Question about GE Advantium 120 Convection/Microwave Oven
New problems after installing light bulb.
I purchased a GE Advantium 120 oven about a year ago and everything has been fine, I recently found this site because I needed to change the inside light bulb which had burnt out. Thank you for the GREAT instructions for the light replacement, but after turning the power back on the internal fan now comes on, the new light illuminates while the door is shut and the carousel continually turns round and round. I currently have to unplug the oven to make all the items listed above STOP.
Things that I have done to correct the probelm:
  • I have removed the new light bulb.
Results unchanged.
  • I have left the oven plugged in for hours to see if “maybe” the oven was in the cool down mode.
Results unchanged.
This problem is odd to me, do you have any idea’s what might have gone wrong or are you aware of a reset button that might fix this problem????
  • shawngo Sep 03, 2008
    Model number is SCA1001KSS01
  • GE Master
  • 8,865 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Then let us know if the hard reset does not fix it.
I would think you have a problem with a door switch or door switch mount.
Posted on Sep 16, 2008
Sear Advantium 120
Disconnect it and connect bac to power. check the fuse. If nothing works is either the fuse, the cable or the power supply unit.
Apr 03, 2008 | GE Advantium 120 Convection/Microwave Oven
Arcing sparking to carousel wheel. have 8 year old GE advantium 120 microwave oven. Was working just fine with a burnt out lightbulb but when I replaced the over head lightbulb it started to arc to the...
I think the problem is just coincidental to the lamp replacement.
i would say there is grease or food debris on the turntable support or turntable motor coupler.
The service manual is here and you can order parts from the Pros here.
Sep 23, 2013 | GE Advantium 120 Convection/Microwave Oven
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
Advantium 120 Interior light is out. How do I replace?
Here ya go... this fella did a good job and replaced the bulb for $4.95 vs $180.00 for the service call parts and labor. This is With pictures and how to steps down the page.
http://www.instructables.com/id/GE-Advantium-Microwave-Halogen-Lightbulb-Replaceme/
Thanks for using FixYa.
Kelly
Apr 09, 2010 | GE Advantium 120 Convection/Microwave Oven
Interior light always on Ge advantium 120
I bet by now your microwave is no longer working....did the bottom or top "hook" finally break off? I found that mine had cracked and started coming loose and so when it closed it was no placing enough pressure on the internal safety switch that tells the oven the door is shut. I was able to use a sturdy plastic glue to solve the problem but finally after about 2 years of fixing it I can no longer get it to bond. Now, I'm looking for a new part. Who makes a product this expensive with plastic parts!!?!??!?!? So frustrating.
Apr 13, 2009 | GE Advantium 120 Convection/Microwave Oven
Light bulb in oven went out
Remove the top grill by removing two screws in the top. Pull the top of the grill out towards you as the bottom has pegs on it. About 6 inches from the left is metal cover that you just squeeze with your finger tips to remove. This exposes the bulb.
Mar 28, 2009 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Opinion
I have had an Advantium for about 3 or 4 yrs and would use nothing else! When this one wears out I will buy another one! I hardly ever use my regular oven any more! Hope this helps.
Feb 02, 2009 | GE Advantium 120 Convection/Microwave Oven
Black Metal Tray for GE Advantium Oven
I just found one for $33.95
http://www.partstore.com/GetModel.aspx?MfgName=General+Electric&BrandName=General+Electric&ModelNumber=SCA1001FSS001&page=3
Aug 26, 2008 | GE Advantium 120 Convection/Microwave Oven
Replace inside bulb
There is a step-by-step guide with photos here.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 26, 2008 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
168 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
