Question about HP Compaq ProLiant DL380 G3 Server
1 and 4 fan problem
The fans will not rotate but fan 1 lite is green (not rotating)and fan 4 is amber in color(not rotating) the server will boot up , however after awile the
# 1 fan will turn amber and then the server shutsdown and reboots.
seems to be no power to fan motors but i don't know why.
    Problem Solver:
  • 14 Answers
This might happen when it detects a non-functioning fan (to preserve all other components).
We've had the same problem on one of our server, one fan wouldn't start (needed more current to start it)
We had to replace the motherboard on server to make it work, since this one got it power from the MB.
A temporarily fix was: Pop fan 4 out, give it a push so it rotated and quickly insert it before it stopped, hope it won't be stopping until you receive a new motherboard.
Posted on Dec 07, 2008
Asus P5GC-MX/1333 system wont boot up, motherboard light on (blinking), fans on PSU not working, fan on motherboard not working, is that a sign PSU went bad? (it was OK a few days ago)
yes
it can be problem wth psu hence insert a wire in green socket and another in black socket of psu and this will short and psu fan will rotate. if psu fan rotates then you need to check the voltage supplies of the psu.
Apr 01, 2014 | ASUS Computers & Internet
Ibm xseries 205 reboot after begin the start
Check server has amber on it. If so inspect FAN and replace same if it has amber.
Mar 16, 2013 | IBM eserver xSeries 205 8480
Fans wont work ibm x3400
Remove fan that is having Amber from Fan bay . Clean fan slot as well as bay slot . Then Refix it . It will work .
Feb 20, 2012 | IBM x3400 Server
Fujitsu econel 100, server wont boot after trying many things i removed memory chips one by one and finally the server booted so i suspect it as faulty memory chip ok I managed to login and tinker around...
See if your fans and drives are spinning up fast enough, perhaps image a fresh drive if you can; certainly it's time to resolve BIOS state issues from discombobulating the DDR.
Er, how many DIMMs are in there now? 1? Is it good?
Jul 25, 2011 | Fujitsu Siemens PRIMERGY Econel 10...
My canon clc 1150 is continously showing e 804 ?
• The operation of a fan (indicated
by detail code) is faulty.
• The CPU PCB is faulty.
• The DC driver PCB is faulty.
0001 The electrical unit fan (FM8)
has stopped to rotate in error.
0002 The IP cooling fan (FM7) has
0003 The exhaust fan (FM2) has
0004 The ozone suction fan (FM5)
0005 The toner suction fan (FM6)
0006 The laser scanner motor
cooling fan (FM4) has
0008 The primary charging
assembly fan (FM3) has
Aug 02, 2010 | Canon CLC 1150 Color Copier
A power outage caused server to shut down. It
The power outage is suspected to corrupt the RAM. Get in touch with the vendow and get it replaced.
Nov 09, 2009 | HP Server Tc2120 (335874-001)
Its not booting and the Leds VRM and NMI are with amber color
VRM and NMI lights lit usually indicate an issue with CPU #2's VRM which can be replaced. Also check 5 lights on back middle of system. If VRM light is lit here remove CPU 2 and VRM and reboot system. If system boots, this was the issue...
Apr 25, 2009 | IBM eServer xSeries 346 8840 (884022U)
HP Compaq ProLiant DL380 G3 Server Logo
372 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
