Can not install windows 7
if you are doing an upgrade from windows vista to windows 7 check first the version of your vista operating system, for example if you are using windows vista home premium 32 bit then the windows 7 CD that you need is windows 7 home premium 32 bit also, cant mix any versions or types of bit. it should be always the same. try also to download the windows upgrade advisory run it and check for programs and applications that you installed or pre-installed in your computer that cant affect the installation, remove those programs and applications that are not compatible with windows 7. just install those back again after.
if you are doing a clean installation of the windows 7
check first if the system requirements for windows 7 installation is applicable to the specification of your computer. if your system is capable the bqack up your files and go ahead with the installation
i hope this helps
Pls rate my resolution thanks!!
