Question about Refrigerators
Repair icemaker shoot on door - Refrigerators
How to repair ice chute on Kenmore model 59292992
Posted on May 24, 2013
Icemaker shoot on door keeps freezing up nd does not let the ice cus or the crushed ice go thru.Help!
Posted on Sep 05, 2008
Door on shoot not closing completely. I'm having the same problem and cannot get door to close properly. Any thoughts?
Bill
Posted on Oct 13, 2008
How to trouble shoot GE ice maker that is not producing ice
Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ... www.youtube.com/watch?v=fPeZ29XdX5U
    • BY DIGITALPIMPLE
    • 4 MIN
    • 295K VIEWS
    • ADDED 2013-05-15
    Video embedded ยท How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair www.partselect.com/Repair/Refrigerator/Not-Making-Ice Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - products.geappliances.com products.geappliances.com/appliance/gea-support-search-content?... Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances products.geappliances.com/appliance/gea-support-search-content?... New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    I have a Crosley side by side refrigerator. I replaced my ice maker line due to a water line repair. Now, I can't get any water to come out the door or in the icemaker
    Note: Always make sure your filter is current if you have one. Not doing so will cause water to not despence properly
    Pull the machine out and remove the lower back cover. Locate the water valve. With the water turned on and connected remove the 5/16" water line (the bigger one) and then have someone else press the water in the door. If the cylinoid is operating correctly it should spray water out.If so, you just verified that the valve and electrical portions are working properly and either the filter is bad or the resevoir, , located inside the lower refrigerator side is frozen. If no water comes out but the valve vibrates, then the valve is bad. If no water and no vibration, continue reading.With the machine plugged in but the wires that go to the valve for the dispenser off take a volt meter and place a lead to each wire and have someone press the panel in the door as if getting water. The reading should go from 0 to around 115-120 a/c.If your not getting electricity down there at anytime than thje door switch is bad.
    Testing the ice maker:
    As far as the smaller line (1/4") you have to manually advance the ice maker and wait for it to call for water with the 1/4" line disconnected from the valve. For whirlpool and its subsidaries,you can do this by getting a jumper wire, removing the cover of icemaker, which you jsut grab and pull off, and using the jumper wire insert one end of the wire into the cirle marked m and the other in the cicle marked n. Leave there until you hear a click and sometimes see a little spark behind the modular head wheel. For GE, you turtn the ice maker off, wait about a minute then turn back on, water should automatically shoot water in the icemaker. That will tell you the water valve is good and icemaker is bad, or the ice maker is good and the valve is bad if no water. Also if you see ice in the maker that hasn't dumper and the teeth of the icemaker are facing any direction other than two o clock position, the icemaker is bad. Also check the fill tube to be sure the no ice is blocking water from coming in.
    Jun 17, 2012 | Crosley Refrigerators
    Whirpool icemaker making noises but not producing any ice
    Hi
    Please check the bellow links to trouble shoot your problem when the icemaker is not making ice:-
    http://www.ehow.com/how_4844376_troubleshoot-whirlpool-refrigerator-ice-makers.html
    Also check the bellow link for whirlpool icemaker repair guide:-
    http://www.appliance-repair-it.com/Whirlpool-icemaker-repair.html
    Please get back to us if you have further query else please accept the suggestion.
    Thank you for contacting fixya.com
    Feb 02, 2011 | Refrigerators
    Water not filling icemaker
    Inlet valve for sure located behind back access panel. Make sure you look at the water tube shoot going into your icemaker for build up before you replace it. This could also be your problem. Fixed this problem many times. Rate me if I helped you!
    Aug 26, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
    No ice is coming out of ice maker
    1. Whirlpool Icemaker Repair Guide ... guide I will walk you through the steps in a whirlpool icemaker not making ice. ... when you do this water does enter the icemaker take that jumper wire and place ...www.appliance-repair-it.com/Whirlpool-icemaker-repair.html - Cached
    Dec 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
    Icemaker on side by side not working
    Change out your ice maker. If your icemaker has worked for 6 years, you got lucky! They normally have to be changed out every couple of years. We have an unlimited inventory of appliance parts for Whirlpool, so please call us to send your parts out and we'll get them out right away!
    Sep 17, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
    Icemaker works fine, only dispenses water
    make sure that the ice shoot is not clogged up with ice or the in the ice basket where the ice goes through. Sometimes the ice can be stuck together and jam and nothing will come out.
    Nov 25, 2008 | GE GSS25JEMWW Side by Side
    Ice maker not shutting off
    The icemaker should have a bar that is normally in the downward position (ie 4'Oclock) when the bin is not full. The ice falls into the collector and pushes that bar into a horizontal position (ie 3'OClock). These instructions are normally on the ice dispenser section. If the bar is not being pushed up then the icemaker does not know to stop. My only suggestion would be to empty completely the ice maker bin and check that the bar can be pushed from one position to the other. If this happens then try turning on again. I hope this is of some if not much help and good luck.
    Jan 27, 2008 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
    Samsung rs2555sl icemaker
    replaced circuit board. Problem solved
    Oct 17, 2007 | Samsung 24.8 Cu. Ft. Side-by-Side...
    Refrigerators Logo
    264 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
