Question about Kenmore 24032\24036 Top Load Washer
Kenmore Top Loader
I have a top loader Kenmore, when I pull out the dial to begin a load, it clicks however water does not fill the basket...What shall I do ?
  • Jeffboggjuk Apr 19, 2009
    where is fill value
  • 1,028 Answers
Try different temp settings be sure screens in inlet valve end of hoses are clean and taps on all the way if you gave water to washer and still none coming in suspect bad fill valve
Posted on Sep 05, 2008
When filling my Kenmore washer to begin a load of laundry the water enters the tub like it is going to wash but immediately drains onto the floor and the "water sensor" never tturns the water...
This either due to a detached "water sensor"/pressure switch hose or a broken drain/leaking drain pump. Disconnect power then remove the screws securing the console to the top of the machine. Pull the console forward then up and lay it back on the hinges. The screws are located at the rear of the console, front corners of the console, or at the front corners of the console under the end caps.
Click on the link below for the detailed procedure in troubleshooting and repair of this leak problem.
Whirlpool and Kenmore Top Loader Washing Machines Leaking From the Bottom
Aug 20, 2011 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series top loader - wouldn't drain & spin
The lid switch is the only thing affecting this part of the cycle. The new switch comes with the new plug (under console ) and the harness that goes to the switch. The console will flip up and the cabinet will pull forward after removing 2 brass looking clips. After that it's right there under the right side of the upper cabinet.
Mar 08, 2009 | Kenmore 24032\24036 Top Load Washer
2 year old top loader Kenmore fills, washes, doesn't drain & does
check yor lid switch,,its a little switch on right side of cabnit..listen for a click,,your unit doesnt have a belt it has coupling
Dec 24, 2008 | Kenmore 24032\24036 Top Load Washer
Font loader washer water does'nt shut off
remove top replace fill valve left rear be sure not to remove the screens inside valve except to clean but be sure to reinstall or trash may get into valve and not allow proper shutoff
Oct 24, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 110.24422300 Top Loader Washing Machine
We have one of two situations happening here. Either your timer is going or the motor is blown. The other thing is to put the machine into spin and see if it drains, let me know!
Oct 02, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22956 top loader quit running after agite cycle
If the timer cycles your lid switch is ok.
most likely: motor Switch (on Motor), condenser next to motor, motor itself, or wiring going from the time to the switch,
It is probably cost efficient to replace the unit rather than trowing parts at it .
Apr 06, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore front loader keeps filling water in drum and will not stop
Plug off the wall. Open up behind, you will find a thin tube going from the pump area to the control point. This is the water level tube; untie this tube from above & blow into it, it should be free, if not free remove the blockage, see that it is not twisted, insert carefully. Or replace. This shd fix your water level problem.
Rate if helped pl..................
Jan 12, 2008 | Kenmore 44102 Front Load Washer
Washer filled with water & then stopped & will not work in any cycle.
could be a bad pressure switch did it fill all the way is it a top loader or front loader any noise or nothing
Dec 31, 2007 | Kenmore 24622 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
73 people viewed this question
Sal De
 Brian Main
Brian Main
