Question about Roland Vs-2000CD Digital Studio Workstation System
Roland vs 2000 no power up
Dc power from adapter good but no power up
    Sergeant:
  • 243 Answers
Check the powersupply on the board itself ensure that its not blown.
thanks,
Nate
Posted on Sep 23, 2008
Can't get this Roland adapter model ACH-120.
I see that´s a pretty expensive power supply.
option 1: buy an equivalent power supply and adapt the cord.
IN: AC 120V 60Hz 12W
OUT: DC +10 V 500mA
DC -10 V 150mA
option 2: Build a new power supply by a kit
something like this:
http://electronics-lab.com/projects/power/011/DUAL%20VOLTAGE%20POWER%20SUPPLY.JPG
Change the 7812 and 7912 by 7810 and 7910. you will get the 10V needed.
option 3: you can try to repair the power supply. check if there is no broken wires or a blown thermal fuse in the transformer.
Jan 28, 2015 | Roland Music
My roland vs 2000 says not found any drivers when i turn it on can it be fixed
I think your best option is to try downloading and installing the latest system update from the Roland Site link below.
http://www.rolandus.com/products/productdetails.php?ProductId=602
May 06, 2011 | Roland Vs-2000CD Digital Studio...
I had used a lower Ac Apadter, it was about 300 Millwalts,But the SP uses about 1000 Millawalts. Would The Roland Sp 606 Still Burn Out if i use a lower Ac adapter?
the unit will only draw the amps it needs, at that low of amps it should not even turn on.
However the voltage is the question YOU CAN NOT USE A POWER SUPPLY THAT HAS MOVE VOLTAGE.
THINGS TO CONSIDER;
is the unit AC or DC
are you applying the right voltage (9VDC 1000MA) (9VAC 1000MA)
if it's AC you can not use DC and vice versa
Feb 22, 2011 | Roland Sp-606 Sampling Workstation System
Hello my roland street cube won't power on, either with dc or batteries....adapter working .could a fuse be blown inside circuitboard? thanks
That is the first thing to check. They are most likely inside the circuit board. Remember to replace them with the same voltage and amperage ratings.
Feb 13, 2011 | Roland Cube-st Battery Powered Amp Cube...
My Roland will not power up at all. Not sure if it is the power supply or the handsonic itself.
Test the power supply with a meter. It should be 9 volts DC and it rated at 2 to 2.5 amps (2000 to 2500 ma)
Jan 20, 2011 | Roland HandSonic 10 Percussion Controller
My roland vs-2000
could you please be more specific
thanks,
Nate
Sep 01, 2008 | Roland Vs-2000CD Digital Studio...
Luckeywalker@yahoo.com My Roland VS 880
that would depend on where you are located in the USA doesn't fix ya have people who do repair work in another section.?
May 27, 2008 | Roland Vs-2000CD Digital Studio...
COMPAQ V2000 WILL NOT POWER UP WITH DC/ADAPTER OR BATTERY
After you have verified that the solder is good around the DC Jack >>>>
Check MOSFET (Anachip 4407 or Fairchild 4435) near DC JACK
[replace the pair PNP/NPN]
Check MAXIM IC (MAX1999)
Mar 13, 2008 | Compaq Presario M2000 Notebook
Roland Vs-2000CD Digital Studio Workstation System Logo
180 people viewed this question
Top Roland Audio Players & Recorders Experts
Electric Dime
Electric Dime
Joseph Mueller
Joseph Mueller
Jerry Greenberg
Jerry Greenberg
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
