Question about Velodyne Audio Players & Recorders
My Velodyne CT 80 powered subwoofer does not power on?
Velodyne CT 80 powered subwoofer with 8" subwoofer
  • supercraig Sep 03, 2008
    Just bought the Velodyne CT 80 powered subwoofer used off Craigslist. I think it was manufactured between 2000 and 2002. The unit is in cosmetically great shape, suprisingly for it's age. Subwoofer looks to be in New condition! The man I bought it from said it was working and then one day he went to turn on and nothing! So, I decided to buy into and fix the problem somehow, need some help as I am not an Electronics Technician. Any suggestions or help would be appreciated.
  • 124 Answers
Fuse in amp may be blown or the amp is dead
Contact Velodyne, the replacment amp is not very expensive
Posted on Jan 04, 2009
8 INCH MTX ROAD THUNDER SUBWOOFER WON'T WORK NO SOUND NO NOTHING
has it ever worked, if so did you ever use it in the cold because in the cold it is possible for the wiring inside the speaker to crack and break
Oct 29, 2012 | Velodyne CT-80 Subwoofer
My ct-120 is humming how do I get it to stop?
My CT120 just started doing this and replacing the 2 large capacitors in the power supply section of the amp fixed it.
Nov 06, 2010 | Velodyne CT-120 Speaker
My subwoofer keeps poping and then stops working
larryagross,
Sounds like you blew the speaker! The amp is sensing the voice coil is connecting to the speakers magnet or iron core and is going into a safe mode. It is possible to blow the coil even when the sub has a built in amp.
First make sure that you have the gains properly set ans not all set to their maximums. Second, disconnect signal to the sub then unplug the power for a few minutes. Third, plug the sub into a source of power on a different circuit using a surge protector.
Does the speaker make any popping at the time it powers up? If so you have a amp problem. If there is no sound produced, connect it back the the system using a different signal cable. Does the speaker now pop again when sound is produced. If so the speaker has failed. Contact a Velodyne repair facility.
-Chris
Aug 10, 2010 | Velodyne CT-80 Subwoofer
Hooking power amp to back of sub
Contact Velodyne.
Should have been a sheet in the box with amp for this
Feb 28, 2009 | Velodyne SPL800R Subwoofer Speaker
No sound for Velodyne ct-100 sub woofer
Sounds like a dead amp. You could check the xformer output and the amp IC's with a VOM.
These amps do not cost a lot, about $40.00. and are easy to replace.
Contact Velodyne
Feb 25, 2009 | Velodyne CT-100 Speaker
Lost manuel
The Q55 is not a velodyne product
Nov 17, 2008 | Velodyne CT-80 Subwoofer
Subwoofer will not work when connected
cheak setting in sterio out put for sub on ect does woofer have sperk wire going in and out use them then ok
Feb 11, 2008 | Velodyne CT-80 Subwoofer
706 people viewed this question
Top Velodyne Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Are you a Velodyne Audio Player and Recorder Expert? Answer questions, earn points and help others
