Hello there,
The phone comes with a low memory size that is why it is not receiving large files from other devices via bluetooth. What you should do is to try to get an additional memory card and install into the phone, then when you receive files via bluetooth, you should send them to the memory card.
For the internet that is slow to connect, the problem is not from the phone, it is from the network of the sim card service provider. It tends to be slow on some kind of phones with low memory capacity to read internet faster.
Insert a memory card into the phone and try to move all files on it, then you can surf the internet using ur phone with an improved internet speed.
Hope this helped.
Goodluck
Elect_Comp
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link Rm-181 file /Rm-174 file.(there are two types of 5200 so,I've given two files, choose what is written in your phone) and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good luck.
If you do not want cantact mobile repairing shop this is the best way....actually i can solve via it internet but.....
Follow the instruction
Pheonix. Nokia
Phoenix Service Software 2011 - Download secondly Download flash file from this link 7210c file or Nokia flash file and install it to C / programme
files/pheonix..after finished this installation open pheonix Inside the interface at the> left top <there you see
then select the approprait Product type i.e"which is written in the
back banel inside the battery of every Nokia(Type RM-000).After doing
"Flashing" press there when you click there you'll see three
icon just select the "Firmware Update" again you'll see
another interface.Look at the product code there should be blank and put your
there is a Botton and choose the code which is written in the
back side of your phone.e.g CODE:0000000.if the same code does not found
just take one.After this you can see "Dead phone USB flashing"
click that box.Now this is the last stage... Connect your phone with the USB
finished (In case your phone is Dead,unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish"
press it and wait untill the phone will Restart automaticlly in normal mode
10-15 minutes.If you cannot understand just make a Reply thanks for
visiting fixya.Good luck.If you could not do please contact me.
