Question about RCA D61W20 61" Rear Projection Television
Which board is it?
Which board is that? I paid for the premium service, and they told me to change the STK IC. They couldn't tell me where to find it or which one it is. I've just been all through my unit and I don't see anything labelled STK. I have 2 boards which are easy to access. One is SRS-310 and the other is YPRPB-130 AV5. Do either of those sound close?
  • 1 more comment
  • Rene LeBlanc Sep 04, 2008
    I accidentally started a new thread. I meant to post a comment to a different posting where you had told me it was a convergence problem. The specifics are:
    I have an RCA 61939 61" Projection TV that has a convergence problem. Quite a few months ago, we heard a snap and the TV shut off. It came right back on when we hit the power button, but it is bowed in on the top, bottom and sides. We can't adjust the green convergence, but have adjusted the Red and Blue so it doesn't look 3D, but there are no straight lines on it.
    I'm capable of performing board swaps, etc, but haven't seen any references to what to change. Can you help?
    Thanks in advance
    Update, I went back in and wrote down the part number for every board and then looked for chips labelled STK. While doing so, I noticed that Resistor R14512 is cracked and turned white. I can only tell that the first color is Brown and the last color is silver.
    Can anyone tell me what value this should be? I think I'll start by replacing that.
  • Rene LeBlanc Sep 05, 2008
    It appears I have a 15888420 convergence board. I can't find any STK chips. Where can I obtain a new one or get this one rebuilt?
  • 2,920 Answers
Tell me what your tv is doing and ill try to go through everything with you on it
Posted on Sep 03, 2008
The red color stops working. If I tap the convergance board it sometimes pops back in.
If ws55807 it is not bad connections on the middle board where the two STK-392-570 convergence chips are.
I have seen this over 100 times in these sets. What happens is the pins break loose inside the chips----I have had ones where I unsoldered the pins and some just fall out--only the solder trying to hold them in.
The good news is Total parts cost for the repair on EBAY (I use a seller there) will be about 15 for the two chips and should be under 30 total for everything needed.
I also have start to finish step, by step instructions for this repair in this model---tell you everything you will need and the best way to do it.
I will attach a photo of a typical convergence IC---yours are up front on the middle board facing the front of the set.
If this information told you something you did not know, rate this solution as very helpful as I do this here for free.
95782e7.jpg Yours will have the STK-392-570 NUMBER ON THE FRONT OF THEM.
Aug 30, 2010 | Mitsubishi WS-55807 TV
P56938 Convergence Problem
I've found some this i nfo that could help you troubleshoot your TV.
Your problem is likely to be in the convergence board power supply
p/n 250868. May not be supplying the - and + 15 volt supply, abd the +45
volt and - 45 volts account shorted diode cr19710. p/n 164590. also replace
cr19709 the one next to it same part #. Also if stk730-130 is bad it can
cause this problem. Also check r 19703 (750k 1/2watt) may be open,
q19700(bc457)or nte123a could have base emitter open.
Jun 26, 2008 | RCA P56950 56" Rear Projection Television
I have a sony projection tv model #KP51WS510 and I was told the convergance amplifier was going out and I was needing info about where it is located so I can change it out. Thanks
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
Oct 24, 2009 | Sony KP-51WS510 51" Rear Projection...
Denon 2106 Protect Mode (Update)
Yes, I am in Texas, just moved there from Michigan. Got away from the cold just in time. It's beautiful in Colorado, but just too cold for me.
I had no idea you had paid for a premium service. You contacted me thru the free forum. If you would like for me to get the payment for the premium service, you could contact fixya thru this email ( ) and tell her (Lauren) how you did not get the information you needed from the premium question you asked and would like that credit to go to me. She will know what to do about it. I really don't know how you would go about it. As it stands right now, you will end up paying whoever answered you first unless you gave somebody a FixYa! rating and accepted the solution. Unless you request a refund. Which is what you may need to do. I hate to see some other person get paid for my knowledge. This has happened to me on many occasions. I get contacted thru the free forum to solve a problem they have paid somebody else for. I don't spend a whole lot of time on the site, since almost everything I do on this site is free help.
In the premium questions you should not give anyone anything but a "Thanks for Trying" unless you are satisfied you have received the help you have paid for. I never seen a link to the premium question you paid for, so I never got a chance to answer you there. I am sure that some of the answers you were getting there were very amusing, to say the least. As I told you in my last post, I really am an expert in these receivers and I don't believe there is another expert here with the experience actually repairing them as I have. There is a decent bunch of folks working here, but many are not really the experts they claim to be. It can be a pretty frustrating activity using the premium service because there are so many so called "Experts" that are only in this for the money and try to answer questions they know nothing about. I hope it was not as bad for you as I have seen in many other cases.
Dave (tech48)
Dec 03, 2008 | Audio Players & Recorders
STK IC 392-110 Chips
am having stk 4392 amp board 2 channel, i want to change this two channel in to one channel. what modofication should i do
Dec 02, 2008 | Toshiba 42H81 42" Rear Projection...
Blinking colors
there is a stk ic in the tv.which is located on the main board of the tv.that stk ic has gone faulty so u r getting this problem. u can get this new stk ic for replacement at  radioshack websites.
Dec 01, 2008 | Toshiba Televison & Video
Now What???
I want to get this straight are you saying that you cant align them
and this is your focus problem or you have two problems that you cant get the convergence and the focus?
it might have been easier just to have the board replaced...
Samsung parts for convergance problem
Jan 28, 2008 | Samsung HC-P4752W 47" Rear Projection...
Convergence tp55e50
There are two Ics that need to be change to correct the convergency problem. These parts are mounted on a big heatsink.
Check this site for cheaper parts: //
Jan 26, 2008 | Toshiba 55H70 55" Rear Projection...
Sony KP-43HT20 ghosting effect.
may have bad convergence amps stk392-560 board location Ic8001 Ic8002 or the dcu unit is bad or the alignment drifted off and it needs service adjustments made to it.
Dec 28, 2006 | Sony KP-43HT20 43" Rear Projection...
RCA D61W20 61" Rear Projection Television Logo
62 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
