mm in line fuse holder from radio shack to both poles insert 6.3amp fuse and done. at least mine works again! $6.00 total cost!
Dec 15, 2008 | Oster 12-Bottle Wine Cellar - Black
Oster wine cooler fuse
I just replaced mine with a "Slo Blow" and it is working just fine. Got it at Radio Shack , 4 for approximately $3.
Sep 25, 2008 | Oster 12-Bottle Wine Cellar - Black
Oster 12 bottle wine cooler
You must remove the fuse from the circuit board to check it. More than likely it's blown. A continuity test while in the circuit will always show the fuse as being good due to feedback through the circuitry.
Aug 09, 2008 | Oster 12-Bottle Wine Cellar - Black
Broken door...
Buy a dented unit on eBay and take off the hinges
May 12, 2008 | Oster 12-Bottle Wine Cellar - Black
Oster 12-Bottle Wine Cellar - Black Logo
682 people viewed this question
Top Oster Furniture Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
jasbo
jasbo
Charles T Nevin
Charles T Nevin
Are you an Oster Furniture Expert? Answer questions, earn points and help others
