Question about Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television
I just replaced the light two weeks ago. Everthing worked fine for two weeks but the timer light that turns green when power is pushed has taken longer and longer to turn the TV on. Now the timer light comes on steady green for 30 to 40 seconds then goes off and the lamp indicator light starts flashing green for awhile the turns red
Yes this is the signal for a bad lamp. Other things can cause this. 1. Look at the new lamp. make sure it still looks good. not broken with little glass pieaces in it. 2. When you turn on the tv, put your ear to the lower back part of the tv near the middle. Listen for the start up of the color wheel (a low high pitch sound only at the start up of the motor). If this is good you will here a ticking sound only if the lamp dose not light.
Now with all this info. If the lamp lights (as seen from the back of the set) and goes out after a few seconds and you did not here the color wheel spin up, the color wheel is bad.
If you here the color wheel spin up and no ticking sound, the Ballast is bad.
The ballast part no. 939P978010
The color wheel is not avialable from Mits. You will have to replaced the light engine. It cost to much. Just buy a new tv.
Posted on Nov 15, 2008
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Feb 03, 2011 | Toshiba 65HM167 65" Projection Television
Sep 05, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
Aug 11, 2010 | Mitsubishi WD-62725 62" Rear Projection...
May 28, 2010 | Sony KDF-E55A20 55 in. LCD Television
Jan 30, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Jan 19, 2010 | NEC VT676 Multimedia Projector
Jan 03, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Dec 06, 2009 | Televison & Video
Feb 07, 2008 | Mitsubishi WD-62827 62" Television
207 people viewed this question
